[mpich-discuss] [mpich2-dev] In direct memory block for handle type REQUEST, 8 handles are still allocated
Pavan Balaji balaji at mcs.anl.gov
Tue Sep 6 06:40:08 CDT 2011
[Dropping mpich2-dev from the cc list, as this is a user question, not a
developer question].
It sounds like your program is not freeing some MPI request that it created.
  -- Pavan
On 09/06/2011 06:32 AM, Hisham Adel wrote:
> Hi,
> On Ubuntu 11.04 with gcc 4.5.2., I use mpich2-1.4.1p1 with this
> configuration options:
> ~/mpich2-1.4/configure --enable-error-messages=all --enable-g=all
> --enable-shared --enable-sharedlibs=gcc --without-mpe
> --with-pm=hydra:mpd --disable-f77 --disable-fc
> After the program terminates, I receive a message related to the memory,
> When I use MPI_Send.
> For example: The message bellow appears when I use 3 MPI_Send.
> The first and second MPI_Send are used to send two separate integers.
> The third one is used to send a special data structure created by me.
> At the end node, the received data are printed out well.
> How can I fix it ?
> I would be grateful if you can help me.
> Regards,
> Hisham
> allocated
> In indirect memory block 0 for handle type REQUEST, 16 handles are still
> allocated
> [3] 1624 at [0x08930c98],
> 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
> [3] 8 at [0x08930bf0], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 8 at [0x08930b48], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 1624 at [0x08930450],
> [3] 8 at [0x089303a8], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 8 at [0x08930300], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 1624 at [0x0892fc08],
> [3] 8 at [0x0892fb60], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 8 at [0x0892fab8], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 1624 at [0x0892f3c0],
> [3] 8 at [0x0892f318], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 8 at [0x0892f270], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 1624 at [0x0892eb78],
> [3] 8 at [0x0892ead0], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 8 at [0x0892ea28], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 1624 at [0x0892e330],
> [3] 8 at [0x0890f948], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 8 at [0x0890f8a0], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 1624 at [0x0890f1a8],
> [3] 8 at [0x0890f100], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 8 at [0x0890f058], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 1624 at [0x0890e960],
> [3] 8 at [0x0890e8b8], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
> [3] 8 at [0x0890e810], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
Pavan Balaji
http://www.mcs.anl.gov/~balaji
