[mpich-discuss] mpi error
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Apr  3 10:21:26 CDT 2012
 Which version of MPICH2 are you using? How are you running your client/server programs (Copy-paste the command and its output)?
Jayesh
----- Original Message -----
To: "mpi" <mpich-discuss at mcs.anl.gov>
Sent: Tuesday, April 3, 2012 9:36:59 AM
Subject: [mpich-discuss] mpi error
Hello,
I have a client/server program, and I run it in the same machine (I have already installed MPICH2 on my machine which have OS Windows 7 64-bits).
When I run the server program in commend line, this error appears:
Fatal error in MPI_Open_port: Other MPI error, error stack:
MPI_Open_port(124): MPI_Open_port(MPI_INFO_NULL, port=0x003CF6B4) failed
MPID_Open_port(69): Function not implemented
****here we have the server code :
#include "mpi.h"
#include <cstdio>
#include "string.h"
#define MAX_DATA 100
using namespace std;
int main( int argc, char **argv )
MPI_Comm server;
double buf[MAX_DATA];
char port_name[MPI_MAX_PORT_NAME];
MPI_Init( &argc, &argv );
strcpy(port_name, argv[1]); /* assume server's name is cmd-line arg */
MPI_Comm_connect( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &server );
bool done = false; int tag, n = 0;
while (!done) {
tag = 2;
MPI_Send( buf, n++, MPI_DOUBLE, 0, tag, server );
MPI_Send( buf, 0, MPI_DOUBLE, 0, 1, server );
MPI_Comm_disconnect( &server );
MPI_Finalize();
return 0;
****here we have the client code :
#include "mpi.h"
#include <cstdio>
#include "string.h"
MPI_Comm client;
MPI_Status status;
char por t_name[MPI_MAX_PORT_NAME];
int size, again;
MPI_Comm_size(MPI_COMM_WORLD, &size);
//if (size != 1) error(FATAL, "Server too big");
MPI_Open_port(MPI_INFO_NULL, port_name);
printf("server available at %s\n",port_name);
while (1) {
MPI_Comm_accept( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &client );
again = 1;
while (again) {
MPI_Recv( buf, MAX_DATA, MPI_DOUBLE, MPI_ANY_SOURCE, MPI_ANY_TAG, client, &status );
switch (status.MPI_TAG) {
case 0: MPI_Comm_free( &client );
MPI_Close_port(port_name);
MPI_Finalize();
return 0;
case 1: MPI_Comm_disconnect( &client );
again = 0;
break;
case 2: /* do something */
break;
default:
/* Unexpected message type */
MPI_Abort( MPI_COMM_WORLD, 1 );
if you have any solution, please help me.
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
