[mpich-discuss] Process Managers
    Reuti
    reuti at staff.uni-marburg.de
    Mon Sep 12 05:38:47 CDT 2011
Am 12.09.2011 um 11:23 schrieb kaz_wada_JCOM:
> Thank you very much for your comments.
> I am very new regarding mpich, and I have no idea to recover the missing in my installing.
> What should I do for "openssl-debvelopment"?
Sorry, it's a typo and should read  "openssl-development" and depends on the distribution you use. Often packages are split into the plain libraries containing the *.so files so that any compiled application can use it, and a package called *-development or alike which contains *.a and *.h files in case you want to compile applications on your own using this library.
As you want to use the *.h files, you will need to install the development package of openssl.
-- Reuti
> By the way, is the hydra installed automatically?
> Wada
>> Hi,
>> Am 12.09.2011 um 10:28 schrieb kaz_wada_JCOM:
>>> In order to configure process managers, hydra and SMPD, I got the attached errors, and the process was stoped.
>>> Shell I entered was as follows:
>>> cd /tmp/wadakazusige/mpich2-1.4.1p1
>>> /home/wadakazusige/libraries/mpich2-1.4.1p1/configure CC=gcc --disable-f77 --disable-fc --with-pm=hydra --with-pmi=hydra --with-pm=smpd   --with-pmi=smpd --build=i686-pc-cygwin --prefix=/home/wadakazusige/mpich2-install 2>&1 | tee c.txt
>>> Am I missing something or misunderstanding?
>> is there any reason that you still want smpd besides Hydra?
>> Nevertheless, the error message states clearly what is missing in your installation. Sometimes it's called "openssl-debvelopment" or alike in the package repository.
>> -- Reuti
>>> Kazuzhige Wada
>>> <c.txt>_______________________________________________
>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
