[mpich-discuss] Error while Building MPICH2 (Step 6 of installation)
Zalia Shams
zalia18 at cs.vt.edu
Mon Sep 5 15:48:25 CDT 2011
Dear Nicolas,
Sure, I will retry. Seems like it is failing to find fortan compiler at step
5!
Thanks so much for your quick response :).
Zalia
On Mon, Sep 5, 2011 at 4:19 PM, Nicolas Rosner <nrosner at gmail.com> wrote:
> Dear Zalia,
> > After configuring according to step 5, I tried to Build MPICH2
> Are you sure configuration finished successfully?
> > make 2>&1 | tee m.txt
> > But it showed the following error
> > make: *** No targets specified and no makefile found. Stop.
> Running ./configure generates the makefiles that make can't find. The
> simplest explanation would be that something failed on the previous
> step. Unfortunately, the c.txt file you attached contains the same as
> your your m.txt file (the output from step 5 seems to have been
> clobbered by that of step 6). Care to retry?
> Cheers,
> Nicolás
Zalia Shams
Graduate Student
Department of Computer Science
Virginia Tech
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110905/7390729a/attachment.htm>
