[mpich-discuss] p4_error issue
Dave Goodell
goodell at mcs.anl.gov
Tue Nov 22 11:41:27 CST 2011
As you mention, mpich1 is no longer supported. It's always surprising when mpich1 or p4 work at all on a modern system. I would recommend just installing mpich2. For most uses it will work just fine as an mpich1 replacement and will be much faster and more robust.
-Dave
On Nov 22, 2011, at 11:24 AM CST, akshar bhosale wrote:
> Hi,
> i have one executable compiled with mpich-1.2.7p1. it works fine if run on one server (node) but it gives following error if i try to run it across multiple nodes.
> p15_4211: p4_error: net_recv read: probable EOF on socket: 1
> > p14_4184: p4_error: net_recv read: probable EOF on socket: 1
> > p13_4157: p4_error: net_recv read: probable EOF on socket: 1
> > p12_4130: p4_error: net_recv read: probable EOF on socket: 1
> > p11_4103: p4_error: net_recv read: probable EOF on socket: 1
> > p10_4076: p4_error: net_recv read: probable EOF on socket: 1
> > p8_4022: p4_error: net_recv read: probable EOF on socket: 1
> > p9_4049: p4_error: net_recv read: probable EOF on socket: 1
> > p23_9466: p4_error: net_recv read: probable EOF on socket: 1
> > p18_9331: p4_error: net_recv read: probable EOF on socket: 1
> > p22_9439: p4_error: net_recv read: probable EOF on socket: 1
> > p16_9277: p4_error: net_recv read: probable EOF on socket: 1
> > p17_9304: p4_error: net_recv read: probable EOF on socket: 1
> > p3_32073: p4_error: net_recv read: probable EOF on socket: 1
> > p6_32157: p4_error: net_recv read: probable EOF on socket: 1
> > p7_32185: p4_error: net_recv read: probable EOF on socket: 1
> > p4_32101: p4_error: net_recv read: probable EOF on socket: 1
> > p5_32129: p4_error: net_recv read: probable EOF on socket: 1
> > rm_l_2_32068: (1003.843750) net_send: could not write to fd=5, errno = 32
> I have tried changing P4_GLOBMEMSIZE but it did not work. machine is having linux (rhel 5.2) with 48 GB of memory.
> Where to llok for errors? I know that mpich-1 is no longer supported. But looking for help.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
