[mpich-discuss] jumpshot error converting .rlog to .slog2...
    Laurent PERROTON
    l.perroton at esiee.fr
    Mon Oct  3 11:54:21 CDT 2011
Anthony Chan writes:
 > Did you see libTraceInput.so in /user/pvm/mpich2-log ?
No:
gemini1: ~/mpich2-log % find . | fgrep -i libTraceInput
Apparently, nothing gets compiled in:
~/mpich2-1.4.1p1/src/util/logging/rlog/TraceInput
I include the c.txt & m.txt if it can help...
L.
Configuring MPICH2 version 1.4.1p1 with  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday'
Running on system: Linux gemini1 3.0.4 #1 SMP Tue Aug 30 11:43:55 CEST 2011 i686 GNU/Linux
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for grep that handles long lines and -e... /bin/grep
checking for fgrep... /bin/grep -F
Executing mpich2prereq in /user/pvm/mpich2-1.4.1p1/src/mpid/ch3 with
Executing mpich2prereq in /user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis
configure: ===== configuring src/mpl =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/mpl/configure  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --disable-option-checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for variable argument list macro functionality... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... yes
checking valgrind/valgrind.h presence... yes
checking for valgrind/valgrind.h... yes
checking valgrind/memcheck.h usability... yes
checking valgrind/memcheck.h presence... yes
checking for valgrind/memcheck.h... yes
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... yes
checking valgrind/helgrind.h presence... yes
checking for valgrind/helgrind.h... yes
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... yes
checking valgrind/drd.h presence... yes
checking for valgrind/drd.h... yes
checking whether the valgrind headers are broken or too old... no
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
config.status: include/mplconfig.h is unchanged
configure: ===== done with src/mpl configure =====
configure: ===== configuring src/openpa =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/openpa/configure --with-atomic-primitives=auto_allow_emulation '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --disable-option-checking
checking for gcc... (cached) gcc
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 4
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure: ===== done with src/openpa configure =====
sourcing /user/pvm/mpich2-1.4.1p1/src/pm/hydra/mpich2prereq
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether C compiler option -O2 works with an invalid prototype program... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... no
checking for multiple weak symbol support... yes
checking for perl... /usr/bin/perl
checking for killall... killall
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /bin/bash
checking whether /bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for working volatile... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... four
checking for max C struct floating point alignment... four
checking for max C struct alignment of structs with doubles... four
checking for max C struct floating point alignment with long doubles... four
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 4
checking size of unsigned long... 4
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 12
checking for ANSI C header files... no
checking size of wchar_t... 4
checking size of float_int... 8
checking size of double_int... 12
checking size of long_int... 8
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 16
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... yes
checking complex.h presence... yes
checking for complex.h... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 24
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 56
checking for gcc __asm__ and pentium cmpxchgl instruction... yes
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking for ANSI C header files... (cached) no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking string.h usability... yes
checking string.h presence... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... no
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for gettimeofday... yes
sourcing /user/pvm/mpich2-1.4.1p1/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... no
checking for thread local storage specifier... __thread
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... yes
checking for sched_getaffinity... yes
checking for bindprocessor... no
checking for thread_policy_set... no
checking whether cpu_set_t available... yes
checking whether the CPU_SET and CPU_ZERO macros are defined... no
configure: ===== configuring src/mpid/ch3 =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/mpid/ch3/configure  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --disable-option-checking
RUNNING CONFIGURE FOR CH3 DEVICE
checking whether make allows comments in actions... no
configure: WARNING: Your make does not allow comments in target code.
Using this make may cause problems when building programs.
You should consider using gnumake instead.
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... no
checking uuid/uuid.h presence... no
checking for uuid/uuid.h... no
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
configure: ===== configuring channels/nemesis =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/configure  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for signal... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
config.status: include/mpidi_ch3i_nemesis_conf.h is unchanged
configure: ===== done with channels/nemesis configure =====
config.status: creating util/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: include/mpidi_ch3_conf.h is unchanged
config.status: executing default-1 commands
copying ./../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
configure: ===== done with src/mpid/ch3 configure =====
configure: ===== configuring src/util/logging/rlog =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/util/logging/rlog/configure  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --disable-option-checking
RUNNING CONFIGURE FOR RLOG
checking for ar... /usr/bin/ar
config.status: creating pprintirlog
config.status: creating rlogconf.h
configure: ===== done with src/util/logging/rlog configure =====
configure: ===== configuring src/mpi/romio =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/mpi/romio/configure  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --disable-option-checking
Configuring with args --prefix=/user/pvm/mpich2-log --disable-f77 --disable-fc --disable-cxx --enable-timing=log --with-logging=rlog --enable-timer-type=gettimeofday --disable-option-checking
checking for architecture... LINUX
ROMIO home directory is /user/pvm/mpich2-1.4.1p1/src/mpi/romio
checking for memalign... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... yes
checking that the compiler correctly implements weak symbols... yes
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... -lrt
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
checking spi/kernel_interface.h usability... no
checking spi/kernel_interface.h presence... no
checking for spi/kernel_interface.h... no
checking for Kernel_GetMemorySize... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to :
setting TEST_CC to /user/pvm/mpich2-1.4.1p1/bin/mpicc
setting TEST_F77 to /user/pvm/mpich2-1.4.1p1/bin/mpif77
setting CFLAGS to    -O2  -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: ===== done with src/mpi/romio configure =====
configure: ===== configuring src/pmi/simple =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/pmi/simple/configure  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --disable-option-checking
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for strings.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
config.status: pmiconf.h is unchanged
configure: ===== done with src/pmi/simple configure =====
configure: ===== configuring src/pm/hydra =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/pm/hydra/configure  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --disable-option-checking
checking for a thread-safe mkdir -p... mkdir -p
checking whether -lc should be explicitly linked in... no
checking whether to build shared libraries... yes
checking for doxygen... /usr/bin/doxygen
checking ifaddrs.h usability... yes
checking ifaddrs.h presence... yes
checking for ifaddrs.h... yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking for netdb.h... (cached) yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... yes
checking for sigaction... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for getifaddrs... yes
checking for fcntl... yes
checking for isatty... yes
checking for inet_ntop... yes
checking for environ in unistd.h... no
checking for manually declared extern environ... yes
checking bootstrap server... user,ssh,rsh,fork,slurm,ll,lsf,sge,pbs,manual,persist
checking tm.h usability... no
checking tm.h presence... no
checking for tm.h... no
checking for tm_init in -ltorque... no
checking process manager... pmiserv
checking user interface... mpich
checking desired processor topology libraries... hwloc,plpa
configure: ===== configuring tools/topo/hwloc/hwloc =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/configure --enable-embedded-mode '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS= -lnsl' 'LIBS=' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' --disable-option-checking
### Configuring hwloc distribution tarball
### Startup tests
checking target system type... i686-pc-linux-gnu
checking how to create a ustar tar archive... gnutar
checking for hwloc version... 1.2.1rc2-1
checking whether gcc and cc understand -c and -o together... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
### Configuring hwloc core
checking hwloc building mode... embedded
configure: hwloc builddir: /user/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc
configure: hwloc srcdir: /user/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc
checking if want hwloc maintainer support... disabled (embedded mode)
checking for hwloc directory prefix... (none)
checking for hwloc symbol prefix... hwloc_
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking which OS support to include... Linux
checking which CPU support to include... x86_32
checking for __attribute__... yes
checking for __attribute__(aligned)... yes
checking for __attribute__(always_inline)... yes
checking for __attribute__(cold)... yes
checking for __attribute__(const)... yes
checking for __attribute__(deprecated)... yes
checking for __attribute__(format)... no
checking for __attribute__(hot)... yes
checking for __attribute__(malloc)... yes
checking for __attribute__(may_alias)... yes
checking for __attribute__(no_instrument_function)... yes
checking for __attribute__(nonnull)... no
checking for __attribute__(noreturn)... yes
checking for __attribute__(packed)... yes
checking for __attribute__(pure)... yes
checking for __attribute__(sentinel)... no
checking for __attribute__(unused)... yes
checking for __attribute__(warn_unused_result)... yes
checking for __attribute__(weak_alias)... yes
checking if gcc supports -fvisibility... yes
checking whether to enable visibility... yes (via -fvisibility=hidden)
configure: WARNING: " -fvisibility=hidden" has been added to the hwloc CFLAGS
checking for inline compatibility keyword... __inline__
checking whether function strncasecmp is declared... yes
checking for strftime... yes
checking for setlocale... yes
checking for KAFFINITY... no
checking for PROCESSOR_CACHE_TYPE... no
checking for CACHE_DESCRIPTOR... no
checking for LOGICAL_PROCESSOR_RELATIONSHIP... no
checking for RelationProcessorPackage... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION... no
checking for GROUP_AFFINITY... no
checking for PROCESSOR_RELATIONSHIP... no
checking for NUMA_NODE_RELATIONSHIP... no
checking for CACHE_RELATIONSHIP... no
checking for PROCESSOR_GROUP_INFO... no
checking for GROUP_RELATIONSHIP... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX... no
checking for PSAPI_WORKING_SET_EX_BLOCK... no
checking for PSAPI_WORKING_SET_EX_INFORMATION... no
checking for main in -lgdi32... no
checking sys/lgrp_user.h usability... no
checking sys/lgrp_user.h presence... no
checking for sys/lgrp_user.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking whether _SC_NPROCESSORS_ONLN is declared... yes
checking whether _SC_NPROCESSORS_CONF is declared... yes
checking whether _SC_NPROC_ONLN is declared... no
checking whether _SC_NPROC_CONF is declared... no
checking whether _SC_LARGE_PAGESIZE is declared... no
checking mach/mach_host.h usability... no
checking mach/mach_host.h presence... no
checking for mach/mach_host.h... no
checking mach/mach_init.h usability... no
checking mach/mach_init.h presence... no
checking for mach/mach_init.h... no
checking for sys/sysctl.h... yes
checking whether CTL_HW is declared... no
checking whether HW_NCPU is declared... no
checking for sysctl... yes
checking for sysctlbyname... no
checking for pthread_t... yes
checking whether function sched_setaffinity is declared... yes
checking for old prototype of sched_setaffinity... no
checking for working CPU_SET... yes
checking for working CPU_SET_S... yes
checking for working _syscall3... no
checking for KERRIGHED... no
checking for lib... no
checking for ffs... yes
checking whether function ffs is declared... yes
checking for ffsl... yes
checking whether function ffsl is declared... yes
checking for fls... no
checking for flsl... no
checking for clz... no
checking for clzl... no
checking for openat... yes
checking for getpagesize... yes
checking for posix_memalign... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking for uname... yes
checking numaif.h usability... no
checking numaif.h presence... no
checking for numaif.h... no
checking pthread_np.h usability... no
checking pthread_np.h presence... no
checking for pthread_np.h... no
checking whether pthread_setaffinity_np is declared... yes
checking whether pthread_getaffinity_np is declared... yes
checking for sys/cpuset.h... no
checking for library containing pthread_getthrds_np... no
checking for XML... no
checking for cpuid... yes
checking for X... libraries , headers
checking whether to build static libraries... no
config.status: creating include/Makefile
config.status: creating include/private/autogen/config.h
config.status: include/private/autogen/config.h is unchanged
config.status: creating include/hwloc/autogen/config.h
config.status: include/hwloc/autogen/config.h is unchanged
configure: ===== done with tools/topo/hwloc/hwloc configure =====
configure: ===== configuring tools/topo/plpa/plpa =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/configure --enable-included-mode '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS= -lnsl' 'LIBS=' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' --disable-option-checking
checking for PLPA version... 1.3.2
checking whether to enable "picky" compiler mode... no (default)
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking for syscall... yes
checking sys/syscall.h usability... yes
checking sys/syscall.h presence... yes
checking for sys/syscall.h... yes
checking for __NR_sched_setaffinity... yes
checking for __NR_sched_getaffinity... yes
checking for PLPA building mode... included
checking if want PLPA maintainer support... disabled
checking for PLPA config prefix... .
checking for PLPA symbol prefix... plpa_
checking for VALGRIND_CHECK_MEM_IS_ADDRESSABLE... yes
checking whether to build PLPA executables... no
config.status: creating ./Makefile
config.status: creating ./config/Makefile
config.status: creating ./src/Makefile
config.status: creating ./src/libplpa/Makefile
config.status: creating ./src/plpa-info/Makefile
config.status: creating ./src/plpa-taskset/Makefile
config.status: creating ./src/libplpa/plpa_config.h
config.status: ./src/libplpa/plpa_config.h is unchanged
config.status: creating ./src/libplpa/plpa.h
config.status: ./src/libplpa/plpa.h is unchanged
configure: ===== done with tools/topo/plpa/plpa configure =====
checking available processor topology libraries...  hwloc plpa
checking checkpointing library... none
checking demux engine... poll,select,port
checking for poll... yes
checking debugging support... none
checking error checking... yes
checking warnings... no
checking profiling... yes
checking libftb.h usability... no
checking libftb.h presence... no
checking for libftb.h... no
checking for FTB_Connect in -lftb... no
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
configure: ===== done with src/pm/hydra configure =====
configure: ===== configuring src/mpe2 =====
configure: executing: /user/pvm/mpich2-1.4.1p1/src/mpe2/configure  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --disable-option-checking
Configuring MPE Profiling System with  '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' '--disable-option-checking' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= '
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2
checking gnumake... yes using --no-print-directory
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ...  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" "src/slog2sdk" cleaned
checking whether MPI_CC has been set ... /user/pvm/mpich2-1.4.1p1/bin/mpicc
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  'sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
=== configuring in src/misc (/user/pvm/mpich2-1.4.1p1/src/mpe2/src/misc)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/user/pvm/mpich2-log'  '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' --cache-file=/dev/null --srcdir=.
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2/src/misc
checking for dbx... no
checking for gdb... /usr/bin/gdb
checking for sysinfo... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... no
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/user/pvm/mpich2-1.4.1p1/src/mpe2/src/callstack)
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2/src/callstack
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking whether <execinfo.h> defines backtrace_symbols_fd() ... yes
checking if <execinfo.h> links with -Wl,--export-dynamic ... yes
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating bin/bt2line
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/user/pvm/mpich2-1.4.1p1/src/mpe2/src/logging)
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2/src/logging
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int32_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for O_LARGEFILE for open() ... needs _LARGEFILE64_SOURCE
checking for O_BINARY for open() ... no
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/user/pvm/mpich2-1.4.1p1/src/mpe2/src/wrappers)
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2/src/wrappers
checking OSF V3 make... Found OSF V3 make
The OSF V3 make does not allow comments in target code.
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/user/pvm/mpich2-1.4.1p1/src/mpe2/src/graphics)
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2/src/graphics
checking for long pointer... no
checking for system... yes
config.status: creating contrib/life/Makefile
config.status: creating contrib/mandel/Makefile
config.status: creating contrib/mastermind/Makefile
config.status: creating contrib/test/Makefile
config.status: creating etc/mpe_mpianim.conf
config.status: creating etc/mpe_graphics.conf
config.status: creating mpe_graphics_conf.h
=== configuring in src/collchk (/user/pvm/mpich2-1.4.1p1/src/mpe2/src/collchk)
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2/src/collchk
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/user/pvm/mpich2-1.4.1p1/src/mpe2/src/slog2sdk)
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' '--cache-file=/dev/null' '--srcdir=.'
checking if CLASSPATH is set... no, good to go
checking for java in user's PATH... found /usr/bin/java
checking if /usr/bin/java runs simple java class... yes
checking if /usr/bin/java runs simple jar file... yes
checking if /usr/bin/java runs non-GUI tool... yes
checking if /usr/bin/java runs simple Swing class... yes
checking if /usr/bin/java runs simple Swing jar file... yes
checking for Java version... java full version "1.6.0_26-b03", i.e. Java 2 SDK
checking for cygpath... no
creating sample logfiles from source
checking for leftover Makefiles in subpackages ... none
config.status: creating sbin/install-package
config.status: creating bin/slog2print
config.status: creating bin/slog2navigator
config.status: creating bin/slog2filter
config.status: creating bin/slog2updater
config.status: creating bin/logconvertor
config.status: creating bin/jumpshot
config.status: creating bin/clogprint
config.status: creating bin/clogTOslog2
config.status: creating bin/clog2print
config.status: creating bin/clog2TOslog2
=== configuring in trace_rlog (/user/pvm/mpich2-1.4.1p1/src/mpe2/src/slog2sdk/trace_rlog)
checking for current directory name... /user/pvm/mpich2-1.4.1p1/src/mpe2/src/slog2sdk/trace_rlog
Configuring TRACE_RLOG implementation with  '--disable-option-checking' '--prefix=/user/pvm/mpich2-log' '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' 'MPI_CC=/user/pvm/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/user/pvm/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers' 'FFLAGS= ' '--cache-file=/dev/null' '--srcdir=.'
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking size of __int64... 0
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for sed... sed
checking for a sed that does not truncate output... sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for malloc in -lefence... yes
checking for strstr... yes
checking for javah in user's PATH... found /usr/bin/javah
checking if /usr exists... yes
checking for <jni.h> include flag... no
checking for javah in user's PATH... found /usr/bin/X11/javah
checking if /usr/bin exists... yes
checking for javah in known path... found /usr/bin/javah
configure: WARNING:  Invalid JNI include dir, exit!
configure: WARNING: SLOG2SDK: No sub-package has been configured
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" "src/slog2sdk" have been configured
configure: ===== done with src/mpe2 configure =====
checking size of OPA_ptr_t... 4
configure: WARNING: Could not define Fortran MPI datatypes for C
checking the sizeof MPI_Offset... 8
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f77/setbot.c
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/binding/f90/mpi_base.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-c.pc
config.status: creating src/packaging/pkgconfig/mpich2-cxx.pc
config.status: creating src/packaging/pkgconfig/mpich2-f77.pc
config.status: creating src/packaging/pkgconfig/mpich2-f90.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  'src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpix/Makefile
config.status: creating src/mpix/comm/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/simple/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
=== configuring in test/mpi (/user/pvm/mpich2-1.4.1p1/test/mpi)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/user/pvm/mpich2-log'  '--disable-f77' '--disable-fc' '--disable-cxx' '--enable-timing=log' '--with-logging=rlog' '--enable-timer-type=gettimeofday' --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether /user/pvm/mpich2-1.4.1p1/bin/mpicc accepts -g... yes
checking for /user/pvm/mpich2-1.4.1p1/bin/mpicc option to accept ISO C89... none needed
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking how to run the C preprocessor... /user/pvm/mpich2-1.4.1p1/bin/mpicc -E
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for library containing pthread_create... -lpthread
checking for library containing pthread_barrier_init... none required
checking for pthread_create... yes
checking for pthread_yield... yes
checking for pthread_barrier_init... yes
checking for pthread_barrier_wait... yes
checking for major version of MPI... 2
checking for minor version of MPI... 2
configure: WARNING: Selecting integer*8 as the Fortran type for MPI_Offset
configure: WARNING: Selecting integer as the Fortran type for MPI_Aint
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking size of void *... 4
checking size of int... 4
checking size of long... 4
checking size of long long... 8
checking size of short... 2
checking for C integer type of address size... int
checking for perl... /usr/bin/perl
configure: creating ./config.status
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating Makefile
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
config.status: include/mpitestconf.h is unchanged
Configuration completed.
Beginning make
Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='' FFLAGS=' ' FC='' FCFLAGS=' ' CXX='' CXXFLAGS=' ' AR='ar' CPP='gcc -E' CPPFLAGS=' -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers'
make all-local
make[1]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
make clean && cd test && make clean
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
make cleanlibs
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
rm -f lib/libmpich.a lib/libpmpich.a
rm -f lib/libmpichcxx.a
rm -f lib/libfmpich.a lib/libmpichf90.a
rm -f lib/libmpich.so*
rm -f lib/libpmpich.so*
rm -f lib/libmpichcxx.so*
rm -f lib/libfmpich.so*
rm -f lib/libmpichf90.so*
rm -f lib/libmpichf90.*.so*
rm -f lib/libmpich.*.so*
rm -f lib/libpmpich.*.so*
rm -f lib/libmpichcxx.*.so*
rm -f lib/libfmpich.*.so*
rm -f lib/libmpich.la* lib/libpmpich.la*
rm -f lib/libmpichf90.la*
rm -f lib/libmpichcxx.la*
rm -f lib/libfmpich.la*
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
for dir in  src/mpl src/openpa src - ; do \
		if [ "$dir" = "-" ] ; then break ; fi ; \
		(cd $dir && make clean ) ; done
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
 rm -f strsep
test -z "libmpl.la" || rm -f libmpl.la
rm -f "./so_locations"
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
Making clean in test
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/test »
 rm -f sanity test_primitives test_barriers test_queue
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/test »
Making clean in src
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
test -z "libopa.la" || rm -f libopa.la
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
Making clean in .
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
rm -rf .libs _libs
rm -f *.lo
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src »
for dir in mpl mpid mpi mpix util nameserv binding env packaging mpe2 pmi pm - ; do \
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid »
for dir in common ch3 - ; do \
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common »
(cd datatype && make clean )
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype »
(cd dataloop && make clean )
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop »
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3 »
for dir in channels src util ; do \
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels »
for dir in nemesis - ; do \
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis »
(cd nemesis && make clean )
make[9]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis »
(cd src && make clean )
make[10]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/src »
make[10]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/src »
(cd netmod && make clean )
make[10]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod »
for dir in tcp - ; do \
make[11]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp »
make[11]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp »
make[10]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod »
(cd utils && make clean )
make[10]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils »
(cd monitor && make clean )
make[11]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor »
make[11]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor »
(cd replacements && make clean )
make[11]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements »
make[11]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements »
make[10]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils »
make[9]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis »
make[9]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/src »
make[9]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/src »
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels »
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/src »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/src »
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/util »
for dir in   - ; do \
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/util »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3 »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi »
for dir in attr coll comm datatype errhan group init misc pt2pt rma spawn timer topo romio  - ; do \
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/attr »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/attr »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/coll »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/coll »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/comm »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/comm »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/datatype »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/datatype »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/errhan »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/errhan »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/group »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/group »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/init »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/init »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/misc »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/misc »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/pt2pt »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/pt2pt »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/rma »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/rma »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/spawn »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/spawn »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/timer »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/timer »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/topo »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/topo »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio »
cleaning directory mpi-io
cleaning directory adio/common
cleaning directory mpi-io/glue/mpich2
cleaning directory adio/ad_testfs
cleaning directory adio/ad_ufs
cleaning directory adio/ad_nfs
cleaning directory test-internal
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/test-internal »
rm -f .P* PI* *.o
rm -f file_realms_test io_bounds_test heap_test
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/test-internal »
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/test »
rm -f .P* PI* *.o
rm -f simple perf async coll_test coll_perf misc file_info excl large_array atomicity noncontig i_noncontig noncontig_coll split_coll shared_fp large_file psimple error status noncontig_coll2 aggregation1 aggregation2 async-multiple ordered_fp hindexed fcoll_test fperf fmisc pfcoll_test
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/test »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpix »
(cd comm && make clean )
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpix/comm »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpix/comm »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpix »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util »
for dir in mem info msgs instrm thread dbg param osserv procmap other logging - ; do \
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/mem »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/mem »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/info »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/info »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/msgs »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/msgs »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/instrm »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/instrm »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/thread »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/thread »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/dbg »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/dbg »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/param »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/param »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/osserv »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/osserv »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/procmap »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/procmap »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/other »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/other »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging »
for dir in rlog common - ; do \
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging/rlog »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging/rlog »
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging/common »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging/common »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/nameserv »
for dir in file - ; do \
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/nameserv/file »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/nameserv/file »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/nameserv »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/binding »
for dir in  - ; do \
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/binding »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/env »
make clean-postamble
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/env »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/env »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/env »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging »
(cd pkgconfig && make clean )
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging/pkgconfig »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging/pkgconfig »
(cd envmods && make clean )
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging/envmods »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging/envmods »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpe2 »
rm -f /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/lib*
rm -f /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/*.jar
rm -f /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/*.o
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpe2 »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pmi »
for dir in simple - ; do \
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pmi/simple »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pmi/simple »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pmi »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm »
for dir in hydra  - ; do \
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra »
Making clean in tools/topo/hwloc/hwloc
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc »
Making clean in include
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/include »
rm -rf .libs _libs
rm -f *.lo
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/include »
Making clean in src
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/src »
test -z "" || rm -f
rm -rf .libs _libs
test -z "libhwloc_embedded.la" || rm -f libhwloc_embedded.la
rm -f *.o
rm -f *.lo
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/src »
Making clean in .
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc »
rm -rf .libs _libs
rm -f *.lo
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc »
Making clean in tools/topo/plpa/plpa
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa »
Making clean in src
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src »
Making clean in plpa-taskset
make[9]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-taskset »
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[9]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-taskset »
Making clean in plpa-info
make[9]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-info »
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[9]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-info »
Making clean in libplpa
make[9]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa »
test -z "" || rm -f
rm -rf .libs _libs
test -z " libplpa_included.la" || rm -f  libplpa_included.la
rm -f *.o
rm -f *.lo
make[9]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa »
Making clean in .
make[9]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src »
rm -rf .libs _libs
rm -f *.lo
make[9]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src »
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src »
Making clean in .
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa »
rm -rf .libs _libs
rm -f *.lo
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa »
Making clean in ../../mpl
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
Making clean in .
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra »
 rm -f hydra_persist hydra_nameserver hydra_pmi_proxy mpiexec.hydra
rm -rf .libs _libs
test -z "libhydra.la libpm.la" || rm -f libhydra.la libpm.la
rm -f *.o
rm -f *.lo
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src »
cd examples && make clean
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/examples »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/examples »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test »
for dir in mpi mpid util basic commands ; do \
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi »
rm -f summary.xml
for dir in util attr basic datatype coll comm errhan group info init pt2pt rma spawn topo io  threads errors manual perf - ; do \
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/util »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/util »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/attr »
rm -f summary.xml
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/attr »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/basic »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/basic »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/datatype »
rm -f summary.xml
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/datatype »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/coll »
rm -f summary.xml
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/coll »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/comm »
rm -f summary.xml
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/comm »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errhan »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errhan »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/group »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/group »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/info »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/info »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/init »
rm -f summary.xml
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/init »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/pt2pt »
rm -f summary.xml
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/pt2pt »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/rma »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/rma »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/spawn »
rm -f summary.xml
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/spawn »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/topo »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/topo »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/io »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/io »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads »
rm -f summary.xml
for dir in util pt2pt comm init spawn ; do \
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/util »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/util »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/pt2pt »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/pt2pt »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/comm »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/comm »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/init »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/init »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/spawn »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads/spawn »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/threads »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors »
for dir in attr coll comm group pt2pt rma spawn topo io  basic faults - ; do \
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/attr »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/attr »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/coll »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/coll »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/comm »
rm -f summary.xml
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/comm »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/group »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/group »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/pt2pt »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/pt2pt »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/rma »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/rma »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/spawn »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/spawn »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/topo »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/topo »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/io »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/io »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/basic »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/basic »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/faults »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors/faults »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/errors »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/manual »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/manual »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/perf »
rm -f summary.xml
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi/perf »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpi »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpid »
(cd ch3 && make clean )
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpid/ch3 »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpid/ch3 »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/mpid »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/util »
(cd timer && make clean )
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/util/timer »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/util/timer »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/util »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/basic »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/basic »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/commands »
rm -f err.txt out.log out.txt stdintest stdintest2 sdtiotest a.out
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test/commands »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/test »
rm -f lib/newconfig
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
make[1]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
make[1]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
  CC     mplstr.lo
  CC     mpltrmem.lo
  CC     mplenv.lo
  CCLD   libmpl.la
make[1]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
make[1]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
Making all in src
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
make  all-am
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
/bin/bash ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo opa_primitives.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c opa_primitives.c -o opa_primitives.o
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/bin/bash ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c opa_queue.c -o opa_queue.o
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Plo
/bin/bash ../libtool --tag=CC   --mode=link gcc   -version-info 1:0  -o libopa.la -rpath /user/pvm/mpich2-log/lib opa_primitives.lo opa_queue.lo  -lpthread
libtool: link: ar cru .libs/libopa.a  opa_primitives.o opa_queue.o
libtool: link: ranlib .libs/libopa.a
libtool: link: ( cd ".libs" && rm -f "libopa.la" && ln -s "../libopa.la" "libopa.la" )
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
Making all in test
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/test »
make[2]: Rien à faire pour « all ».
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/test »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[2]: Rien à faire pour « all-am ».
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[1]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[1]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop »
  CC              dataloop.c
  CC              segment.c
  CC              segment_packunpack.c
  CC              segment_flatten.c
  CC              segment_count.c
  CC              dataloop_create.c
  CC              dataloop_create_contig.c
  CC              dataloop_create_vector.c
  CC              dataloop_create_blockindexed.c
  CC              dataloop_create_indexed.c
  CC              dataloop_create_struct.c
  CC              dataloop_create_pairtype.c
  CC              subarray_support.c
  CC              darray_support.c
  AR cr ../../../../../lib/libmpich.a dataloop.o segment.o segment_packunpack.o segment_flatten.o segment_count.o dataloop_create.o dataloop_create_contig.o dataloop_create_vector.o dataloop_create_blockindexed.o dataloop_create_indexed.o dataloop_create_struct.o dataloop_create_pairtype.o subarray_support.o darray_support.o
  RANLIB          libmpich.a
date > .libstamp0
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop »
make all-local
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype »
  CC              mpid_type_debug.c
  CC              mpid_segment.c
  CC              mpid_ext32_segment.c
  CC              mpid_ext32_datatype.c
  CC              mpid_type_dup.c
  CC              mpir_type_get_contig_blocks.c
  CC              mpir_type_flatten.c
  CC              mpid_type_commit.c
  CC              mpid_type_zerolen.c
  CC              mpid_type_vector.c
  CC              mpid_type_contiguous.c
  CC              mpid_type_create_resized.c
  CC              mpid_type_blockindexed.c
  CC              mpid_type_indexed.c
  CC              mpid_type_struct.c
  CC              mpid_type_get_envelope.c
  CC              mpid_datatype_free.c
  CC              mpid_datatype_contents.c
  CC              mpid_type_get_contents.c
  CC              mpid_type_create_pairtype.c
  CC              mpid_contents_support.c
  AR cr ../../../../lib/libmpich.a mpid_type_debug.o mpid_segment.o mpid_ext32_segment.o mpid_ext32_datatype.o mpid_type_dup.o mpir_type_get_contig_blocks.o mpir_type_flatten.o mpid_type_commit.o mpid_type_zerolen.o mpid_type_vector.o mpid_type_contiguous.o mpid_type_create_resized.o mpid_type_blockindexed.o mpid_type_indexed.o mpid_type_struct.o mpid_type_get_envelope.o mpid_datatype_free.o mpid_datatype_contents.o mpid_type_get_contents.o mpid_type_create_pairtype.o mpid_contents_support.o
  RANLIB          libmpich.a
date > .libstamp0
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common/datatype »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/common »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3 »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis »
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/src »
  CC              mpid_nem_alloc.c
  CC              mpid_nem_init.c
  CC              mpid_nem_queue.c
  CC              mpid_nem_barrier.c
  CC              mpid_nem_mpich2.c
  CC              mpid_nem_ckpt.c
  CC              mpid_nem_finalize.c
  CC              mpid_nem_network_poll.c
  CC              mpid_nem_network.c
  CC              mpid_nem_debug.c
  CC              mpid_nem_lmt.c
  CC              mpid_nem_lmt_shm.c
  CC              mpid_nem_net_array.c
  CC              mpid_nem_lmt_dma.c
  CC              mpid_nem_lmt_vmsplice.c
  AR cr ../../../../../../../lib/libmpich.a mpid_nem_alloc.o mpid_nem_init.o mpid_nem_queue.o mpid_nem_barrier.o mpid_nem_mpich2.o mpid_nem_ckpt.o mpid_nem_finalize.o mpid_nem_network_poll.o mpid_nem_network.o mpid_nem_debug.o mpid_nem_lmt.o mpid_nem_lmt_shm.o mpid_nem_net_array.o mpid_nem_lmt_dma.o mpid_nem_lmt_vmsplice.o
  RANLIB          libmpich.a
date > .libstamp0
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/src »
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod »
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp »
  CC              tcp_finalize.c
  CC              tcp_init.c
  CC              tcp_send.c
  CC              tcp_utility.c
  CC              socksm.c
  CC              tcp_getip.c
  CC              tcp_ckpt.c
  AR cr ../../../../../../../../lib/libmpich.a tcp_finalize.o tcp_init.o tcp_send.o tcp_utility.o socksm.o tcp_getip.o tcp_ckpt.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod »
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils »
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor »
  CC              papi_defs.c
  AR cr ../../../../../../../../lib/libmpich.a papi_defs.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor »
make[8]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements »
  CC              mkstemp.c
  AR cr ../../../../../../../../lib/libmpich.a mkstemp.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements »
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/src »
  CC              ch3_finalize.c
  CC              ch3_init.c
  CC              ch3_isend.c
  CC              ch3_isendv.c
  CC              ch3_istartmsg.c
  CC              ch3_istartmsgv.c
  CC              ch3_progress.c
  CC              ch3_abort.c
  CC              ch3i_comm.c
  CC              ch3i_eagernoncontig.c
  AR cr ../../../../../../lib/libmpich.a ch3_finalize.o ch3_init.o ch3_isend.o ch3_isendv.o ch3_istartmsg.o ch3_istartmsgv.o ch3_progress.o ch3_abort.o ch3i_comm.o ch3i_eagernoncontig.o
  RANLIB          libmpich.a
date > .libstamp0
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/src »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/src »
  CC              ch3u_buffer.c
  CC              ch3u_comm_spawn_multiple.c
  CC              ch3u_handle_connection.c
  CC              ch3u_handle_recv_pkt.c
  CC              ch3u_handle_recv_req.c
  CC              ch3u_handle_send_req.c
  CC              ch3u_port.c
  CC              ch3u_recvq.c
  CC              ch3u_request.c
  CC              ch3u_rma_ops.c
  CC              ch3u_rma_sync.c
  CC              ch3u_rndv.c
  CC              ch3u_eager.c
  CC              ch3u_eagersync.c
  CC              mpid_abort.c
  CC              mpid_cancel_recv.c
  CC              mpid_cancel_send.c
  CC              mpid_comm_disconnect.c
  CC              mpid_comm_spawn_multiple.c
  CC              mpid_finalize.c
  CC              mpid_get_universe_size.c
  CC              mpid_getpname.c
  CC              mpid_init.c
  CC              mpid_iprobe.c
  CC              mpid_irecv.c
  CC              mpid_irsend.c
  CC              mpid_isend.c
  CC              mpid_issend.c
  CC              mpid_port.c
  CC              mpid_probe.c
  CC              mpid_recv.c
  CC              mpid_rsend.c
  CC              mpid_send.c
  CC              mpid_ssend.c
  CC              mpid_startall.c
  CC              mpid_vc.c
  CC              mpid_rma.c
  CC              mpidi_isend_self.c
  CC              mpidi_pg.c
  CC              mpidi_printf.c
  AR cr ../../../../lib/libmpich.a ch3u_buffer.o ch3u_comm_spawn_multiple.o ch3u_handle_connection.o ch3u_handle_recv_pkt.o ch3u_handle_recv_req.o ch3u_handle_send_req.o ch3u_port.o ch3u_recvq.o ch3u_request.o ch3u_rma_ops.o ch3u_rma_sync.o ch3u_rndv.o ch3u_eager.o ch3u_eagersync.o mpid_abort.o mpid_cancel_recv.o mpid_cancel_send.o mpid_comm_disconnect.o mpid_comm_spawn_multiple.o mpid_finalize.o mpid_get_universe_size.o mpid_getpname.o mpid_init.o mpid_iprobe.o mpid_irecv.o mpid_irsend.o mpid_isend.o mpid_issend.o mpid_port.o mpid_probe.o mpid_recv.o mpid_rsend.o mpid_send.o mpid_ssend.o mpid_startall.o mpid_vc.o mpid_rma.o mpidi_isend_self.o mpidi_pg.o mpidi_printf.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/src »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/util »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3/util »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid/ch3 »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpid »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/attr »
  CC              attr_delete.c
  CC              attr_get.c
  CC              attr_put.c
  CC              comm_create_keyval.c
  CC              comm_delete_attr.c
  CC              comm_free_keyval.c
  CC              comm_get_attr.c
  CC              comm_set_attr.c
  CC              keyval_create.c
  CC              keyval_free.c
  CC              type_create_keyval.c
  CC              type_delete_attr.c
  CC              type_free_keyval.c
  CC              type_get_attr.c
  CC              type_set_attr.c
  CC              win_create_keyval.c
  CC              win_delete_attr.c
  CC              win_free_keyval.c
  CC              win_get_attr.c
  CC              win_set_attr.c
  CC              attrutil.c
  CC              dup_fn.c
  AR cr ../../../lib/libmpich.a attr_delete.o attr_get.o attr_put.o comm_create_keyval.o comm_delete_attr.o comm_free_keyval.o comm_get_attr.o comm_set_attr.o keyval_create.o keyval_free.o type_create_keyval.o type_delete_attr.o type_free_keyval.o type_get_attr.o type_set_attr.o win_create_keyval.o win_delete_attr.o win_free_keyval.o win_get_attr.o win_set_attr.o attrutil.o dup_fn.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/attr »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/coll »
  CC              allreduce.c
  CC              barrier.c
  CC              op_create.c
  CC              op_free.c
  CC              bcast.c
  CC              alltoall.c
  CC              alltoallv.c
  CC              reduce.c
  CC              scatter.c
  CC              gather.c
  CC              scatterv.c
  CC              gatherv.c
  CC              scan.c
  CC              exscan.c
  CC              allgather.c
  CC              allgatherv.c
  CC              red_scat.c
  CC              alltoallw.c
  CC              reduce_local.c
  CC              op_commutative.c
  CC              red_scat_block.c
  CC              helper_fns.c
  CC              opsum.c
  CC              opmax.c
  CC              opmin.c
  CC              opband.c
  CC              opbor.c
  CC              opbxor.c
  CC              opland.c
  CC              oplor.c
  CC              oplxor.c
  CC              opprod.c
  CC              opminloc.c
  CC              opmaxloc.c
  AR cr ../../../lib/libmpich.a allreduce.o barrier.o op_create.o op_free.o bcast.o alltoall.o alltoallv.o reduce.o scatter.o gather.o scatterv.o gatherv.o scan.o exscan.o allgather.o allgatherv.o red_scat.o alltoallw.o reduce_local.o op_commutative.o red_scat_block.o helper_fns.o opsum.o opmax.o opmin.o opband.o opbor.o opbxor.o opland.o oplor.o oplxor.o opprod.o opminloc.o opmaxloc.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/coll »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/comm »
  CC              comm_compare.c
  CC              comm_create.c
  CC              comm_dup.c
  CC              comm_free.c
  CC              comm_get_name.c
  CC              comm_group.c
  CC              comm_rank.c
  CC              comm_size.c
  CC              comm_remote_group.c
  CC              comm_remote_size.c
  CC              comm_set_name.c
  CC              comm_split.c
  CC              comm_test_inter.c
  CC              intercomm_create.c
  CC              intercomm_merge.c
  CC              commutil.c
  AR cr ../../../lib/libmpich.a comm_compare.o comm_create.o comm_dup.o comm_free.o comm_get_name.o comm_group.o comm_rank.o comm_size.o comm_remote_group.o comm_remote_size.o comm_set_name.o comm_split.o comm_test_inter.o intercomm_create.o intercomm_merge.o commutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/comm »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/datatype »
  CC              address.c
  CC              get_address.c
  CC              get_count.c
  CC              get_elements.c
  CC              pack.c
  CC              unpack.c
  CC              pack_size.c
  CC              status_set_elements.c
  CC              type_get_name.c
  CC              type_set_name.c
  CC              type_size.c
  CC              type_extent.c
  CC              type_vector.c
  CC              type_commit.c
  CC              type_indexed.c
  CC              type_hindexed.c
  CC              type_struct.c
  CC              type_contiguous.c
  CC              type_free.c
  CC              type_hvector.c
  CC              type_dup.c
  CC              type_get_envelope.c
  CC              type_get_contents.c
  CC              type_ub.c
  CC              type_lb.c
  CC              type_get_extent.c
  CC              type_get_true_extent.c
  CC              type_match_size.c
  CC              type_create_struct.c
  CC              type_create_hindexed.c
  CC              type_create_hvector.c
  CC              pack_external.c
  CC              pack_external_size.c
  CC              unpack_external.c
  CC              type_create_indexed_block.c
  CC              type_create_resized.c
  CC              type_create_darray.c
  CC              type_create_subarray.c
  CC              typeutil.c
  AR cr ../../../lib/libmpich.a address.o get_address.o get_count.o get_elements.o pack.o unpack.o pack_size.o status_set_elements.o type_get_name.o type_set_name.o type_size.o type_extent.o type_vector.o type_commit.o type_indexed.o type_hindexed.o type_struct.o type_contiguous.o type_free.o type_hvector.o type_dup.o type_get_envelope.o type_get_contents.o type_ub.o type_lb.o type_get_extent.o type_get_true_extent.o type_match_size.o type_create_struct.o type_create_hindexed.o type_create_hvector.o pack_external.o pack_external_size.o unpack_external.o type_create_indexed_block.o type_create_resized.o type_create_darray.o type_create_subarray.o typeutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/datatype »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/errhan »
  CC              add_error_code.c
  CC              add_error_class.c
  CC              add_error_string.c
  CC              comm_call_errhandler.c
  CC              comm_create_errhandler.c
  CC              comm_get_errhandler.c
  CC              comm_set_errhandler.c
  CC              errhandler_create.c
  CC              errhandler_free.c
  CC              errhandler_get.c
  CC              errhandler_set.c
  CC              error_class.c
  CC              error_string.c
  CC              file_create_errhandler.c
  CC              file_get_errhandler.c
  CC              file_set_errhandler.c
  CC              file_call_errhandler.c
  CC              win_create_errhandler.c
  CC              win_call_errhandler.c
  CC              win_get_errhandler.c
  CC              win_set_errhandler.c
  CC              errutil.c
  CC              dynerrutil.c
  AR cr ../../../lib/libmpich.a add_error_code.o add_error_class.o add_error_string.o comm_call_errhandler.o comm_create_errhandler.o comm_get_errhandler.o comm_set_errhandler.o errhandler_create.o errhandler_free.o errhandler_get.o errhandler_set.o error_class.o error_string.o file_create_errhandler.o file_get_errhandler.o file_set_errhandler.o file_call_errhandler.o win_create_errhandler.o win_call_errhandler.o win_get_errhandler.o win_set_errhandler.o errutil.o dynerrutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/errhan »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/group »
  CC              group_compare.c
  CC              group_difference.c
  CC              group_excl.c
  CC              group_free.c
  CC              group_incl.c
  CC              group_intersection.c
  CC              group_range_excl.c
  CC              group_range_incl.c
  CC              group_rank.c
  CC              group_size.c
  CC              group_translate_ranks.c
  CC              group_union.c
  CC              grouputil.c
  AR cr ../../../lib/libmpich.a group_compare.o group_difference.o group_excl.o group_free.o group_incl.o group_intersection.o group_range_excl.o group_range_incl.o group_rank.o group_size.o group_translate_ranks.o group_union.o grouputil.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/group »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/init »
  CC              abort.c
  CC              init.c
  CC              initialized.c
  CC              initthread.c
  CC              ismain.c
  CC              finalize.c
  CC              finalized.c
  CC              querythread.c
  CC              initinfo.c
  CC              async.c
  AR cr ../../../lib/libmpich.a abort.o init.o initialized.o initthread.o ismain.o finalize.o finalized.o querythread.o initinfo.o async.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/init »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/misc »
  CC              getpname.c
  CC              pcontrol.c
  CC              version.c
  AR cr ../../../lib/libmpich.a getpname.o pcontrol.o version.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/misc »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/pt2pt »
  CC              bsend.c
  CC              bsend_init.c
  CC              bufattach.c
  CC              buffree.c
  CC              cancel.c
  CC              greq_start.c
  CC              greq_complete.c
  CC              ibsend.c
  CC              iprobe.c
  CC              irecv.c
  CC              irsend.c
  CC              isend.c
  CC              issend.c
  CC              probe.c
  CC              recv.c
  CC              recv_init.c
  CC              request_free.c
  CC              request_get_status.c
  CC              rsend.c
  CC              rsend_init.c
  CC              send.c
  CC              send_init.c
  CC              sendrecv.c
  CC              sendrecv_rep.c
  CC              status_set_cancelled.c
  CC              ssend.c
  CC              ssend_init.c
  CC              start.c
  CC              startall.c
  CC              test.c
  CC              test_cancelled.c
  CC              testall.c
  CC              testany.c
  CC              testsome.c
  CC              wait.c
  CC              waitall.c
  CC              waitany.c
  CC              waitsome.c
  CC              bsendutil.c
  CC              mpir_request.c
  AR cr ../../../lib/libmpich.a bsend.o bsend_init.o bufattach.o buffree.o cancel.o greq_start.o greq_complete.o ibsend.o iprobe.o irecv.o irsend.o isend.o issend.o probe.o recv.o recv_init.o request_free.o request_get_status.o rsend.o rsend_init.o send.o send_init.o sendrecv.o sendrecv_rep.o status_set_cancelled.o ssend.o ssend_init.o start.o startall.o test.o test_cancelled.o testall.o testany.o testsome.o wait.o waitall.o waitany.o waitsome.o bsendutil.o mpir_request.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/pt2pt »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/rma »
  CC              accumulate.c
  CC              alloc_mem.c
  CC              free_mem.c
  CC              get.c
  CC              put.c
  CC              win_complete.c
  CC              win_create.c
  CC              win_fence.c
  CC              win_free.c
  CC              win_get_group.c
  CC              win_get_name.c
  CC              win_lock.c
  CC              win_post.c
  CC              win_set_name.c
  CC              win_start.c
  CC              win_unlock.c
  CC              win_wait.c
  CC              win_test.c
  CC              winutil.c
  AR cr ../../../lib/libmpich.a accumulate.o alloc_mem.o free_mem.o get.o put.o win_complete.o win_create.o win_fence.o win_free.o win_get_group.o win_get_name.o win_lock.o win_post.o win_set_name.o win_start.o win_unlock.o win_wait.o win_test.o winutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/rma »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/spawn »
  CC              comm_disconnect.c
  CC              comm_get_parent.c
  CC              comm_join.c
  CC              comm_spawn.c
  CC              comm_spawn_multiple.c
  CC              lookup_name.c
  CC              publish_name.c
  CC              unpublish_name.c
  CC              open_port.c
  CC              close_port.c
  CC              comm_connect.c
  CC              comm_accept.c
  AR cr ../../../lib/libmpich.a comm_disconnect.o comm_get_parent.o comm_join.o comm_spawn.o comm_spawn_multiple.o lookup_name.o publish_name.o unpublish_name.o open_port.o close_port.o comm_connect.o comm_accept.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/spawn »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/timer »
  CC              wtime.c
  CC              wtick.c
  CC              mpidtime.c
  AR cr ../../../lib/libmpich.a wtime.o wtick.o mpidtime.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/timer »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/topo »
  CC              cart_coords.c
  CC              cart_create.c
  CC              cart_get.c
  CC              cart_map.c
  CC              cart_rank.c
  CC              cart_shift.c
  CC              cart_sub.c
  CC              dims_create.c
  CC              graph_get.c
  CC              graph_map.c
  CC              graph_nbr.c
  CC              graphcreate.c
  CC              graphdimsget.c
  CC              graphnbrcnt.c
  CC              cartdim_get.c
  CC              topo_test.c
  CC              dist_gr_create_adj.c
  CC              dist_gr_create.c
  CC              dist_gr_neighb_count.c
  CC              dist_gr_neighb.c
  CC              topoutil.c
  AR cr ../../../lib/libmpich.a cart_coords.o cart_create.o cart_get.o cart_map.o cart_rank.o cart_shift.o cart_sub.o dims_create.o graph_get.o graph_map.o graph_nbr.o graphcreate.o graphdimsget.o graphnbrcnt.o cartdim_get.o topo_test.o dist_gr_create_adj.o dist_gr_create.o dist_gr_neighb_count.o dist_gr_neighb.o topoutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/topo »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio »
make mpiolib
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio »
compiling ROMIO in directory mpi-io
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/mpi-io »
  CC              close.c
  CC              read.c
  CC              open.c
  CC              write.c
  CC              set_view.c
  CC              iread.c
  CC              iwrite.c
  CC              seek.c
  CC              get_posn.c
  CC              delete.c
  CC              read_all.c
  CC              read_at.c
  CC              read_atall.c
  CC              iread_at.c
  CC              iwrite_at.c
  CC              write_all.c
  CC              get_bytoff.c
  CC              write_at.c
  CC              write_atall.c
  CC              get_view.c
  CC              get_group.c
  CC              get_amode.c
  CC              get_extent.c
  CC              fsync.c
  CC              get_atom.c
  CC              set_atom.c
  CC              set_size.c
  CC              get_size.c
  CC              prealloc.c
  CC              file_f2c.c
  CC              file_c2f.c
  CC              set_info.c
  CC              get_info.c
  CC              rd_atallb.c
  CC              rd_atalle.c
  CC              read_allb.c
  CC              read_alle.c
  CC              wr_atallb.c
  CC              wr_atalle.c
  CC              write_allb.c
  CC              write_alle.c
  CC              get_posn_sh.c
  CC              iread_sh.c
  CC              read_sh.c
  CC              write_sh.c
  CC              iwrite_sh.c
  CC              seek_sh.c
  CC              read_ord.c
  CC              read_orde.c
  CC              write_ordb.c
  CC              read_ordb.c
  CC              write_ord.c
  CC              write_orde.c
  CC              mpiu_greq.c
  CC              mpich2_fileutil.c
  CC              register_datarep.c
  CC              mpir-mpioinit.c
ar cr /user/pvm/mpich2-1.4.1p1/lib/libmpich.a close.o read.o open.o write.o set_view.o iread.o iwrite.o seek.o get_posn.o delete.o read_all.o read_at.o read_atall.o iread_at.o iwrite_at.o write_all.o get_bytoff.o write_at.o write_atall.o get_view.o get_group.o get_amode.o get_extent.o fsync.o get_atom.o set_atom.o set_size.o get_size.o prealloc.o file_f2c.o file_c2f.o set_info.o get_info.o rd_atallb.o rd_atalle.o read_allb.o read_alle.o wr_atallb.o wr_atalle.o write_allb.o write_alle.o get_posn_sh.o iread_sh.o read_sh.o write_sh.o iwrite_sh.o seek_sh.o read_ord.o read_orde.o write_ordb.o read_ordb.o write_ord.o write_orde.o mpiu_greq.o mpich2_fileutil.o register_datarep.o mpir-mpioinit.o
ranlib /user/pvm/mpich2-1.4.1p1/lib/libmpich.a
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/mpi-io »
compiling ROMIO in directory adio/common
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/adio/common »
  CC              ad_close.c
  CC              ad_init.c
  CC              ad_end.c
  CC              ad_open.c
  CC              flatten.c
  CC              malloc.c
  CC              ad_read_coll.c
  CC              eof_offset.c
  CC              ad_write_coll.c
  CC              lock.c
  CC              ad_read_str.c
  CC              ad_write_str.c
  CC              iscontig.c
  CC              get_fp_posn.c
  CC              ad_seek.c
  CC              ad_delete.c
  CC              ad_flush.c
  CC              ad_hints.c
  CC              error.c
  CC              ad_fstype.c
  CC              ad_get_sh_fp.c
  CC              ad_set_sh_fp.c
  CC              shfp_fname.c
  CC              byte_offset.c
  CC              status_setb.c
  CC              ad_aggregate.c
  CC              cb_config_list.c
  CC              ad_read_str_naive.c
  CC              ad_set_view.c
  CC              ad_iopen.c
  CC              ad_write_str_naive.c
  CC              ad_resize.c
  CC              ad_read.c
  CC              ad_write.c
  CC              ad_iread.c
  CC              ad_iwrite.c
  CC              ad_done.c
  CC              ad_wait.c
  CC              adi_close.c
  CC              ad_prealloc.c
  CC              ad_fcntl.c
  CC              ad_iread_fake.c
  CC              ad_iwrite_fake.c
  CC              ad_done_fake.c
  CC              ad_wait_fake.c
  CC              ad_subarray.c
  CC              ad_darray.c
  CC              strfns.c
  CC              greq_fns.c
  CC              system_hints.c
  CC              ad_write_nolock.c
  CC              ad_coll_exch_new.c
  CC              ad_coll_build_req_new.c
  CC              ad_io_coll.c
  CC              ad_aggregate_new.c
  CC              heap-sort.c
  CC              ad_opencoll.c
  CC              ad_opencoll_scalable.c
  CC              ad_opencoll_failsafe.c
  CC              ad_features.c
ar cr /user/pvm/mpich2-1.4.1p1/lib/libmpich.a ad_close.o ad_init.o ad_end.o ad_open.o flatten.o malloc.o ad_read_coll.o eof_offset.o ad_write_coll.o lock.o ad_read_str.o ad_write_str.o iscontig.o get_fp_posn.o ad_seek.o ad_delete.o ad_flush.o ad_hints.o error.o ad_fstype.o ad_get_sh_fp.o ad_set_sh_fp.o shfp_fname.o byte_offset.o status_setb.o ad_aggregate.o cb_config_list.o ad_read_str_naive.o ad_set_view.o ad_iopen.o ad_write_str_naive.o ad_resize.o ad_read.o ad_write.o ad_iread.o ad_iwrite.o ad_done.o ad_wait.o adi_close.o ad_prealloc.o ad_fcntl.o ad_iread_fake.o ad_iwrite_fake.o ad_done_fake.o ad_wait_fake.o ad_subarray.o ad_darray.o strfns.o greq_fns.o system_hints.o ad_write_nolock.o ad_coll_exch_new.o ad_coll_build_req_new.o ad_io_coll.o ad_aggregate_new.o heap-sort.o ad_opencoll.o ad_opencoll_scalable.o ad_opencoll_failsafe.o ad_features.o
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/adio/common »
compiling ROMIO in directory mpi-io/glue/mpich2
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2 »
  CC              mpio_file.c
  CC              mpio_err.c
ar cr /user/pvm/mpich2-1.4.1p1/lib/libmpich.a mpio_file.o mpio_err.o
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2 »
compiling ROMIO in directory adio/ad_testfs
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs »
  CC              ad_testfs_close.c
  CC              ad_testfs_read.c
  CC              ad_testfs_rdcoll.c
  CC              ad_testfs_wrcoll.c
  CC              ad_testfs_open.c
  CC              ad_testfs_write.c
  CC              ad_testfs_done.c
  CC              ad_testfs_fcntl.c
  CC              ad_testfs_iread.c
  CC              ad_testfs_iwrite.c
  CC              ad_testfs_wait.c
  CC              ad_testfs_flush.c
  CC              ad_testfs_seek.c
  CC              ad_testfs_resize.c
  CC              ad_testfs_hints.c
  CC              ad_testfs_delete.c
  CC              ad_testfs.c
ar cr /user/pvm/mpich2-1.4.1p1/lib/libmpich.a ad_testfs_close.o ad_testfs_read.o ad_testfs_rdcoll.o ad_testfs_wrcoll.o ad_testfs_open.o ad_testfs_write.o ad_testfs_done.o ad_testfs_fcntl.o ad_testfs_iread.o ad_testfs_iwrite.o ad_testfs_wait.o ad_testfs_flush.o ad_testfs_seek.o ad_testfs_resize.o ad_testfs_hints.o ad_testfs_delete.o ad_testfs.o
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs »
compiling ROMIO in directory adio/ad_ufs
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/adio/ad_ufs »
  CC              ad_ufs_open.c
  CC              ad_ufs.c
ar cr /user/pvm/mpich2-1.4.1p1/lib/libmpich.a ad_ufs_open.o ad_ufs.o
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/adio/ad_ufs »
compiling ROMIO in directory adio/ad_nfs
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs »
  CC              ad_nfs_read.c
  CC              ad_nfs_open.c
  CC              ad_nfs_write.c
  CC              ad_nfs_done.c
  CC              ad_nfs_fcntl.c
  CC              ad_nfs_iread.c
  CC              ad_nfs_iwrite.c
  CC              ad_nfs_wait.c
  CC              ad_nfs_setsh.c
  CC              ad_nfs_getsh.c
  CC              ad_nfs.c
  CC              ad_nfs_resize.c
  CC              ad_nfs_features.c
ar cr /user/pvm/mpich2-1.4.1p1/lib/libmpich.a ad_nfs_read.o ad_nfs_open.o ad_nfs_write.o ad_nfs_done.o ad_nfs_fcntl.o ad_nfs_iread.o ad_nfs_iwrite.o ad_nfs_wait.o ad_nfs_setsh.o ad_nfs_getsh.o ad_nfs.o ad_nfs_resize.o ad_nfs_features.o
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi/romio »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpi »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpix »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpix/comm »
  CC              group_comm.c
  AR cr ../../../lib/libmpich.a group_comm.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpix/comm »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpix »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/mem »
  CC              trmem.c
  CC              handlemem.c
  CC              safestr.c
  CC              argstr.c
  CC              strerror.c
  AR cr ../../../lib/libmpich.a trmem.o handlemem.o safestr.o argstr.o strerror.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/mem »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/info »
  CC              infoutil.c
  CC              info_create.c
  CC              info_delete.c
  CC              info_dup.c
  CC              info_free.c
  CC              info_get.c
  CC              info_getn.c
  CC              info_getnth.c
  CC              info_getvallen.c
  CC              info_set.c
  AR cr ../../../lib/libmpich.a infoutil.o info_create.o info_delete.o info_dup.o info_free.o info_get.o info_getn.o info_getnth.o info_getvallen.o info_set.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/info »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/msgs »
  CC              msgprint.c
  AR cr ../../../lib/libmpich.a msgprint.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/msgs »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/instrm »
  CC              states.c
  CC              instr.c
  AR cr ../../../lib/libmpich.a states.o instr.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/instrm »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/thread »
  CC              mpiu_thread.c
  AR cr ../../../lib/libmpich.a mpiu_thread.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/thread »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/dbg »
  CC              dbg_printf.c
  CC              timelimit.c
  CC              exit.c
  AR cr ../../../lib/libmpich.a dbg_printf.o timelimit.o exit.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/dbg »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/param »
  CC              param_vals.c
  AR cr ../../../lib/libmpich.a param_vals.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/param »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/osserv »
  CC              dl.c
  AR cr ../../../lib/libmpich.a dl.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/osserv »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/procmap »
  CC              local_proc.c
  AR cr ../../../lib/libmpich.a local_proc.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/procmap »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/other »
  CC              outliers.c
  CC              assert.c
  AR cr ../../../lib/libmpich.a outliers.o assert.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/other »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging/rlog »
  CC              rlog.c
  CC              rlogutil.c
  CC              rlogtime.c
  CC              irlogutil.c
  AR cr ../../../../lib/libmpich.a rlog.o rlogutil.o rlogtime.o irlogutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging/rlog »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging/common »
make[4]: Rien à faire pour « all ».
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging/common »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util/logging »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/util »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/nameserv »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/nameserv/file »
  CC              file_nameserv.c
  AR cr ../../../lib/libmpich.a file_nameserv.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/nameserv/file »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/nameserv »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/binding »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/binding »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/env »
  CC              mpich2version.c
gcc -O2   -o mpich2version mpich2version.o  \
	../../lib/libmpich.a -lrt -lpthread
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/env »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging/pkgconfig »
make[3]: Rien à faire pour « all ».
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging/pkgconfig »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging/envmods »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging/envmods »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/packaging »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpe2 »
make --no-print-directory  build_lib_bin
**** Making src/misc ....
make --no-print-directory  mpe_debug_objs
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a
gcc -I.. -I../include -I../../.. -I../../../include -O2 -DMPI_LINUX  -DMPE_NOMPI -o mpehname.no -c mpehname.c
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a mpehname.no
ranlib /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o decomp.po -c decomp.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o mpe_seq.po -c mpe_seq.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o dbxerr.po -c dbxerr.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o getgrank.po -c getgrank.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o examine.po -c examine.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o privtags.po -c privtags.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o mpehname.po -c mpehname.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o mpe_io.po -c mpe_io.c
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a decomp.po mpe_seq.po dbxerr.po getgrank.po examine.po privtags.po mpehname.po mpe_io.po
ranlib /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a
**** Making src/callstack ....
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -o iterator.po -c iterator.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -o fancyprint.po -c fancyprint.c
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include -O2  -o iterator.no -c iterator.c
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include -O2  -o fancyprint.no -c fancyprint.c
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a iterator.no fancyprint.no
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a iterator.po fancyprint.po
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/bin/check_callstack
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include -O2  -o check_callstack.no -c check_callstack.c
cp -f check_callstack.no mpe2tmp.o
gcc -Wl,--export-dynamic -O2  -o /user/pvm/mpich2-1.4.1p1/src/mpe2/bin/check_callstack mpe2tmp.o \
	                         -L/user/pvm/mpich2-1.4.1p1/src/mpe2/lib -lmpe_nompi
**** Making src/logging ....
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpi_null.no -c mpi_null.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_util.no -c clog_util.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_timer.no -c clog_timer.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_uuid.no -c clog_uuid.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_commset.no -c clog_commset.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_preamble.no -c clog_preamble.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_record.no -c clog_record.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_sync.no -c clog_sync.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_block.no -c clog_block.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_buffer.no -c clog_buffer.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_merger.no -c clog_merger.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_cache.no -c clog_cache.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_joiner.no -c clog_joiner.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog.no -c clog.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_thread.no -c mpe_log_thread.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log.no -c mpe_log.c
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_null.no -c mpe_log_null.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o mpe_log_null.po -c mpe_log_null.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_util.po -c clog_util.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_timer.po -c clog_timer.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_uuid.po -c clog_uuid.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_commset.po -c clog_commset.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_preamble.po -c clog_preamble.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_record.po -c clog_record.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_sync.po -c clog_sync.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_block.po -c clog_block.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_buffer.po -c clog_buffer.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_merger.po -c clog_merger.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_cache.po -c clog_cache.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_joiner.po -c clog_joiner.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog.po -c clog.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o mpe_log_thread.po -c mpe_log_thread.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o mpe_log.po -c mpe_log.c
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a mpi_null.no clog_util.no clog_timer.no clog_uuid.no clog_commset.no clog_preamble.no clog_record.no clog_sync.no clog_block.no clog_buffer.no clog_merger.no clog_cache.no clog_joiner.no clog.no mpe_log_thread.no mpe_log.no
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi_null.a
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi_null.a mpi_null.no mpe_log_null.no
ranlib /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi_null.a
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_null.a
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_null.a mpe_log_null.po
ranlib /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_null.a
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a clog_util.po clog_timer.po clog_uuid.po clog_commset.po clog_preamble.po clog_record.po clog_sync.po clog_block.po clog_buffer.po clog_merger.po clog_cache.po clog_joiner.po clog.po mpe_log_thread.po mpe_log.po
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/bin/clog2_print /user/pvm/mpich2-1.4.1p1/src/mpe2/bin/clog2_join /user/pvm/mpich2-1.4.1p1/src/mpe2/bin/clog2_repair
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_print.no -c clog_print.c
cp -f clog_print.no mpe2tmp1.o
gcc  -O2  -o /user/pvm/mpich2-1.4.1p1/src/mpe2/bin/clog2_print mpe2tmp1.o \
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_join.no -c clog_join.c
cp -f clog_join.no mpe2tmp2.o
gcc  -O2  -o /user/pvm/mpich2-1.4.1p1/src/mpe2/bin/clog2_join mpe2tmp2.o \
gcc -I.. -I../../.. -I../include -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_repair.no -c clog_repair.c
cp -f clog_repair.no mpe2tmp3.o
gcc  -O2  -o /user/pvm/mpich2-1.4.1p1/src/mpe2/bin/clog2_repair mpe2tmp3.o \
**** Making src/wrappers ....
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c log_mpi_util.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c log_mpi_core.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c trace_mpi_core.c
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/liblmpe.a
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/liblmpe.a log_mpi_util.o log_mpi_core.o
ranlib /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/liblmpe.a
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libtmpe.a
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libtmpe.a trace_mpi_core.o
ranlib /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libtmpe.a
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/mpe_prof.o
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c mpe_prof.c
make --no-print-directory  linktest_all
make --no-print-directory  linktest_C
make --no-print-directory  linktest_F77
**** Making src/graphics ....
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o mpe_graphics.no -c mpe_graphics.c
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xcolor.no -c xcolor.c
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xframe.no -c xframe.c
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xinit.no -c xinit.c
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xwmap.no -c xwmap.c
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xmouse.no -c xmouse.c
gcc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xkey.no -c xkey.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include    -o mpe_graphics.po -c mpe_graphics.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include    -o xcolor.po -c xcolor.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include    -o xframe.po -c xframe.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include    -o xinit.po -c xinit.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include    -o xwmap.po -c xwmap.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include    -o xmouse.po -c xmouse.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include    -o xkey.po -c xkey.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include    -o visual_mess.po -c visual_mess.c
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a mpe_graphics.no xcolor.no xframe.no xinit.no xwmap.no xmouse.no xkey.no
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a mpe_graphics.po xcolor.po xframe.po xinit.po xwmap.po xmouse.po xkey.po
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libampe.a
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libampe.a visual_mess.po
ranlib /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libampe.a
**** Making src/collchk ....
make --no-print-directory  /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_collchk.a
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c begin.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c err_han.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c is_init.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c check_buff.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c check_dims.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c check_graph.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c check_size.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_amode.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_call.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_dtype.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_high_low.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_int.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_local_leader.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_op.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_root.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_tag.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_datarep.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_whence.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c allgather.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c allgatherv.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c allreduce.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c alltoall.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c alltoallv.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c barrier.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c bcast.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c cart_create.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c cart_map.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c gather.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c gatherv.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c graph_create.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c graph_map.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c init.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c intercomm_create.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c intercomm_merge.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c reduce.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c reduce_scatter.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c scan.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c scatter.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c scatterv.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c finalize.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c exscan.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c alltoallw.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_open.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_preallocate.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all_begin.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all_end.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all_begin.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all_end.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered_begin.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered_end.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_seek_shared.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_set_atomicity.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_set_size.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_set_view.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all_begin.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all_end.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all_begin.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all_end.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered_begin.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered_end.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c add_fh.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c get_fh.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c win_create.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c win_fence.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c add_win.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c get_win.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_accept.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_connect.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_create.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_disconnect.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_dup.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_spawn.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_spawn_multiple.c
/user/pvm/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/user/pvm/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_split.c
ar cr /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_collchk.a *.o
ranlib /user/pvm/mpich2-1.4.1p1/src/mpe2/lib/libmpe_collchk.a
**** Making src/slog2sdk ....
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpe2 »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pmi »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pmi/simple »
  CC              simple_pmiutil.c
  CC              simple_pmi.c
  AR cr ../../../lib/libmpich.a simple_pmiutil.o simple_pmi.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pmi/simple »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pmi »
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra »
Making all in ../../mpl
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
Making all in tools/topo/plpa/plpa
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa »
Making all in src
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src »
Making all in libplpa
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa »
make  all-am
make[7]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa »
depbase=`echo plpa_api_probe.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
	/bin/bash ../../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.   -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers  -O2  -MT plpa_api_probe.lo -MD -MP -MF $depbase.Tpo -c -o plpa_api_probe.lo plpa_api_probe.c &&\
	mv -f $depbase.Tpo $depbase.Plo
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -O2 -MT plpa_api_probe.lo -MD -MP -MF .deps/plpa_api_probe.Tpo -c plpa_api_probe.c -o plpa_api_probe.o
depbase=`echo plpa_dispatch.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
	/bin/bash ../../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.   -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers  -O2  -MT plpa_dispatch.lo -MD -MP -MF $depbase.Tpo -c -o plpa_dispatch.lo plpa_dispatch.c &&\
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -O2 -MT plpa_dispatch.lo -MD -MP -MF .deps/plpa_dispatch.Tpo -c plpa_dispatch.c -o plpa_dispatch.o
depbase=`echo plpa_runtime.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
	/bin/bash ../../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.   -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers  -O2  -MT plpa_runtime.lo -MD -MP -MF $depbase.Tpo -c -o plpa_runtime.lo plpa_runtime.c &&\
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -O2 -MT plpa_runtime.lo -MD -MP -MF .deps/plpa_runtime.Tpo -c plpa_runtime.c -o plpa_runtime.o
depbase=`echo plpa_map.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
	/bin/bash ../../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.   -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers  -O2  -MT plpa_map.lo -MD -MP -MF $depbase.Tpo -c -o plpa_map.lo plpa_map.c &&\
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/mpl/include -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/openpa/src -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/datatype -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/common/locks -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -I/user/pvm/mpich2-1.4.1p1/src/util/wrappers -O2 -MT plpa_map.lo -MD -MP -MF .deps/plpa_map.Tpo -c plpa_map.c -o plpa_map.o
/bin/bash ../../libtool --tag=CC   --mode=link gcc  -O2   -lnsl -o libplpa_included.la  plpa_api_probe.lo plpa_dispatch.lo plpa_runtime.lo plpa_map.lo  -lrt -lpthread
libtool: link: ar cr .libs/libplpa_included.a  plpa_api_probe.o plpa_dispatch.o plpa_runtime.o plpa_map.o
libtool: link: ranlib .libs/libplpa_included.a
libtool: link: ( cd ".libs" && rm -f "libplpa_included.la" && ln -s "../libplpa_included.la" "libplpa_included.la" )
make[7]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa »
Making all in plpa-info
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-info »
make[6]: Rien à faire pour « all ».
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-info »
Making all in plpa-taskset
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-taskset »
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-taskset »
make[6]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src »
make[6]: Rien à faire pour « all-am ».
make[6]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa »
make[5]: Rien à faire pour « all-am ».
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa »
Making all in tools/topo/hwloc/hwloc
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc »
Making all in src
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/src »
  CC     topology.lo
  CC     traversal.lo
  CC     distances.lo
  CC     topology-synthetic.lo
  CC     bind.lo
  CC     cpuset.lo
  CC     misc.lo
  CC     topology-linux.lo
  CC     topology-x86.lo
  CCLD   libhwloc_embedded.la
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/src »
Making all in include
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/include »
make[5]: Rien à faire pour « all ».
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/include »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc »
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc »
Making all in .
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra »
  CC     alloc.lo
  CC     args.lo
  CC     dbg.lo
  CC     env.lo
  CC     launch.lo
  CC     others.lo
  CC     signals.lo
  CC     sock.lo
  CC     string.lo
  CC     topo.lo
  CC     topo_plpa.lo
  CC     topo_hwloc.lo
./tools/topo/hwloc/topo_hwloc.c: In function ‘hwloc_to_hydra_cpuset_dup’:
./tools/topo/hwloc/topo_hwloc.c:56: warning: ‘hwloc_cpuset_isset’ is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:49)
./tools/topo/hwloc/topo_hwloc.c: In function ‘hydra_to_hwloc_cpuset_dup’:
./tools/topo/hwloc/topo_hwloc.c:70: warning: ‘hwloc_cpuset_zero’ is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:36)
./tools/topo/hwloc/topo_hwloc.c:73: warning: ‘hwloc_cpuset_set’ is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:44)
./tools/topo/hwloc/topo_hwloc.c: In function ‘get_cache_nbobjs’:
./tools/topo/hwloc/topo_hwloc.c:86: warning: ‘hwloc_cpuset_compare’ is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:65)
./tools/topo/hwloc/topo_hwloc.c: In function ‘load_cache_objs’:
./tools/topo/hwloc/topo_hwloc.c:100: warning: ‘hwloc_cpuset_compare’ is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:65)
./tools/topo/hwloc/topo_hwloc.c: In function ‘HYDT_topo_hwloc_bind’:
./tools/topo/hwloc/topo_hwloc.c:329: warning: ‘hwloc_cpuset_alloc’ is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:29)
./tools/topo/hwloc/topo_hwloc.c:337: warning: ‘hwloc_cpuset_free’ is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:30)
  CC     bsci_init.lo
  CC     bsci_finalize.lo
  CC     bsci_launch.lo
  CC     bsci_query_node_list.lo
  CC     bsci_query_job_id.lo
  CC     bsci_query_proxy_id.lo
  CC     bsci_query_native_int.lo
  CC     bsci_wait.lo
  CC     bsci_env.lo
  CC     bscu_wait.lo
  CC     bscu_cb.lo
  CC     external_common.lo
  CC     external_common_launch.lo
  CC     fork_init.lo
  CC     user_init.lo
  CC     manual_init.lo
  CC     rsh_init.lo
  CC     rsh_env.lo
  CC     ssh_init.lo
  CC     ssh.lo
  CC     ssh_env.lo
  CC     ssh_finalize.lo
  CC     slurm_init.lo
  CC     slurm_launch.lo
  CC     slurm_env.lo
  CC     slurm_query_native_int.lo
  CC     slurm_query_node_list.lo
  CC     slurm_query_proxy_id.lo
  CC     slurm_query_jobid.lo
  CC     ll_init.lo
  CC     ll_launch.lo
  CC     ll_query_native_int.lo
  CC     ll_query_node_list.lo
  CC     ll_query_proxy_id.lo
  CC     ll_env.lo
  CC     lsf_init.lo
  CC     lsf_query_native_int.lo
  CC     lsf_query_node_list.lo
  CC     lsf_env.lo
  CC     sge_init.lo
  CC     sge_query_native_int.lo
  CC     sge_query_node_list.lo
  CC     sge_env.lo
  CC     pbs_init.lo
  CC     pbs_query_native_int.lo
  CC     pbs_query_node_list.lo
  CC     pbs_query_jobid.lo
  CC     persist_init.lo
  CC     persist_launch.lo
  CC     persist_wait.lo
  CC     ckpoint.lo
  CC     demux.lo
  CC     demux_poll.lo
  CC     demux_select.lo
  CC     debugger.lo
  CC     hydt_ftb_dummy.lo
  CC     uiu.lo
  CCLD   libhydra.la
  CC     pmiserv_pmi.lo
  CC     pmiserv_pmi_v1.lo
  CC     pmiserv_pmi_v2.lo
  CC     pmiserv_pmci.lo
  CC     pmiserv_cb.lo
  CC     pmiserv_utils.lo
  CC     common.lo
  CC     pmi_v2_common.lo
  CCLD   libpm.la
  CC     hydra_persist-persist_server.o
  CCLD   hydra_persist
  CC     hydra_nameserver-hydra_nameserver.o
  CCLD   hydra_nameserver
  CC     hydra_pmi_proxy-pmip.o
  CC     hydra_pmi_proxy-pmip_cb.o
  CC     hydra_pmi_proxy-pmip_utils.o
  CC     hydra_pmi_proxy-pmip_pmi_v1.o
  CC     hydra_pmi_proxy-pmip_pmi_v2.o
  CC     hydra_pmi_proxy-common.o
  CC     hydra_pmi_proxy-pmi_v2_common.o
  CCLD   hydra_pmi_proxy
  CC     mpiexec.o
  CC     utils.o
  CCLD   mpiexec.hydra
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm/hydra »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/pm »
make all-postamble
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src »
for dir in mpl openpa ; do \
	    (cd $dir && make prefix=/user/pvm/mpich2-1.4.1p1 exec_prefix=/user/pvm/mpich2-1.4.1p1 \
	    bindir=/user/pvm/mpich2-1.4.1p1/bin libdir=/user/pvm/mpich2-1.4.1p1/lib \
	    includedir=/user/pvm/mpich2-1.4.1p1/include docdir=/user/pvm/mpich2-1.4.1p1/share/doc install) ; \
	done
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
test -z "/user/pvm/mpich2-1.4.1p1/lib" || /bin/mkdir -p "/user/pvm/mpich2-1.4.1p1/lib"
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   libmpl.la '/user/pvm/mpich2-1.4.1p1/lib'
libtool: install: /usr/bin/install -c .libs/libmpl.lai /user/pvm/mpich2-1.4.1p1/lib/libmpl.la
libtool: install: /usr/bin/install -c .libs/libmpl.a /user/pvm/mpich2-1.4.1p1/lib/libmpl.a
libtool: install: chmod 644 /user/pvm/mpich2-1.4.1p1/lib/libmpl.a
libtool: install: ranlib /user/pvm/mpich2-1.4.1p1/lib/libmpl.a
libtool: install: warning: remember to run `libtool --finish /user/pvm/mpich2-log/lib'
make[4]: Rien à faire pour « install-data-am ».
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/mpl »
make[3]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
Making install in src
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
 /bin/bash ../libtool   --mode=install /usr/bin/install -c   libopa.la '/user/pvm/mpich2-1.4.1p1/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /user/pvm/mpich2-1.4.1p1/lib/libopa.la
libtool: install: /usr/bin/install -c .libs/libopa.a /user/pvm/mpich2-1.4.1p1/lib/libopa.a
libtool: install: chmod 644 /user/pvm/mpich2-1.4.1p1/lib/libopa.a
libtool: install: ranlib /user/pvm/mpich2-1.4.1p1/lib/libopa.a
test -z "/user/pvm/mpich2-1.4.1p1/include" || /bin/mkdir -p "/user/pvm/mpich2-1.4.1p1/include"
 /usr/bin/install -c -m 644 opa_config.h opa_primitives.h opa_queue.h opa_util.h '/user/pvm/mpich2-1.4.1p1/include'
/bin/mkdir -p '/user/pvm/mpich2-1.4.1p1/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/user/pvm/mpich2-1.4.1p1/include/primitives'
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/src »
Making install in test
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/test »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/test »
make[5]: Rien à faire pour « install-exec-am ».
make[5]: Rien à faire pour « install-data-am ».
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/test »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa/test »
make[4]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[5]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
test -z "/user/pvm/mpich2-1.4.1p1/share/doc" || /bin/mkdir -p "/user/pvm/mpich2-1.4.1p1/share/doc"
 /usr/bin/install -c -m 644 README '/user/pvm/mpich2-1.4.1p1/share/doc'
test -z "/user/pvm/mpich2-1.4.1p1/lib/pkgconfig" || /bin/mkdir -p "/user/pvm/mpich2-1.4.1p1/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/user/pvm/mpich2-1.4.1p1/lib/pkgconfig'
make[5]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[4]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[3]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src/openpa »
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src »
make[1]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/src »
make all-postamble
make[1]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
( cd examples && make )
make[2]: entrant dans le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/examples »
  CC              cpi.c
../bin/mpicc   -o cpi cpi.o  -lm
make[2]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1/examples »
Make completed
make[1]: quittant le répertoire « /nfs/user/pers/info/pvm/mpich2-1.4.1p1 »
