[mpich-discuss] LAMMPS execution on Windows 7 no SP1 using MPICH 2.0-1.4.1p1 for windows
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Sep 14 10:15:33 CDT 2011
To create an administrator command prompt Right-click on the command prompt icon and select "Run as administrator" (It is NOT enough to open a command prompt as an administrator to get an administrator command prompt).
Try running your job from the administrator command prompt and let us know if it works.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Tuesday, September 13, 2011 11:52:57 PM
Subject: Re: [mpich-discuss] LAMMPS execution on Windows 7 no SP1 using MPICH 2.0-1.4.1p1 for windows
Here is the results for a user that is in the administrators group:
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\mike>cd winlaamps
The system cannot find the path specified.
C:\Users\mike>cd ..
C:\Users>cd ..
C:\>cd winlaamps
C:\winlaamps>mpiexec -np 4 -localonly c:\winlaamps\lmp6 < in.water5
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\6240 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\3572 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7056 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7060 registry key, error 5, Access is denied.
C:\winlaamps>mpiexec -np 4 -localonly c:\winlaamps\cpi.exe
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\5784 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\6316 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\2656 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\5096 registry key, error 5, Access is denied.
Enter the number of intervals: (0 quits) 1
pi is approximately 3.2000000000000002, Error is 0.0584073464102071
wall clock time = 0.001515
wall clock time = 0.000037
wall clock time = 0.000034
wall clock time = 0.000035
wall clock time = 0.000036
Enter the number of intervals: (0 quits) 0
C:\winlaamps>0
'0' is not recognized as an internal or external command,
operable program or batch file.
C:\winlaamps>0
Here is the same test running in a command shell that belongs to the administrator:
C:\Windows\system32>cd ..
C:\Windows>cd ..
C:\>cd winlaamps
wall clock time = 0.000077
wall clock time = 0.000033
wall clock time = 0.000072
wall clock time = 0.000032
C:\winlaamps>
Nice! No access issues!!!
I get the following from running LAMMPS:
The application is unable to start correctly (0xc000007b). Click OK to close the application. I'm guessing this error is coming from LAMMPS and is related to how it's calling MPICH?
Thanks for the help on the access issue.
Cc: claudevms at comcast.net
Sent: Tuesday, September 13, 2011 7:54:02 AM
>> MPICH2 not installed or unable to query host ...
This is due to a bug in wmpi* wrapper programs. This does not indicate a faulty installation. Try running "mpiexec -n 2 c:\Progra~1\MPICH2\examples\cpi.exe" and see if it works.
>> Unable to open the ...
Try running the command from an administrator command prompt (Right-click on command prompt icon and select "Run as administrator".)
Let us know if it works.
Jayesh
Sent: Monday, September 12, 2011 11:39:58 PM
Subject: [mpich-discuss] LAMMPS execution on Windows 7 no SP1 using MPICH 2.0-1.4.1p1 for windows
I can see smpd running as a service. smpd responds to start and stop commands.
MPICH2 Configurable Settings reports
"spike: MPICH2 not installed or unable to query host"
I used the wmpiregister.exe to associate "behappy" with my mike account. I copied the mpich2mpidll to the winlaamps directory along with the
mpiexec.exe.
I turned off the windows firewall and disabled it. I turned off the Norton firewall and it is disabled as well.
The lmp6.exe is a LAMMPS EXE file copied directly from the LAMMPS site.
I was hoping to get LAMMPS to run quicker (divide and conquer)in a multicore environment.
Thanks in advance for any insight!
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
