[mpich-discuss] linking MPI
    Gus Correa
    gus at ldeo.columbia.edu
    Mon Oct 24 16:19:45 CDT 2011
Hi Carolina
The compiler wrapper is called mpif90, not mpichf90,
this is why 'which' cannot find it.
If you change FC to /full/path/to/mpich2/bin/mpif90 in your
makefile, it should be easier to compile.
I hope this helps,
Gus Correa
Carolina Carneiro wrote:
> Hi guys,
> I think the path to install directory was wrong, what's strange since I
> did exactly what the mpich's read me said. Now I got this error:
> root at carol-HP-Pavilion-dv5-Notebook-PC:/home/carol/mocassin/mocassin.2.02.69#
> make mocassin
> /home/carol/mocassin/mpich2-1.4.1p1/bin/mpif90 -O5 -o mocassin
> source/infnan.f90 source/constants_mod.f90 source/vector_mod.f90
> source/common_mod.f90 source/interpolation_mod.f90
> source/set_input_mod.f90 source/hydro_mod.f90 source/ph_mod.f90
> source/composition_mod.f90 source/continuum_mod.f90
> source/ionization_mod.f90 source/pathIntegration_mod.f90
> source/grid_mod.f90 source/dust_mod.f90 source/emission_mod.f90
> source/photon_mod.f90 source/update_mod.f90 source/output_mod.f90
> source/iteration_mod.f90 source/mocassin.f90
> -l/home/carol/mocassin/mpich2-1.4.1p1/src/include
> source/common_mod.f90(240): warning #6379: The structure contains one or
> more misaligned fields.   [GRID_TYPE]
>     type grid_type             ! derived grid type
> source/emission_mod.f90(3109): remark #8291: Recommended relationship
> between field width 'W' and the number of fractional digits 'D' in this
> edit descriptor is 'W>=D+7'.
> read(unit=19,fmt='(A2,I2,1x,A23,11x,A7,1x,F9.4,7x,F9.6,4x,F12.6,1x,I2,1x,I2,1x,E8.2,1x,E8.2,1x,I2)',
> source/iteration_mod.f90(544): warning #8093: A do-variable within a DO
> body shall not appear in a variable definition context.   [GPLOC]
>                                      & gpLoc=gpLoc, cellLoc=cellLoc)
> source/iteration_mod.f90(547): warning #8093: A do-variable within a DO
> ld: cannot find
> -lroot at carol-HP-Pavilion-dv5-Notebook-PC:/home/carol/mocassin/mocassin.2.02.69#
> make mocassin
> ld: cannot find -l/home/carol/mocassin/mpich2-1.4.1p1/src/include
> ld: cannot find -lmpichf90
> make: *** [mocassin] Error 1
> the directory path /home/carol/mocassin/mpich2-1.4.1p1/src/include is
> right, but this file mpichf90 I can't find. When I try "locate mpichf90"
> nothing happens.
> Carolina.
> 2011/10/24 Gus Correa <gus at ldeo.columbia.edu <mailto:gus at ldeo.columbia.edu>>
>     HI Carolina
>     It is easier to use the MPI compiler wrapper than the
>     bare compiler, because the wrapper knows the MPI libraries it needs,
>     the MPI include files it needs, and where to find them.
>     I.e. try to change the F90 macro in the makefile to
>     F90=/your/path/to/mpich2/bin/__mpif90
>     My two cents,
>     Gus Correa
>         Hi,
>         I'm having problems to use the command make to compile a
>         makefile. I'm trying to link the makefile to the MPI library,
>         but it isn't working. Several errors are appearing:
>         root at carol-HP-Pavilion-dv5-__Notebook-PC:/home/carol/__mocassin/mocassin.2.02.69#
>         make mocassin
>         /opt/intel/composer_xe_2011___sp1.6.233/composer_xe_2011___sp1.6.233/bin/intel64/ifort
>         -O5 -o mocassin source/infnan.f90 source/constants_mod.f90
>         source/vector_mod.f90 source/common_mod.f90
>         source/interpolation_mod.f90 source/set_input_mod.f90
>         source/output_mod.f90 source/iteration_mod.f90
>         source/mocassin.f90  -l/home/carol/mocassin/__mpich2install/include
>         contains one or more misaligned fields.   [GRID_TYPE]
>         source/grid_mod.f90(491): error #5102: Cannot open include file
>         'mpif.h'
>                include 'mpif.h'
>         compilation aborted for source/grid_mod.f90 (code 1)
>         source/dust_mod.f90(17): error #5102: Cannot open include file
>         'mpif.h'
>              include 'mpif.h'
>         source/dust_mod.f90(97): error #6404: This name does not have a
>         type, and must have an explicit type.   [MPI_REAL]
>         &                             mpi_real, mpi_sum, mpi_comm_world,
>         ierr)
>         ------------------------------__^
>         type, and must have an explicit type.   [MPI_SUM]
>         ierr)
>         ------------------------------__----------^
>         type, and must have an explicit type.   [MPI_COMM_WORLD]
>         ierr)
>         ------------------------------__-------------------^
>         compilation aborted for source/dust_mod.f90 (code 1)
>         source/emission_mod.f90(8): error #7013: This module file was
>         not generated by any release of this compiler.   [GRID_MOD]
>            use grid_mod
>         source/emission_mod.f90(217): error #6404: This name does not
>         have a type, and must have an explicit type.   [GETVOLUME]
>                dV = getVolume(grid,ix,iy,iz)
>         source/emission_mod.f90(536): error #6404: This name does not
>         have a type, and must have an explicit type.   [HLEVXSECP]
>                    phXSecHI =  xSecArray(i-HIPnuP+1+__HlevXSecP(1)-1)
>         ------------------------------__---------------^
>         source/emission_mod.f90(545): error #6404: This name does not
>         have a type, and must have an explicit type.   [HEISINGXSECP]
>                        phXSecHeI =
>         xSecArray(i-HeIPnuP+1+__HeISingXSecP(1)-1)
>         ------------------------------__--------------------^
>         source/emission_mod.f90(553): error #6404: This name does not
>         have a type, and must have an explicit type.   [HEIIXSECP]
>                            phXSecHeII =
>         xSecArray(i-HeIIPnuP+1+__HeIIXSecP(1)-1)
>         ------------------------------__--------------------------^
>         relationship between field width 'W' and the number of
>         fractional digits 'D' in this edit descriptor is 'W>=D+7'.
>         read(unit=19,fmt='(A2,I2,1x,__A23,11x,A7,1x,F9.4,7x,F9.6,4x,__F12.6,1x,I2,1x,I2,1x,E8.2,1x,__E8.2,1x,I2)',
>         ------------------------------__------------------------------__-----------------------------^
>         ------------------------------__------------------------------__------------------------------__-------^
>         compilation aborted for source/emission_mod.f90 (code 1)
>         source/photon_mod.f90(9): error #7013: This module file was not
>            use grid_mod
>         compilation aborted for source/photon_mod.f90 (code 1)
>         source/update_mod.f90(8): error #7013: This module file was not
>         generated by any release of this compiler.   [EMISSION_MOD]
>            use emission_mod
>         source/update_mod.f90(234): error #6404: This name does not have
>                             phXSec  = xSecArray(j-IPnuP+1+HlevXSecP(__1)-1)
>         ------------------------------__---------------------^
>         source/update_mod.f90(238): error #6404: This name does not have
>                             phXSec  =
>         xSecArray(j-IPnuP+1+__HeISingXSecP(1)-1)
>         source/update_mod.f90(242): error #6404: This name does not have
>                             phXSec  = xSecArray(j-IPnuP+1+HeIIXSecP(__1)-1)
>         source/update_mod.f90(1304): error #6632: Keyword arguments are
>         invalid without an explicit interface.   [FILE_NAME]
>                                 call
>         equilibrium(file_name=__dataFile(elem, ion), &
>         ------------------------------__------------^
>         source/update_mod.f90(1305): error #6632: Keyword arguments are
>         invalid without an explicit interface.   [IONDENUP]
>          &ionDenUp=ionDenUsed(__elementXref(elem),ion+1)/&
>         ------------------------------__-^
>         source/update_mod.f90(1306): error #6632: Keyword arguments are
>         invalid without an explicit interface.   [TE]
>          &ionDenUsed(elementXref(elem),__ion), Te=TeUsed,&
>         ------------------------------__------------------------------__------^
>         source/update_mod.f90(1307): error #6632: Keyword arguments are
>         invalid without an explicit interface.   [NE]
>                                      &Ne=NeUsed,
>         FlineEm=forbiddenLinesLarge(&
>         invalid without an explicit interface.   [FLINEEM]
>                                      &Ne=NeUsed,
>         source/update_mod.f90(1310): error #6632: Keyword arguments are
>                                 call
>         source/update_mod.f90(1311): error #6632: Keyword arguments are
>                                      &ionDenUp=0., Te=TeUsed,&
>         ------------------------------__--------------^
>         source/update_mod.f90(1312): error #6632: Keyword arguments are
>                                      &Ne=NeUsed,
>                                      &Ne=NeUsed,
>         source/update_mod.f90(2033): error #6404: This name does not
>         have a type, and must have an explicit type.   [RESLINE]
>                       do imul = 1, resLine(iL)%nmul
>         source/update_mod.f90(2033): error #6837: The leftmost part-ref
>         in a data-ref can not be a function reference.   [RESLINE]
>         source/update_mod.f90(2033): error #6158: The structure-name is
>         invalid or is missing.   [RESLINE]
>         source/update_mod.f90(2034): error #6837: The leftmost part-ref
>                          if (resLine(iL)%elem==1) then
>         source/update_mod.f90(2034): error #6158: The structure-name is
>         source/update_mod.f90(2034): internal error: Please visit
>         'http://www.intel.com/__software/products/support
>         <http://www.intel.com/software/products/support>' for assistance.
>         [ Aborting due to internal error. ]
>         compilation aborted for source/update_mod.f90 (code 1)
>         source/output_mod.f90(6): error #7013: This module file was not
>            use emission_mod
>         source/output_mod.f90(342): error #6404: This name does not have
>         a type, and must have an explicit type.   [LOG10TE]
>                               log10Te         = log10(TeUsed)
>         source/output_mod.f90(343): error #6404: This name does not have
>         a type, and must have an explicit type.   [LOG10NE]
>                               log10Ne         = log10(NeUsed)
>         source/output_mod.f90(344): error #6404: This name does not have
>         a type, and must have an explicit type.   [SQRTEUSED]
>                               sqrTeUsed = sqrt(TeUsed)
>         source/output_mod.f90(370): error #6410: This name has not been
>         declared as an array or a function.   [HIRECLINES]
>                                        HIRecLines(iup, ilow) = &
>         ------------------------------__--^
>         source/output_mod.f90(370): internal error: Please visit
>         compilation aborted for source/output_mod.f90 (code 1)
>         source/iteration_mod.f90(35): error #5102: Cannot open include
>         file 'mpif.h'
>                   include 'mpif.h'
>         source/iteration_mod.f90(7): error #7013: This module file was
>         not generated by any release of this compiler.   [EMISSION_MOD]
>            use emission_mod
>         source/iteration_mod.f90(103): error #6404: This name does not
>         have a type, and must have an explicit type.   [BJUMPTEMP]
>                         BjumpTemp = 0.
>         source/iteration_mod.f90(153): error #6404: This name does not
>         have a type, and must have an explicit type.   [MPI_REAL]
>                              & mpi_real, mpi_sum, mpi_comm_world, ierr)
>         have a type, and must have an explicit type.   [MPI_SUM]
>         ------------------------------__----^
>         have a type, and must have an explicit type.   [MPI_COMM_WORLD]
>         ------------------------------__-------------^
>         source/iteration_mod.f90(477): error #6404: This name does not
>         have a type, and must have an explicit type.   [TOTALESCAPED]
>                   totalEscaped = 0.
>         source/iteration_mod.f90(543): error #6632: Keyword arguments
>         are invalid without an explicit interface.   [ISTAR]
>                                        call
>         energyPacketDriver(iStar=0,n=__load, grid=grid(1:nGrids), &
>         are invalid without an explicit interface.   [N]
>                                        call
>         ------------------------------__------------------------------__----^
>         are invalid without an explicit interface.   [GRID]
>                                        call
>         ------------------------------__------------------------------__------------^
>         source/iteration_mod.f90(544): error #6632: Keyword arguments
>         are invalid without an explicit interface.   [GPLOC]
>         ------------------------------__---------^
>         are invalid without an explicit interface.   [CELLLOC]
>         ------------------------------__----------------------^
>         source/iteration_mod.f90(546): error #6632: Keyword arguments
>                                        call
>                                        call
>                                        call
>         source/iteration_mod.f90(547): error #6632: Keyword arguments
>         source/iteration_mod.f90(574): error #6404: This name does not
>         have a type, and must have an explicit type.   [MPI_INTEGER]
>                           & mpi_integer, mpi_sum, mpi_comm_world, ierr)
>         compilation aborted for source/iteration_mod.f90 (code 1)
>         source/mocassin.f90(43): error #5102: Cannot open include file
>         'mpif.h'
>            include 'mpif.h'
>         source/mocassin.f90(34): error #7002: Error in opening the
>         compiled module file.  Check INCLUDE paths.   [DUST_MOD]
>            use dust_mod
>         source/mocassin.f90(35): error #7013: This module file was not
>            use grid_mod
>         source/mocassin.f90(55): error #6404: This name does not have a
>            call mpi_comm_rank(MPI_COMM_WORLD, taskid, ierr)
>         compilation aborted for source/mocassin.f90 (code 1)
>         The makefile is this:
>         source1  = source/infnan.f90 source/constants_mod.f90
>         source/interpolation_mod.f90 \
>         source/ph_mod.f90 source/composition_mod.f90 \
>            source/continuum_mod.f90 source/ionization_mod.f90
>         source/pathIntegration_mod.f90 \
>         source/emission_mod.f90 source/photon_mod.f90  \
>            source/update_mod.f90 \
>         source/mocassin.f90
>         source2  = source/infnan.f90 source/constants_mod.f90
>         source/mocassinWarm.f90
>         source3  = source/infnan.f90 source/constants_mod.f90
>         source/mocassinOutput.f90
>         source4  = source/infnan.f90 source/constants_mod.f90
>         source/mocassinPlot.f90
>          F90  =
>         LIBS = -l/home/carol/mocassin/__mpich2install/include
>         OPT1 = -O5
>         OPT2 = -O5
>         mocassin:
>            $(F90) $(OPT1) -o mocassin $(source1) $(LIBS)
>         mocassinWarm:
>            $(F90) $(OPT1) -o mocassinWarm $(source2) $(LIBS)
>         mocassinOutput:
>            $(F90) $(OPT2) -o mocassinOutput $(source3) $(LIBS)
>         mocassinPlot:
>            $(F90) $(OPT2) -o mocassinPlot $(source4) $(LIBS)
>         clean:
>            /bin/rm *.o *~ *.mod mocassin mocassinWarm mocassinOutput
>         mocassinPlot
>         Does someone have a clue of what is the problem?
>         Thanks,
>         Carolina.
>         _________________________________________________
>         mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>         <mailto:mpich-discuss at mcs.anl.gov>
>         To manage subscription options or unsubscribe:
>         https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss
>         <https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
