[mpich-discuss] mpich-1.4.1p1
    Reuti
    reuti at staff.uni-marburg.de
    Wed Sep 21 14:45:14 CDT 2011
Am 21.09.2011 um 21:10 schrieb Gus Correa:
> Anthony:
> How about non-ascii characters? e.g. Ã (A with an accent)
about this I wondered too. Also in respect to a linked in RPATH or RUNPATH in the final application which one can check with `readelf -d program`. Does the ability to execute the application then depend on the setting of the locale?
> Are they OK in Linux directory and file names?
> Do they require some specific locale setting, UTF-8 character set,
> or other?
> Does autoconf digest them right?
> Carolina:
> I'd stay on the safe side and stick to very conventional
> file and directory names made only of:
> 1)  upper and lower case letters [a to z, and A to Z, without any accents, be careful with your Brazilian ABNT/ABNT-2 keyboard!],
> 2) digits [0 to 9],
> 3) underscore (_) [e.g. my_file], and
3a) a dash and plus (-+) if it's not the first character. My users in computational chemistry use them quite often without known issues.
> 4) period (.) [e.g. my_program.f90]
> And use the slash (/) *only* for directory name separator.
> No blanks of course [which is a Windows thing].
5) No colon : on a Mac in a terminal. It will show up in the GUI as slash. Despite working it's confusing. Origin is that the colon was (is) the directory separator in HFS (Hierarchical File System) used there and translates from the GUI ":" to a terminal "/" and is rejected because of this in the opposite way.
6) Default on a Mac is not to distinguish between upper and lower case, even in a terminal. Unless you format the partion in a different way to honor it or as Unix FS.
--Reuti
> My two cents,
> Gus Correa
> Anthony Chan wrote:
>> Carolina,
>> Here are lines that in config.log shows the problem:
>> configure:11770: gcc -c      -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src -I/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src conftest.c >&5
>> gcc: de: No such file or directory
>> gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/mpl/include: No such file or directory
>> gcc: Trabalho/Mocassin/mpich2-1.4.1p1/src/openpa/src: No such file or directory
>> Notice your mpich2 source is located in "/home/carol/Ãrea de Trabalho/Mocassin/mpich2-1.4.1p1/"
>> which contains blank character.  Many unix tools including autoconf cannot handle blanks in
>> pathname well, so move mpich2 source tree to a directory whose pathname does NOT contain any
>> blank or white space characters.  The same for the build and install directories.
>> A.Chan
>> ----- Original Message -----
>>> Hello,
>>> I'm trying to install mpich2-1.4.1p1 in my computer and it's not
>>> working.
>>> The following message appear:
>>> "configure: error: **** Incompatible Fortran and C Object File Types!
>>> F77 Object File Type produced by "gfortran -O2" is : : ELF 64-bit LSB
>>> relocatable, x86-64, version 1 (SYSV), not stripped.
>>> C Object File Type produced by "gcc " is : : ERROR: cannot open `' (No
>>> such file or directory)."
>>> I have gfortran and gcc installed in my computer.
>>> I tried to use ./configure --disable-f77, because I don't require
>>> support
>>> for Fortran 77, just for Fortran 90, but it didn't work either:
>>> "Fortran 90 support requires compatible Fortran 77 support.
>>> To force the use of the Fortran 90 compiler for Fortran 77,
>>> do not use configure option --disable-f77, and set the environment
>>> variable F77 to the name of the Fortran 90 compiler, or $FC.
>>> If you do not want any Fortran support, use configure options
>>> --disable-f77 and --disable-fc."
>>> Can you help me? I don't know what to do, and I need this very
>>> quickly.
>>> Thank you for your attencion,
>>> Carolina Moura.
>>> _______________________________________________
>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
