[mpich-discuss] mpich-1.4.1p1
    Anthony Chan
    chan at mcs.anl.gov
    Wed Sep 21 14:56:47 CDT 2011
Configure (or any autoconf generated script) assumes C locale, see
http://www.gnu.org/software/autoconf/manual/autoconf.html#Special-Shell-Variables
Search for LANG or LC_ALL...
----- Original Message -----
> Hi,
> Am 21.09.2011 um 21:10 schrieb Gus Correa:
> > Anthony:
> > How about non-ascii characters? e.g. � (A with an accent)
> about this I wondered too. Also in respect to a linked in RPATH or
> RUNPATH in the final application which one can check with `readelf -d
> program`. Does the ability to execute the application then depend on
> the setting of the locale?
> > Are they OK in Linux directory and file names?
> > Do they require some specific locale setting, UTF-8 character set,
> > or other?
> > Does autoconf digest them right?
> > Carolina:
> > I'd stay on the safe side and stick to very conventional
> > file and directory names made only of:
> > 1) upper and lower case letters [a to z, and A to Z, without any
> > accents, be careful with your Brazilian ABNT/ABNT-2 keyboard!],
> > 2) digits [0 to 9],
> > 3) underscore (_) [e.g. my_file], and
> 3a) a dash and plus (-+) if it's not the first character. My users in
> computational chemistry use them quite often without known issues.
> > 4) period (.) [e.g. my_program.f90]
> > And use the slash (/) *only* for directory name separator.
> > No blanks of course [which is a Windows thing].
> 5) No colon : on a Mac in a terminal. It will show up in the GUI as
> slash. Despite working it's confusing. Origin is that the colon was
> (is) the directory separator in HFS (Hierarchical File System) used
> there and translates from the GUI ":" to a terminal "/" and is
> rejected because of this in the opposite way.
> 6) Default on a Mac is not to distinguish between upper and lower
> case, even in a terminal. Unless you format the partion in a different
> way to honor it or as Unix FS.
> --Reuti
> > My two cents,
> > Gus Correa
> > Anthony Chan wrote:
> >> Carolina,
> >> Here are lines that in config.log shows the problem:
> >> configure:11770: gcc -c -I/home/carol/�rea de
> >> Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include
> >> Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src -I/home/carol/�rea
> >> de Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src conftest.c >&5
> >> gcc: de: No such file or directory
> >> gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include: No such file
> >> or directory
> >> or directory
> >> gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src: No such file
> >> or directory
> >> or directory
> >> Notice your mpich2 source is located in "/home/carol/�rea de
> >> Trabalho/Mocassin/mpich2-1.4.1p1/"
> >> which contains blank character. Many unix tools including autoconf
> >> cannot handle blanks in
> >> pathname well, so move mpich2 source tree to a directory whose
> >> pathname does NOT contain any
> >> blank or white space characters. The same for the build and install
> >> directories.
> >> A.Chan
> >>> Hello,
> >>> I'm trying to install mpich2-1.4.1p1 in my computer and it's not
> >>> working.
> >>> The following message appear:
> >>> "configure: error: **** Incompatible Fortran and C Object File
> >>> Types!
> >>> F77 Object File Type produced by "gfortran -O2" is : : ELF 64-bit
> >>> LSB
> >>> relocatable, x86-64, version 1 (SYSV), not stripped.
> >>> C Object File Type produced by "gcc " is : : ERROR: cannot open `'
> >>> (No
> >>> such file or directory)."
> >>> I have gfortran and gcc installed in my computer.
> >>> I tried to use ./configure --disable-f77, because I don't require
> >>> support
> >>> for Fortran 77, just for Fortran 90, but it didn't work either:
> >>> "Fortran 90 support requires compatible Fortran 77 support.
> >>> To force the use of the Fortran 90 compiler for Fortran 77,
> >>> do not use configure option --disable-f77, and set the environment
> >>> variable F77 to the name of the Fortran 90 compiler, or $FC.
> >>> If you do not want any Fortran support, use configure options
> >>> --disable-f77 and --disable-fc."
> >>> Can you help me? I don't know what to do, and I need this very
> >>> quickly.
> >>> Thank you for your attencion,
> >>> Carolina Moura.
> >>> _______________________________________________
> >>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> >>> To manage subscription options or unsubscribe:
> >>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
