[mpich-discuss] mpi error
moussa boutouil b.moussa1989 at live.fr
Tue Apr 3 09:36:59 CDT 2012
Hello, I have a client/server program, and I run it in the same machine (I have already installed MPICH2 on my machine which have OS  Windows 7 64-bits).When I run the server program in commend line, this error appears: 	Fatal error in MPI_Open_port: Other MPI error, error stack:	MPI_Open_port(124): MPI_Open_port(MPI_INFO_NULL, port=0x003CF6B4) failed	MPID_Open_port(69): Function not implemented   ****here we have the server code : 	#include "mpi.h" 	#include <cstdio>	#include "string.h"	#define MAX_DATA 100	using namespace std;	int main( int argc, char **argv ) 	{   	MPI_Comm server;     	double buf[MAX_DATA];     	char port_name[MPI_MAX_PORT_NAME];      	MPI_Init( &argc, &argv );     	strcpy(port_name, argv[1]); /* assume server's name is cmd-line arg */      	MPI_Comm_connect( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &server );      	bool done = false; int tag, n = 0;		while (!done) {         	tag = 2;         	MPI_Send( buf, n++, MPI_DOUBLE, 0, tag, server );     	}     	MPI_Send( buf, 0, MPI_DOUBLE, 0, 1, server );     	MPI_Comm_disconnect( &server );     	MPI_Finalize();     	return 0; 	} ****here we have the client code : 	#include "mpi.h" 	#include <cstdio>	#include "string.h"	#define MAX_DATA 100	using namespace std;
	int main( int argc, char **argv ) 	{ 	    MPI_Comm client; 	    MPI_Status status; 	    char por		t_name[MPI_MAX_PORT_NAME];   	  double buf[MAX_DATA];     	int    size, again;      	MPI_Init( &argc, &argv );    	 MPI_Comm_size(MPI_COMM_WORLD, &size);     	//if (size != 1) error(FATAL, "Server too big");     	MPI_Open_port(MPI_INFO_NULL, port_name);     	printf("server available at %s\n",port_name);     		while (1) {      	   MPI_Comm_accept( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &client );     	    again = 1;       		  while (again) {            	 MPI_Recv( buf, MAX_DATA, MPI_DOUBLE, MPI_ANY_SOURCE, MPI_ANY_TAG, client, &status );            	 switch (status.MPI_TAG) {                 	case 0: MPI_Comm_free( &client );                 	        MPI_Close_port(port_name);                  	       MPI_Finalize();                 	        return 0;                		 case 1: MPI_Comm_disconnect( &client );                 	        again = 0;                   	      break;                 	case 2: /* do something */ 						break;                	default:                         /* Unexpected message type */                         MPI_Abort( MPI_COMM_WORLD, 1 );                 	}             	}        	 } 	}
if you have any solution, please help me.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120403/89b9584d/attachment.htm>
