[mpich-discuss] how to connect linux and windows?
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Nov 4 10:54:41 CDT 2011
Have to turned off firewalls on both the machines (Windows firewall & any firewalls on Linux)?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, November 3, 2011 7:54:46 PM
Subject: Re: Re: [mpich-discuss] how to connect linux and windows?
I have remove the extention .exe of the executable file on windows.
the content of machinefile.txt
192.168.1.1 //linux
192.168.1.3 //windows
c:\MPICH2\bin>mpiexec -machinefile machinefile.txt -path "c:\MPICH2\examples;/h
ome/walter/mpich2-1.4.1p1/examples" icpi
Enter the number of intervals: (0 quits) 100
pi is approximately 3.1416009869231254, Error is 0.0000083333333323
wall clock time = 0.000156
Enter the number of intervals: (0 quits) 0
It's OK.
when add -n 4 or modify machinefile.txt
192.168.1.1 2
192.168.1.3 2
wrong info like below:
c:\MPICH2\bin>mpiexec -n 4 -machinefile machinefile.txt -path "c:\MPICH2\exampl
es;/home/walter/mpich2-1.4.1p1/examples" icpi
op_read error on left context: Error = -1
unable to read the cmd header on the left context, Error = -1
when modify machinefile.txt
192.168.1.3
192.168.1.1
Fatal error in PMPI_Bcast: Other MPI error, error stack:
PMPI_Bcast(1478)......................: MPI_Bcast(buf=0012FE48, count=1, MPI_INT
, root=0, MPI_COMM_WORLD) failed
MPIR_Bcast_impl(1321).................:
MPIR_Bcast_intra(1119)................:
MPIR_Bcast_scatter_ring_allgather(962):
MPIR_Bcast_binomial(213)..............: Failure during collective
MPIR_Bcast_scatter_ring_allgather(955):
MPIR_Bcast_binomial(189)..............:
MPIC_Send(66).........................:
MPIC_Wait(540)........................:
MPIDI_CH3I_Progress(402)..............:
MPID_nem_mpich2_blocking_recv(905)....:
MPID_nem_newtcp_module_poll(37).......:
MPID_nem_newtcp_module_connpoll(2656).:
gen_cnting_fail_handler(1739).........: connect failed - 远程计算机拒绝网络连接
(errno 1225)
job aborted:
rank: node: exit code[: error message]
0: 192.168.1.3: 1: process 0 exited without calling finalize
1: 192.168.1.1: -2
2: 192.168.1.3: 123
3: 192.168.1.1: -2
2011-11-04
lt200819
发件人: Jayesh Krishna
发送时间: 2011-11-04 01:07:13
收件人: lt200819
抄送: mpich-discuss
主题: Re: [mpich-discuss] how to connect linux and windows?
Please copy-paste the entire command and the output in your email.
I would recommend recompiling icpi.c on both Windows and Linux and then renaming executables on both machines to "icpi" (Note: Remove the extension, .exe, of the executable file on Windows).
-Jayesh
Sent: Wednesday, November 2, 2011 9:17:16 PM
use cpi.exe as the example. I have rename it as icpi.exe. and have "make" the icpi.c on the linux.
if exe on two windows ,it's OK. But, if exe on both linux and windows,it show some error.
C:\MPICH2\bin>mpiexec -machinefile machinefile.txt -channel nemesis -path "c:\MPICH2\examples;/home/walter/mpich2-1.4.1p1/examples" icpi
can't found the cmd header in the left context.
why?
2011-11-03
lt200819
发件人: Jayesh Krishna
发送时间: 2011-11-01 23:07:20
收件人: 李彤
抄送: mpich-discuss
So did it work for you ?
-Jayesh
Sent: Monday, October 31, 2011 9:27:54 PM
Subject: Re: [mpich-discuss] how to connect linux and windows?
I have done it.
use cpi.exe as the example. I have rename it as icpi.exe. and have make the icpi.c on the linux.
if exe on two windows ,it's OK. But, if exe on linux and windows,it show some error.
why?
2011/10/27 Jayesh Krishna < jayesh at mcs.anl.gov >
SMPD is the default (only available one right now) process manager on Windows. After configuring MPICH2 with SMPD on Unix/linux,
1. Make sure that you have the program (say foo.c ==compiled_to==> foo.exe ==renamed_to==> "foo" on Windows) compiled and working on Windows.
"mpiexec -n 2 foo" should work
2. Add the Windows and Linux hostnames to the "machinefile" (mpiexec -n 2 -machinefile mf.txt foo)
You can specify the path to the different executables using the "-path" option (mpiexec -n 2 -machinefile mf.txt -path "C:\temp;/home/user/temp" foo).
Jayesh
Sent: Monday, October 24, 2011 3:12:21 AM
Subject: [mpich-discuss] how to connect linux and windows?
now,I have use smpd complement the connection between ubuntu11.10 and other ubuntu11.10
and I have install mpich2-1.4.1p1 on windows7 , it's run well
how to connect linux and windows??
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
