[mpich-discuss] linking MPI
Carolina Carneiro carol07 at astro.ufrj.br
Mon Oct 24 15:41:57 CDT 2011
Hi guys,
I think the path to install directory was wrong, what's strange since I did
exactly what the mpich's read me said. Now I got this error:
root at carol-HP-Pavilion-dv5-Notebook-PC:/home/carol/mocassin/mocassin.2.02.69#
make mocassin
/home/carol/mocassin/mpich2-1.4.1p1/bin/mpif90 -O5 -o mocassin
source/infnan.f90 source/constants_mod.f90 source/vector_mod.f90
source/common_mod.f90 source/interpolation_mod.f90 source/set_input_mod.f90
source/hydro_mod.f90 source/ph_mod.f90 source/composition_mod.f90
source/continuum_mod.f90 source/ionization_mod.f90
source/pathIntegration_mod.f90 source/grid_mod.f90 source/dust_mod.f90
source/emission_mod.f90 source/photon_mod.f90 source/update_mod.f90
source/output_mod.f90 source/iteration_mod.f90 source/mocassin.f90
-l/home/carol/mocassin/mpich2-1.4.1p1/src/include
source/common_mod.f90(240): warning #6379: The structure contains one or
more misaligned fields.   [GRID_TYPE]
    type grid_type             ! derived grid type
source/emission_mod.f90(3109): remark #8291: Recommended relationship
between field width 'W' and the number of fractional digits 'D' in this edit
descriptor is 'W>=D+7'.
read(unit=19,fmt='(A2,I2,1x,A23,11x,A7,1x,F9.4,7x,F9.6,4x,F12.6,1x,I2,1x,I2,1x,E8.2,1x,E8.2,1x,I2)',
source/iteration_mod.f90(544): warning #8093: A do-variable within a DO body
shall not appear in a variable definition context.   [GPLOC]
                                     & gpLoc=gpLoc, cellLoc=cellLoc)
source/iteration_mod.f90(547): warning #8093: A do-variable within a DO body
ld: cannot find
-lroot at carol-HP-Pavilion-dv5-Notebook-PC:/home/carol/mocassin/mocassin.2.02.69#
make mocassin
ld: cannot find -l/home/carol/mocassin/mpich2-1.4.1p1/src/include
ld: cannot find -lmpichf90
make: *** [mocassin] Error 1
the directory path /home/carol/mocassin/mpich2-1.4.1p1/src/include is right,
but this file mpichf90 I can't find. When I try "locate mpichf90" nothing
happens.
Carolina.
2011/10/24 Gus Correa <gus at ldeo.columbia.edu>
> HI Carolina
> It is easier to use the MPI compiler wrapper than the
> bare compiler, because the wrapper knows the MPI libraries it needs,
> the MPI include files it needs, and where to find them.
> I.e. try to change the F90 macro in the makefile to
> F90=/your/path/to/mpich2/bin/**mpif90
> My two cents,
> Gus Correa
> Carolina Carneiro wrote:
>> Hi,
>> I'm having problems to use the command make to compile a makefile. I'm
>> trying to link the makefile to the MPI library, but it isn't working.
>> Several errors are appearing:
>> root at carol-HP-Pavilion-dv5-**Notebook-PC:/home/carol/**mocassin/mocassin.2.02.69#
>> make mocassin
>> /opt/intel/composer_xe_2011_**sp1.6.233/composer_xe_2011_**sp1.6.233/bin/intel64/ifort
>> -O5 -o mocassin source/infnan.f90 source/constants_mod.f90
>> source/vector_mod.f90 source/common_mod.f90 source/interpolation_mod.f90
>> source/set_input_mod.f90 source/hydro_mod.f90 source/ph_mod.f90
>> source/composition_mod.f90 source/continuum_mod.f90
>> source/ionization_mod.f90 source/pathIntegration_mod.f90 source/grid_mod.f90
>> source/dust_mod.f90 source/emission_mod.f90 source/photon_mod.f90
>> source/update_mod.f90 source/output_mod.f90 source/iteration_mod.f90
>> source/mocassin.f90  -l/home/carol/mocassin/**mpich2install/include
>> source/grid_mod.f90(491): error #5102: Cannot open include file 'mpif.h'
>>        include 'mpif.h'
>> compilation aborted for source/grid_mod.f90 (code 1)
>> source/dust_mod.f90(17): error #5102: Cannot open include file 'mpif.h'
>>      include 'mpif.h'
>> source/dust_mod.f90(97): error #6404: This name does not have a type, and
>> must have an explicit type.   [MPI_REAL]
>> &                             mpi_real, mpi_sum, mpi_comm_world, ierr)
>> must have an explicit type.   [MPI_SUM]
>> must have an explicit type.   [MPI_COMM_WORLD]
>> compilation aborted for source/dust_mod.f90 (code 1)
>> source/emission_mod.f90(8): error #7013: This module file was not
>> generated by any release of this compiler.   [GRID_MOD]
>>    use grid_mod
>> source/emission_mod.f90(217): error #6404: This name does not have a type,
>> and must have an explicit type.   [GETVOLUME]
>>        dV = getVolume(grid,ix,iy,iz)
>> source/emission_mod.f90(536): error #6404: This name does not have a type,
>> and must have an explicit type.   [HLEVXSECP]
>>            phXSecHI =  xSecArray(i-HIPnuP+1+**HlevXSecP(1)-1)
>> source/emission_mod.f90(545): error #6404: This name does not have a type,
>> and must have an explicit type.   [HEISINGXSECP]
>>                phXSecHeI = xSecArray(i-HeIPnuP+1+**HeISingXSecP(1)-1)
>> source/emission_mod.f90(553): error #6404: This name does not have a type,
>> and must have an explicit type.   [HEIIXSECP]
>>                    phXSecHeII = xSecArray(i-HeIIPnuP+1+**HeIIXSecP(1)-1)
>>         read(unit=19,fmt='(A2,I2,1x,**A23,11x,A7,1x,F9.4,7x,F9.6,4x,**
>> F12.6,1x,I2,1x,I2,1x,E8.2,1x,**E8.2,1x,I2)', &
>> compilation aborted for source/emission_mod.f90 (code 1)
>> source/photon_mod.f90(9): error #7013: This module file was not generated
>>    use grid_mod
>> compilation aborted for source/photon_mod.f90 (code 1)
>> source/update_mod.f90(8): error #7013: This module file was not generated
>> by any release of this compiler.   [EMISSION_MOD]
>>    use emission_mod
>> source/update_mod.f90(234): error #6404: This name does not have a type,
>>                     phXSec  = xSecArray(j-IPnuP+1+HlevXSecP(**1)-1)
>> source/update_mod.f90(238): error #6404: This name does not have a type,
>>                     phXSec  = xSecArray(j-IPnuP+1+**HeISingXSecP(1)-1)
>> source/update_mod.f90(242): error #6404: This name does not have a type,
>>                     phXSec  = xSecArray(j-IPnuP+1+HeIIXSecP(**1)-1)
>> source/update_mod.f90(1304): error #6632: Keyword arguments are invalid
>> without an explicit interface.   [FILE_NAME]
>>                         call equilibrium(file_name=**dataFile(elem, ion),
>> source/update_mod.f90(1305): error #6632: Keyword arguments are invalid
>> without an explicit interface.   [IONDENUP]
>>                              &ionDenUp=ionDenUsed(**
>> elementXref(elem),ion+1)/&
>> source/update_mod.f90(1306): error #6632: Keyword arguments are invalid
>> without an explicit interface.   [TE]
>>                              &ionDenUsed(elementXref(elem),**ion),
>> Te=TeUsed,&
>> source/update_mod.f90(1307): error #6632: Keyword arguments are invalid
>> without an explicit interface.   [NE]
>>                              &Ne=NeUsed, FlineEm=forbiddenLinesLarge(&
>> without an explicit interface.   [FLINEEM]
>> source/update_mod.f90(1310): error #6632: Keyword arguments are invalid
>> source/update_mod.f90(1311): error #6632: Keyword arguments are invalid
>>                              &ionDenUp=0., Te=TeUsed,&
>> source/update_mod.f90(1312): error #6632: Keyword arguments are invalid
>> source/update_mod.f90(2033): error #6404: This name does not have a type,
>> and must have an explicit type.   [RESLINE]
>>               do imul = 1, resLine(iL)%nmul
>> source/update_mod.f90(2033): error #6837: The leftmost part-ref in a
>> data-ref can not be a function reference.   [RESLINE]
>> source/update_mod.f90(2033): error #6158: The structure-name is invalid or
>> is missing.   [RESLINE]
>> source/update_mod.f90(2034): error #6837: The leftmost part-ref in a
>>                  if (resLine(iL)%elem==1) then
>> source/update_mod.f90(2034): error #6158: The structure-name is invalid or
>> source/update_mod.f90(2034): internal error: Please visit '
>> http://www.intel.com/**software/products/support<http://www.intel.com/software/products/support>'
>> for assistance.
>> [ Aborting due to internal error. ]
>> compilation aborted for source/update_mod.f90 (code 1)
>> source/output_mod.f90(6): error #7013: This module file was not generated
>>    use emission_mod
>> source/output_mod.f90(342): error #6404: This name does not have a type,
>> and must have an explicit type.   [LOG10TE]
>>                       log10Te         = log10(TeUsed)
>> source/output_mod.f90(343): error #6404: This name does not have a type,
>> and must have an explicit type.   [LOG10NE]
>>                       log10Ne         = log10(NeUsed)
>> source/output_mod.f90(344): error #6404: This name does not have a type,
>> and must have an explicit type.   [SQRTEUSED]
>>                       sqrTeUsed = sqrt(TeUsed)
>> source/output_mod.f90(370): error #6410: This name has not been declared
>> as an array or a function.   [HIRECLINES]
>>                                HIRecLines(iup, ilow) = &
>> source/output_mod.f90(370): internal error: Please visit '
>> for assistance.
>> compilation aborted for source/output_mod.f90 (code 1)
>> source/iteration_mod.f90(35): error #5102: Cannot open include file
>> 'mpif.h'
>>           include 'mpif.h'
>> source/iteration_mod.f90(7): error #7013: This module file was not
>> generated by any release of this compiler.   [EMISSION_MOD]
>>    use emission_mod
>> source/iteration_mod.f90(103): error #6404: This name does not have a
>> type, and must have an explicit type.   [BJUMPTEMP]
>>                 BjumpTemp = 0.
>> source/iteration_mod.f90(153): error #6404: This name does not have a
>> type, and must have an explicit type.   [MPI_REAL]
>> type, and must have an explicit type.   [MPI_SUM]
>> type, and must have an explicit type.   [MPI_COMM_WORLD]
>> source/iteration_mod.f90(477): error #6404: This name does not have a
>> type, and must have an explicit type.   [TOTALESCAPED]
>>           totalEscaped = 0.
>> source/iteration_mod.f90(543): error #6632: Keyword arguments are invalid
>> without an explicit interface.   [ISTAR]
>>                                call energyPacketDriver(iStar=0,n=**load,
>> grid=grid(1:nGrids), &
>> without an explicit interface.   [N]
>> without an explicit interface.   [GRID]
>> source/iteration_mod.f90(544): error #6632: Keyword arguments are invalid
>> without an explicit interface.   [GPLOC]
>> without an explicit interface.   [CELLLOC]
>> source/iteration_mod.f90(546): error #6632: Keyword arguments are invalid
>> source/iteration_mod.f90(547): error #6632: Keyword arguments are invalid
>> source/iteration_mod.f90(574): error #6404: This name does not have a
>> type, and must have an explicit type.   [MPI_INTEGER]
>>                   & mpi_integer, mpi_sum, mpi_comm_world, ierr)
>> compilation aborted for source/iteration_mod.f90 (code 1)
>> source/mocassin.f90(43): error #5102: Cannot open include file 'mpif.h'
>>    include 'mpif.h'
>> source/mocassin.f90(34): error #7002: Error in opening the compiled module
>> file.  Check INCLUDE paths.   [DUST_MOD]
>>    use dust_mod
>> source/mocassin.f90(35): error #7013: This module file was not generated
>>    use grid_mod
>> source/mocassin.f90(55): error #6404: This name does not have a type, and
>>    call mpi_comm_rank(MPI_COMM_WORLD, taskid, ierr)
>> compilation aborted for source/mocassin.f90 (code 1)
>> The makefile is this:
>> source1  = source/infnan.f90 source/constants_mod.f90
>> source/vector_mod.f90 source/common_mod.f90 source/interpolation_mod.f90 \
>> source/composition_mod.f90 \
>> source/pathIntegration_mod.f90 \
>>    source/grid_mod.f90 source/dust_mod.f90 source/emission_mod.f90
>> source/photon_mod.f90  \
>>    source/update_mod.f90 \
>> source2  = source/infnan.f90 source/constants_mod.f90
>>    source/output_mod.f90 source/iteration_mod.f90 source/mocassinWarm.f90
>> source3  = source/infnan.f90 source/constants_mod.f90
>> source/mocassinOutput.f90
>> source4  = source/infnan.f90 source/constants_mod.f90
>>    source/output_mod.f90 source/iteration_mod.f90 source/mocassinPlot.f90
>>  F90  = /opt/intel/composer_xe_2011_**sp1.6.233/composer_xe_2011_**
>> LIBS = -l/home/carol/mocassin/**mpich2install/include
>> OPT1 = -O5
>> OPT2 = -O5
>> mocassin:
>>    $(F90) $(OPT1) -o mocassin $(source1) $(LIBS)
>> mocassinWarm:
>>    $(F90) $(OPT1) -o mocassinWarm $(source2) $(LIBS)
>> mocassinOutput:
>>    $(F90) $(OPT2) -o mocassinOutput $(source3) $(LIBS)
>> mocassinPlot:
>>    $(F90) $(OPT2) -o mocassinPlot $(source4) $(LIBS)
>> clean:
>>    /bin/rm *.o *~ *.mod mocassin mocassinWarm mocassinOutput mocassinPlot
>> Does someone have a clue of what is the problem?
>> Thanks,
>> Carolina.
>> ______________________________**_________________
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111024/f6f6db59/attachment-0001.htm>
