[mpich-discuss] Problem with LD_PRELOAD does not works with mpich2!
Sandra Mendez
sandra.mendez at caos.uab.es
Fri Oct 21 13:19:19 CDT 2011
I'm testing an I/O tracing but it does not work with mpich2. When execute
the application with my I/O tracing it reports the following error:
smendez at node1:~$ /home/smendez/mpich2-install/bin/mpirun -genv LD_PRELOAD
/home/smendez/libpas2p/bin/libpas2p-mpich.so -f /home/smendez/maquinas1 -n 4
/home/smendez/fuentesTest/pruebaPAS2P
Attempting to use an MPI routine before initializing MPICH
When it executes without "-genv LD_PRELOAD
/home/smendez/libpas2p/bin/libpas2p-mpich.so" the program run correctly.
The "libpas2p-mpich.so" was compiled with
/home/smendez/mpich2-install/bin/mpicc -shared -ldl -fPIC ./libpas2p-io.c -o
bin/libpas2p.so
also mpich was configured with
./configure --prefix=/home/smendez/mpich2-install --enable-shared
--enable-sharedlib
make
make install
Somebody can be help me?
Thanks.
Sandra.-
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111021/68cdf18b/attachment.htm>
