[mpich-discuss] Process Managers
    Pavan Balaji
    balaji at mcs.anl.gov
    Mon Sep 12 04:32:59 CDT 2011
SMPD and Hydra use different PMI wire protocols, so they are not
compatible -- you cannot build MPICH2 to simultaneously support both.
Hydra is built by default and is the recommended process manager.
SMPD is not recommended unless you are using Windows.
  -- Pavan
On 09/12/2011 04:23 AM, kaz_wada_JCOM wrote:
> Thank you very much for your comments.
> I am very new regarding mpich, and I have no idea to recover the missing in
> my installing.
> What should I do for "openssl-debvelopment"?
> By the way, is the hydra installed automatically?
> Wada
>> Hi,
>> Am 12.09.2011 um 10:28 schrieb kaz_wada_JCOM:
>>> In order to configure process managers, hydra and SMPD, I got the
>>> attached errors, and the process was stoped.
>>> Shell I entered was as follows:
>>>   cd /tmp/wadakazusige/mpich2-1.4.1p1
>>>   /home/wadakazusige/libraries/mpich2-1.4.1p1/configure
>>> CC=gcc --disable-f77 --disable-fc --with-pm=hydra --with-pmi=hydra --with-pm=smpd
>>>    --with-pmi=smpd --build=i686-pc-cygwin --prefix=/home/wadakazusige/mpich2-install
>>> 2>&1 | tee c.txt
>>> Am I missing something or misunderstanding?
>> is there any reason that you still want smpd besides Hydra?
>> Nevertheless, the error message states clearly what is missing in your
>> installation. Sometimes it's called "openssl-debvelopment" or alike in the
>> package repository.
>> -- Reuti
>>> Kazuzhige Wada
>>> <c.txt>_______________________________________________
>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
