[mpich-discuss] Problem with MPICH2 install
    Dave Goodell
    goodell at mcs.anl.gov
    Tue Nov  1 12:35:52 CDT 2011
This particular test is expected to fail at this time in all configurations.
-Dave
On Nov 1, 2011, at 12:31 PM CDT, Abel Marin-Lafleche wrote:
> Ok
> It seems to work fine with ifort 12.1.0.
> Now in make testing I have 1 test failing. Should I worry about this ?
> I join the summary.xml file
> Processing directory coll
> Looking in ./errors/coll/testlist
> Unexpected output in bcastlength: Did not detect mismatched length (long) on process 3
> Unexpected output in bcastlength: Did not detect mismatched length (short) on process 3
> Unexpected output in bcastlength:  Found 2 errors
> Program bcastlength exited without No Errors
> Thank you
> Abel
> On 11/01/2011 10:49 AM, Anthony Chan wrote:
>> Your configure command seems OK.  But the ifort on your path is 11.1
>> which is older than the icc/icpc which are 12.1.  Could you try using the
>> same version of icc/icpc/ifort to configure mpich2 ?
>> A.Chan
>> ----- Original Message -----
>>> Hi,
>>> I have some problem while trying to install mpich2 on a linux machine
>>> (64 bit,
>>> theo.ne.anl.gov).
>>> Althoug the make and make install steps appear to have no problem and
>>> the cpi
>>> test program is working too. When I try a make installcheck I receive
>>> a bunch of
>>> errors relateded to F77 and F90 bindings.
>>> It is always the same kind of compiling error:
>>> undefined reference to `__intel_sse2_strrchr'
>>> undefined reference to `__intel_sse2_strcspn'
>>> undefined reference to `__intel_sse2_strdup'
>>> I do need mpif77 and mpif90 to work properly as the code I am working
>>> on is
>>> written in fortran 90.
>>> Here is more detail about what I am trying to do and I join the files
>>> m.txt,
>>> mi.txt and mic.txt
>>> I am using intel compiler icc, icpc and ifort
>>> [b59103 at theo mpich2-1.4.1]$ icc --version
>>> icc (ICC) 12.1.0 20110811
>>> Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
>>> [b59103 at theo mpich2-1.4.1]$ ifort --version
>>> ifort (IFORT) 11.1 20100806
>>> Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
>>> [b59103 at theo mpich2-1.4.1]$ icpc --version
>>> icpc (ICC) 12.1.0 20110811
>>> Here is my compile/install script and I join the files m.txt, mi.txt
>>> and
>>> mtesting.txt
>>> cd /software/src
>>> tar xzf mpich2-1.4.1p1.tar.gz
>>> mkdir /software/build/mpich2-1.4.1
>>> cd /software/build/mpich2-1.4.1
>>> /software/src/mpich2-1.4.1p1/configure
>>> --prefix=/software/mpich2-install CC=icc
>>> F77=ifort FC=ifort CXX=icpc \
>>> MPICH2LIB_CFLAGS="-g -O2" MPICH2LIB_FFLAGS="-g -O2"
>>> MPICH2LIB_FCFLAGS="-g
>>> -O2" MPICH2LIB_CXXFLAGS="-g -O2" \
>>> --with-pm=gforker --enable-g=meminit 2>&1 | tee c.txt
>>> make 2>&1 | tee m.txt
>>> make install 2>&1 | tee mi.txt
>>> make installcheck 2>&1 | tee mic.txt
>>> Thank you,
>>> Abel
>>> Abel Marin-Lafleche
>>> Nuclear Engineering Associate
>>> Nuclear Engineering Division
>>> Argonne National Laboratory
>>> 9700 S. Cass Avenue
>>> Argonne, IL 60439 USA
>>> Phone: 630-252-4622
>>> _______________________________________________
>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Abel Marin-Lafleche
> 9700 S. Cass Avenue
> Phone: 630-252-4622
> <summary.xml>_______________________________________________
