[mpich-discuss] MPICH problem
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Oct 21 10:33:18 CDT 2011
 It looks like MPICH2 was not installed correctly on your system. Uninstall your existing version and install using the instructions in Section 9.4 (NOT 9.1) of the instal
ler's guide (available at http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs).
(PS: After a successful installation SMPD would not prompt you for a passphrase)
Jayesh
----- Original Message -----
Sent: Thursday, October 20, 2011 5:26:44 PM
Subject: [mpich-discuss] MPICH problem
Hi.
I have some problem running MPICH program. I have Windows 7 x64. I have
instaled 32bit version of MPICH because i had some problem with LINKER in
64 bit version.
So, the problem is that when I try to run program with command "mpiexec
-localonly 2 cpi.exe" for example, I get promted for passphrase with
"Please specify an authentication passphrase for smpd :" then I write in
the passphrase and next output I get is "Please specify an authentication
passphrase for smpd : Please specify an authentication passphrase for smpd
:" and program is hanged. I can write but it does nothing so I have to
stop it with Ctrl+c. Also, when i write "smpd -status" I get "Abortion:
unable to connect to Mycomputer". It looks like it cannot set smpd service
on my computer, however "smpd -start" works fine. I run cmd as
administrator.
Anybody have any idea what is a problem ? I did not find any similar
problems on web.
Using Opera's revolutionary email client: http://www.opera.com/mail/
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
