[mpich-discuss] Segmentation Fault when running any application.
    Rajeev Thakur
    thakur at mcs.anl.gov
    Mon Nov 21 17:22:14 CST 2011
Can you run an OpenMP-only program (no MPI) on that machine and see if it runs correctly?
On Nov 21, 2011, at 2:17 PM, Michael Warthon wrote:
> Alright I replaced MPI_Init with MPI_Init_thread function. I compile the program again and no errors occur. However, when I run the program nothing happens. Below is the code that uses threading and MPI. This is just a basic hello world program to see if the code actually works or not. I have already found another machine in order to create, compile and run my code. That machine has the mpicc command and on that machine there are no problems when running the code.
> #include
> <stdio.h>
> #include <stdlib.h>
> #include <math.h>
> #include <omp.h>
> #include <mpi.h>
> int
> main(int argc,char *argv[])
> //MPI variables
> int numprocs, rank, namelen, provided;
> char processor_name[MPI_MAX_PROCESSOR_NAME];
> //OpenMP variables
> int nthreads, tid;
> //MPI_Init(&argc, &argv);
> MPI_Init_thread(0,0, MPI_THREAD_FUNNELED, &provided);
> MPI_Comm_size(MPI_COMM_WORLD, &numprocs);
> MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> MPI_Get_processor_name(processor_name, &namelen);
> printf("Process %d on %s out of %d\n", rank, processor_name, numprocs);
> fflush(stdout);
> omp_set_num_threads(4);
> #pragma omp parallel private(tid) shared(nthreads)
> // Obtain and print thread id
> tid = omp_get_thread_num();
> printf("Hello World from thread = %d for process %d\n", tid,rank);
> fflush(stdout);
> // Only master thread does this
> if (tid == 0)
> nthreads = omp_get_num_threads();
> printf("Number of threads = %d for process %d\n", nthreads,rank);
> fflush(stdout);
> MPI_Finalize();
> On Mon, Nov 21, 2011 at 11:17 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> If your OpenMP contructs do not make any MPI call
> (only the main thread is making MPI calls),
> MPI_THREAD_FUNNELED should be used instead, e.g.
> http://www.mpi-forum.org/docs/mpi-20-html/node165.htm
> A.Chan
> > Hi,
> > Make sure that you call MPI_Init_thread(..,MPI_THREAD_MULTIPLE,..) in
> > your code instead of MPI_Init().
> > -Jayesh
> > From: "Michael Warthon" <michael.warthon at upr.edu>
> > To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> > Cc: mpich-discuss at mcs.anl.gov
> > Sent: Sunday, November 20, 2011 11:34:43 AM
> > Subject: Re: [mpich-discuss] Segmentation Fault when running any
> > application.
> > One more question concerning this whole setup. If I wanted to compile
> > an MPI program that used OpenMP, how would I go about doing that? I
> > have tried to compile it but just adding the -fopenmp flag but when I
> > tried to run the program using mpiexec the program did nothing. There
> > was no compilation error or anything. When I commented out the lines
> > concerning OpenMP, the program ran fine.
> > On Fri, Nov 18, 2011 at 3:23 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> > wrote:
> > Glad to know it worked for you.
> > The error messages are still annoying though. There are some known
> > bugs with SMPD that might give these error messages (as you have
> > already found) but unfortunately I haven't been able to recreate it
> > here (Also we don't have dev resources to pursue this SMPD bug. So
> > unfortunately you are stuck with the bug if you use SMPD.).
> > Regards,
> > Jayesh
> > From: "Michael Warthon" < michael.warthon at upr.edu >
> > To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> > Sent: Friday, November 18, 2011 2:36:59 PM
> > application.
> > Oh my god! It finally worked! Yes, apparently it was that I was
> > compiling it for the 64-bit version of MPICH2. I ran the code and it
> > worked fine even though it was giving me the error concerning the left
> > socket in mpiexec. Since it is working correctly, I think everything
> > is okay now. Thank you very much for helping me out these past couple
> > of days. I greatly appreciate it!
> > On Fri, Nov 18, 2011 at 2:11 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> > wrote:
> > Hi,
> > Do you have a 64-bit version of MPICH2 installed in your system ? If
> > so, you need to create 64-bit executable with gcc (Use "-m64" flag of
> > gcc OR use mingw compilers that accept "-m64" option) .
> > (PS: On 64-bit systems I use mingw compilers,
> > x86_64-w64-mingw32-g++ -I"/cygdrive/c/Program Files/MPICH2/include"
> > -L"/cygdrive/c/Program Files/MPICH2/lib" hellow.c -lmpi
> > Regards,
> > Jayesh
> > Sent: Friday, November 18, 2011 12:04:05 PM
> > application.
> > Alright I entered that command in and the result was this:
> > /tmp/cc0GoDvV.o:hello.c:(.text+0x1f): undefined reference to
> > `_MPI_Init'
> > /tmp/cc0GoDvV.o:hello.c:(.text+0x36): undefined reference to
> > `_MPI_Comm_size'
> > /tmp/cc0GoDvV.o:hello.c:(.text+0x4d): undefined reference to
> > `_MPI_Comm_rank'
> > /tmp/cc0GoDvV.o:hello.c:(.text+0x64): undefined reference to
> > `_MPI_Get_processor
> > _name'
> > /tmp/cc0GoDvV.o:hello.c:(.text+0x93): undefined reference to
> > `_MPI_Finalize'
> > collect2: ld returned 1 exit status
> > On Fri, Nov 18, 2011 at 11:52 AM, Jayesh Krishna < jayesh at mcs.anl.gov
> > > wrote:
> > Hi,
> > Try,
> > $ gcc -I "/cygdrive/c/Program Files/MPICH2/include" -L
> > "/cygdrive/c/Program Files/MPICH2/lib" hello.c -o hello.exe -lmpi
> > Regards,
> > Jayesh
> > Sent: Friday, November 18, 2011 11:19:11 AM
> > application.
> > If the program I am trying to compile will work with mpiexec even with
> > the error present, then I will not install MPICH2 from source.
> > Currently the command I am entering is:
> > $ gcc hello.c -o hello.exe -I "/cygdrive/c/Program
> > Files/MPICH2/include" -L "/cygdrive/c/Program
> > Files/MPICH2/lib/libmpi.a" -lmpi
> > The response I get is:
> > /usr/lib/gcc/i686-pc-cygwin/4.5.3/../../../../i686-pc-cygwin/bin/ld:
> > cannot find
> > -lmpi
> > Is there a verbose option for gcc in order to obtain more information
> > about what is happening?
> > On Fri, Nov 18, 2011 at 10:32 AM, Jayesh Krishna < jayesh at mcs.anl.gov
> > > wrote:
> > Hi,
> > If you are not too much concerned about performance you can
> > configure/make/install MPICH2 from source on Cygwin.
> > If you want help with compiling an MPI program with gcc libs please
> > send us the complete command that you used to compile your code (From
> > the error message it looks like you did not specify the path to
> > libmpi.a , you need to specify the path using "-L" option).
> > (PS: Please provide as much details as possible)
> > Regards,
> > Jayesh
> > To: "Jose Marques" < jmarques at itn.pt >, "Jayesh Krishna" <
> > Sent: Thursday, November 17, 2011 2:54:37 PM
> > application.
> > Ok well I did a bit of searching on past discussions and it looks like
> > the error will come up but won't affect how the program will run.
> > However, it seems that I keep getting out of one problem and running
> > into another. When I tried to compile the hello.c file again I got
> > this error:
> > cannot find
> > -lmpi
> > I want to make sure that other executable will work for mpiexec so I
> > would like to be able to compile hello.c and then test to see if it
> > will run or not.
> > On Thu, Nov 17, 2011 at 12:38 PM, Michael Warthon <
> > michael.warthon at upr.edu > wrote:
> > Thank you. Unfortunately I still get the same error regarding the
> > closing of the left context socket.
> > On Thu, Nov 17, 2011 at 2:28 PM, Jose Marques < jmarques at itn.pt >
> > wrote:
> > Michael,
> > There's a good set of instructions in
> > http://www.petri.co.il/disable-uac-in-windows-7.htm
> > Rds,
> > Jose
> > On 17-11-2011 6:12, Michael Warthon wrote:
> > How do I go about turning that off?
> > On Nov 17, 2011, at 2:05 PM, Jose Marques < jmarques at itn.pt > wrote:
> > Michael,
> > Did you switch off User Account Control in Windows 7 ? I think I had
> > the same probs and solved them taking care of UAC.
> > Jose
> > On 17-11-2011 5:35, Michael Warthon wrote:
> > I am still getting the same error even after reinstalling SMPD. The
> > MPICH2 that I have installed is the 64-bit version. My computer has
> > windows 7, is a 64-bit operating system, and has an intel core i5 CPU
> > processor. The installer I used mpich2-1.4.1p1-win-x86-64.msi is the
> > correct one right?
> > On Thu, Nov 17, 2011 at 12:22 PM, Jayesh Krishna < jayesh at mcs.anl.gov
> > > wrote:
> > Hi,
> > The error message does not appear with the "-verbose" option (The
> > launch mechanism with a "-verbose" option is different though).
> > I think that the issue is still that MPICH2 was not installed
> > correctly in your system (I verified that 1.4.1p1 works correctly -
> > without error msgs - on our Srv2008). Please follow the steps below
> > and let us know if it works for you,
> > # Right-click on the command prompt icon and select "Run as
> > administrator" to open an admin command prompt
> > # From the admin command prompt, uninstall SMPD using the "-uninstall"
> > option (Type "smpd -uninstall")
> > # From the admin command prompt, install SMPD using the "-install"
> > option (Type "smpd -install")
> > # Try running mpiexec from the admin command prompt (Type "mpiexec -n
> > 2 hostname")
> > # Try running mpiexec from a normal command prompt (Type "mpiexec -n 2
> > hostname")
> > Let us know the results.
> > Regards,
> > Jayesh
> > Sent: Thursday, November 17, 2011 10:10:28 AM
> > application.
> > Alright. Attached is the text file with the complete message from the
> > command: "c:\Program Files\MPICH2\bin\mpiexec" -verbose -n 2 hostname
> > I tried the other command and for some reason I am actually able to
> > run the program even when the errors occur. This is the response I got
> > when running the command:
> > C:\Users\Mike>"c:\Program Files\MPICH2\bin\mpiexec" -n 2 "C:\Program
> > Files\MPICH
> > 2\examples\cpi.exe"
> > error closing the left context socket: Error = -1
> > Enter the number of intervals: (0 quits) 100
> > pi is approximately 3.1416009869231241, Error is 0.0000083333333309
> > wall clock time = 0.000541
> > pi is approximately 3.1424259850010983, Error is 0.0008333314113051
> > wall clock time = 0.000047
> > Enter the number of intervals: (0 quits) 0
> > op_read error on left context: Error = -1
> > unable to read the cmd header on the left context, Error = -1
> > Error posting readv, An existing connection was forcibly closed by the
> > remote ho
> > st.(10054)
> > On Thu, Nov 17, 2011 at 9:56 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
> > wrote:
> > Hi,
> > Yes, please give us the output of the command with "-verbose" turned
> > on.
> > And for these tests, run mpiexec with the complete path ("c:\Program
> > Files\MPICH2\bin\mpiexec" -verbose -n 2 hostname). Do you get the same
> > error message when executing cpi ("c:\Program
> > Files\MPICH2\examples\cpi.exe")?
> > Regards,
> > Jayesh
> > Sent: Thursday, November 17, 2011 9:42:42 AM
> > application.
> > For each command, this is the entire response that I get:
> > C:\Users\Mike>mpiexec -validate
> > SUCCESS
> > C:\Users\Mike>mpiexec -n 2 hostname
> > Mike-PC
> > Mike-PC
> > C:\Users\Mike>
> > Did you want me to use the verbose option?
> > On Thu, Nov 17, 2011 at 9:21 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
> > wrote:
> > Hi,
> > Please copy-paste the command and the response (the complete message)
> > in your email.
> > Are you able to validate the registered username/password (Type
> > "mpiexec -validate" and it should return "SUCCESS")?
> > Regards,
> > Jayesh
> > Sent: Thursday, November 17, 2011 7:50:25 AM
> > application.
> > Ok. I have checked and yes smpd is running and I have given a
> > sufficient username and password so that mpiexec will run. Now I am
> > getting a new error when executing mpiexec -n 2 hostname where it is
> > giving me this response:
> > On Wed, Nov 16, 2011 at 2:21 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> > wrote:
> > Hi,
> > 1. Make sure that the process manager, smpd, is running in your system
> > (Look in the task manager/Process Explorer to see if there is a
> > service named smpd running. Alternately you can run "smpd -status" to
> > check if smpd is running)
> > 2. Run a simple non-MPI program like hostname from the command prompt
> > using mpiexec (Type "mpiexec -n 2 hostname" ). When prompted for
> > username/password give a valid Windows username/password.
> > If mpiexec gives you an error, type "mpiexec -remove" to remove the
> > existing registered username/password and then type "mpiexec
> > -register" to register a new/valid Windows username/password. Re-run
> > mpiexec.
> > 3. Run the sample MPI program, cpi.exe, provided with MPICH2 (mpiexec
> > -n 2 C:\Progra~1\MPICH2\examples\cpi.exe)
> > >> I am getting an error when I look at the MPICH2 configurable
> > >> settings ...
> > This is a known bug. Due to limited developer bandwidth we haven't
> > been able to address this issue yet.
> > Regards,
> > Jayesh
> > Sent: Wednesday, November 16, 2011 12:27:01 PM
> > application.
> > Alright. I have reinstalled MPICH2 using the method in section 9.4.
> > However, I am not able to connect to the host it seems. I keep
> > receiving this message when trying to execute a program:
> > Credentials for Mike rejected connecting to Mike-PC
> > Aborting: Unable to connect to Mike-PC
> > Also, I am getting an error when I look at the MPICH2 configurable
> > settings that says that MPICH2 is not installed or that it cannot
> > query the host.
> > On Wed, Nov 16, 2011 at 9:35 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
> > wrote:
> > Hi,
> > Looks like MPICH2 was not installed correctly in your system.
> > Uninstall your existing version of MPICH2. Please follow the steps in
> > Section 9.4 (Not 9.1 -
> > http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.4.1-installguide.pdf
> > ) of the installer's guide to install MPICH2.
> > (PS: I am assuming that you have Win7/Srv2008/...)
> > Regards,
> > Jayesh
> > Sent: Tuesday, November 15, 2011 9:04:57 PM
> > application.
> > Yeah it must have been that I got the installation mixed up. I
> > downloaded the windows installer and it finally compiled. So progess
> > has been made as now I am getting this error when trying to run
> > hello.exe:
> > Error while connecting to host, No connection could be made because
> > the target m
> > achine actively refused it. (10061)
> > Connect on sock (host=localhost, port=8676) failed, exhaused all end
> > points
> > Unable to connect to 'localhost:8676',
> > sock error: Error = -1
> > On Tue, Nov 15, 2011 at 5:12 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> > wrote:
> > Hi,
> > There are two ways you can use MPICH2 on Windows+cygwin,
> > # Download MPICH2 source compile/install it on Cygwin. Use mpicc to
> > compile and use mpiexec (from this installation - NOT the one
> > available with Windows installer) to run your program.
> > # Download MPICH2 Windows installer, install MPICH2 (using installer
> > gui). Use the cygwin/gcc libs provided with the Windows installation
> > to compile your code. Use mpiexec from the Windows installation to run
> > your job.
> > Looks like you are mixing the approaches.
> > Regards,
> > Jayesh
> > Sent: Tuesday, November 15, 2011 1:03:02 PM
> > application.
> > I was using mpicc in order to compile it. Unfortunately I am still not
> > able to compile the code even with the command you gave me. I used:
> > gcc -l/mpich_install/include -L/mpich_install/lib hello.c -lmpi
> > I still received the same error. Did I install it incorrectly maybe?
> > On Tue, Nov 15, 2011 at 12:42 PM, Jayesh Krishna < jayesh at mcs.anl.gov
> > > wrote:
> > Hi,
> > How were you compiling your code before ?
> > A command similar to,
> > "gcc -I/cygdrive/c/Progra~1/MPICH2/include
> > -L/cygdrive/c/Progra~1/MPICH2/lib hello.c -o hello.exe -lmpi"
> > should work.
> > Regards,
> > jayesh
> > Sent: Tuesday, November 15, 2011 12:18:43 PM
> > application.
> > Alright. Well I tried it and for some reason it is not able to see the
> > library.
> > I used the command:
> > gcc -g hello.c -L\mpich_install\lib -lmpi
> > It ended up giving me an error saying:
> > fatal error: mpi.h: No such file or directory
> > On Tue, Nov 15, 2011 at 10:32 AM, Jayesh Krishna < jayesh at mcs.anl.gov
> > > wrote:
> > Hi,
> > Try using gcc (usual gcc stuff: specify include dirs using "-I", lib
> > dirs using "-L") to compile your code and link it with "-lmpi" .
> > Regards,
> > Jayesh
> > Sent: Tuesday, November 15, 2011 10:16:00 AM
> > application.
> > What would be the correct command to use in cygwin in order to compile
> > the code? Just want to make sure that I actually compiled it
> > correctly.
> > On Tue, Nov 15, 2011 at 10:10 AM, Jayesh Krishna < jayesh at mcs.anl.gov
> > > wrote:
> > Hi,
> > I just tried compiling your code with cygwin gcc (3.4.4) + MPICH2
> > 1.4.1p1 gcc libs and it worked for me (No seg fault, gives the
> > expected output).
> > Make sure that you are using the correct header files and libraries
> > (MPICH2 libs and headers) when you compile your code.
> > Regards,
> > Jayesh
> > Sent: Tuesday, November 15, 2011 9:53:32 AM
> > application.
> > Ah sorry. I forgot to include the p1 at the end of it. I am using
> > mpich2 1.4.1p1
> > On Tue, Nov 15, 2011 at 9:44 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
> > wrote:
> > Did you try the latest stable release (1.4.1p1)?
> > -Jayesh
> > To: mpich-discuss at mcs.anl.gov
> > Sent: Monday, November 14, 2011 7:54:43 PM
> > Subject: [mpich-discuss] Segmentation Fault when running any
> > application.
> > Hello,
> > I am new to MPI and I went and installed mpich2 1.4.1 onto a windows
> > system that is being used through cygwin. I have compiled the code
> > that simply prints the process and rank as shown below.
> > #include <stdio.h>
> > #include <mpi.h>
> > int main( int argc, char *argv[]) {
> > int numprocs, rank, namelen;
> > printf( "Process %d on %s out of %d\n" , rank, processor_name,
> > numprocs);
> > MPI_Finalize();
> > Nothing too complicated. However, I still receive an error from the
> > command line in cygwin that simply reads segmentation fault: (core
> > dumped). The command I used was:
> > mpiexec -n 1 a.exe
> > No matter what executable I try to run, I still receive the same
> > error. Any help regarding this would be greatly appreciated!
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov To manage
> > Dr. Jose G. Marques
> > Reactor Manager
> > Instituto Tecnologico e Nuclear phone: (+351) 219 946 115 Estrada
> > Nacional 10 fax: (+351) 219 941 039 P-2686-953 Sacavem, Portugal
> > Dr. Jose G. Marques
> > Reactor Manager
