[mpich-discuss] Error while Building MPICH2 (Step 6 of	installation)
    Nicolas Rosner
    nrosner at gmail.com
    Mon Sep  5 15:19:37 CDT 2011
Dear Zalia,
> After configuring according to step 5, I tried to Build MPICH2
Are you sure configuration finished successfully?
> make 2>&1 | tee m.txt
> But it showed the following error
> make: *** No targets specified and no makefile found.  Stop.
Running ./configure generates the makefiles that make can't find. The
simplest explanation would be that something failed on the previous
step. Unfortunately, the c.txt file you attached contains the same as
your your m.txt file (the output from step 5 seems to have been
clobbered by that of step 6). Care to retry?
Cheers,
Nicolás
