[mpich-discuss] In direct memory block for handle type REQUEST, 8 handles are still allocated
Hisham Adel hosham2004 at yahoo.com
Tue Sep 6 06:32:50 CDT 2011
On Ubuntu 11.04 with gcc 4.5.2., I use mpich2-1.4.1p1 with this configuration options:
~/mpich2-1.4/configure --enable-error-messages=all --enable-g=all --enable-shared --enable-sharedlibs=gcc --without-mpe --with-pm=hydra:mpd --disable-f77 --disable-fc
After the program terminates, I receive a message related to the memory, When I use MPI_Send.
For example: The message bellow appears when I use 3 MPI_Send.
The first and second MPI_Send are used to send two separate integers.
The third one is used to send a special data structure created by me.
At the end node, the received data are printed out well.
How can I fix it ?
I would be grateful if you can help me.
Hisham
In indirect memory block 0 for handle type REQUEST, 16 handles are still allocated
[3] 1624 at [0x08930c98], 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
[3] 8 at [0x08930bf0], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 8 at [0x08930b48], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 1624 at [0x08930450], 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
[3] 8 at [0x089303a8], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 8 at [0x08930300], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 1624 at [0x0892fc08], 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
[3] 8 at [0x0892fb60], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 8 at [0x0892fab8], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 1624 at [0x0892f3c0], 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
[3] 8 at [0x0892f318], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 8 at [0x0892f270], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 1624 at [0x0892eb78], 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
[3] 8 at [0x0892ead0], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 8 at [0x0892ea28], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 1624 at [0x0892e330], 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
[3] 8 at [0x0890f948], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 8 at [0x0890f8a0], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 1624 at [0x0890f1a8], 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
[3] 8 at [0x0890f100], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 8 at [0x0890f058], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 1624 at [0x0890e960], 1.4.1p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c[248]
[3] 8 at [0x0890e8b8], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
[3] 8 at [0x0890e810], am/mpich2-1.4.1p1/src/mpid/ch3/src/ch3u_eager.c[439]
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110906/04190b92/attachment.htm>
