[mpich-discuss] [mvapich-discuss] Announcing the Release of MVAPICH2 1.7RC2 and OSU Micro-Benchmarks (OMB) 3.4 (fwd)
    Dhabaleswar Panda
    panda at cse.ohio-state.edu
    Mon Sep 19 21:46:37 CDT 2011
These releases might be of interest to some of the MPICH2 users. Thus, I
am posting it here.
DK
---------- Forwarded message ----------
Date: Mon, 19 Sep 2011 20:16:12 -0400 (EDT)
From: Dhabaleswar Panda <panda at cse.ohio-state.edu>
To: mvapich-discuss at cse.ohio-state.edu
Cc: Dhabaleswar Panda <panda at cse.ohio-state.edu>
Subject: [mvapich-discuss] Announcing the Release of MVAPICH2 1.7RC2 and
The MVAPICH team is pleased to announce the release of MVAPICH2-1.7RC2
and OSU Micro-Benchmarks (OMB) 3.4.
Features, Enhancements, and Bug Fixes for MVAPICH2 1.7RC2 (since
MVAPICH2-1.7RC1 release) are listed here.
* NEW Features and Enhancements
    - Based on MPICH2-1.4.1p1
    - Integrated Hybrid (UD-RC/XRC) design to get best performance
      on large-scale systems with reduced/constant memory footprint
    - Shared memory backed Windows for One-Sided Communication
    - Support for truly passive locking for intra-node RMA in shared
      memory and LIMIC based windows
    - Integrated with Portable Hardware Locality (hwloc v1.2.1)
    - Integrated with latest OSU Micro-benchmarks (3.4)
    - Enhancements and tuned collectives (Allreduce and Allgatherv)
    - MPI_THREAD_SINGLE provided by default and
      MPI_THREAD_MULTIPLE as an option
    - Enabling Checkpoint/Restart support in pure SMP mode
    - Optimization for QDR cards
    - On-demand connection management support with IB CM (RoCE interface)
    - Optimization to limit number of RDMA Fast Path connections
      for very large clusters (Nemesis interface)
    - Multi-core-aware collective support (QLogic PSM interface)
Bug Fixes:
    - Fixes for code compilation warnings
    - Compiler preference lists reordered to avoid mixing GCC and Intel
      compilers if both are found by configure
    - Fix a bug in transferring very large messages (>2GB)
       - Thanks to Tibor Pausz from Univ. of Frankfurt for reporting it
    - Fix a hang with One-Sided Put operation
    - Fix a bug in ptmalloc integration
    - Avoid double-free crash with mpispawn
    - Avoid crash and print an error message in mpirun_rsh when the
      hostfile is empty
    - Checking for error codes in PMI design
    - Verify programs can link with LiMIC2 at runtime
    - Fix for compilation issue when BLCR or FTB installed in
      non-system paths
    - Fix an issue with RDMA-Migration
    - Fix for memory leaks
    - Fix an issue in supporting RoCE with second port on available on HCA
        - Thanks to Jeffrey Konz from HP for reporting it
    - Fix for a hang with passive RMA tests (QLogic PSM interface)
The complete set of Features, Enhancements, and Bug Fixes for MVAPICH2
1.7RC2 (since MVAPICH2-1.6 release) are listed here.
    - CH3 shared memory channel for standalone hosts
      (including laptops) without any InfiniBand adapters
    - HugePage support
    - Improved intra-node shared memory communication performance
    - Improved on-demand InfiniBand connection setup (CH3 and RoCE)
    - Tuned RDMA Fast Path Buffer size to get better performance
      with less memory footprint (CH3 and Nemesis)
    - Supporting large data transfers (>2GB)
    - Integrated with enhanced LiMIC2 (v0.5.5) to support Intra-node
      large message (>2GB) transfers
    - Optimized Fence synchronization (with and without
      LIMIC2 support)
    - Automatic intra-node communication parameter tuning
      based on platform
    - Efficient connection set-up for multi-core systems
    - Enhanced designs and tuning for collectives
      (bcast, reduce, barrier, gather, allreduce, allgather,
      allgatherv and alltoall)
    - Fast process migration using RDMA
    - Compact and shorthand way to specify blocks of processes
      on the same host with mpirun_rsh
    - Support for latest stable version of HWLOC v1.2.1
    - Enhanced mpirun_rsh design to avoid race conditions,
      support for fault-tolerance functionality and
      improved debug messages
    - Enhanced debugging config options to generate
      core files and back-traces
    - Automatic inter-node communication parameter tuning
      based on platform and adapter detection (Nemesis)
    - Improved performance for medium sized messages (QLogic PSM interface)
    - Support for Chelsio T4 Adapter
    - Support for Ekopath Compiler
Bug Fixes:
    - Fixes in Checkpoint/Restart and Migration support
    - Fix Restart when using automatic checkpoint
          - Thanks to Alexandr for reporting this
    - Handling very large one-sided transfers using RDMA
    - Fixes for memory leaks
    - Graceful handling of unknown HCAs
    - Better handling of shmem file creation errors
    - Fix for a hang in intra-node transfer
    - Fix for a build error with --disable-weak-symbols
          - Thanks to Peter Willis for reporting this issue
    - Fixes for one-sided communication with passive target
      synchronization
    - Better handling of memory allocation and registration failures
    - Fixes for compilation warnings
    - Fix a bug that disallows '=' from mpirun_rsh arguments
    - Handling of non-contiguous transfer in Nemesis interface
    - Bug fix in gather collective when ranks are in cyclic order
    - Fix for the ignore_locks bug in MPI-IO with Lustre
      hostfile is empty
      non-system paths
New features, Enhancements and Bug Fixes of OSU Micro-Benchmarks (OMB)
3.4 (since OMB 3.3 release) are listed here.
New Features & Enhancements
    - Add passive one-sided communication benchmarks
    - Update one-sided communication benchmarks to provide shared
      memory hint in MPI_Alloc_mem calls
    - Update one-sided communication benchmarks to use MPI_Alloc_mem
      for buffer allocation
    - Give default values to configure definitions (can now build
      directly with mpicc)
    - Update latency benchmarks to begin from 0 byte message
* Bug Fixes
    - Remove memory leaks in one-sided communication benchmarks
    - Update benchmarks to touch buffers before using them for
      communication
    - Fix osu_get_bw test to use different buffers for concurrent
      communication operations
    - Fix compilation warnings
For downloading MVAPICH2-1.7RC2, OSU Micro-Benchmarks (OMB) 3.4,
associated user guide and accessing the SVN, please visit the
following URL:
http://mvapich.cse.ohio-state.edu
All questions, feedbacks, bug reports, hints for performance tuning,
patches and enhancements are welcome. Please post it to the
mvapich-discuss mailing list (mvapich-discuss at cse.ohio-state.edu).
We are also happy to inform that the number of organizations using
MVAPICH/MVAPICH2 (and registered at the MVAPICH site) has crossed
1,700 world-wide (in 63 countries). The MVAPICH team extends thanks to
all these organizations.
The MVAPICH Team
http://mail.cse.ohio-state.edu/mailman/listinfo/mvapich-discuss
