[mpich-discuss] Problem with MPICH2 install
    Abel Marin-Lafleche
    amarinlafleche at anl.gov
    Tue Nov  1 12:31:10 CDT 2011
Ok
It seems to work fine with ifort 12.1.0.
Now in make testing I have 1 test failing. Should I worry about this ?
I join the summary.xml file
Processing directory coll
Looking in ./errors/coll/testlist
Unexpected output in bcastlength: Did not detect mismatched length (long) on
process 3
Unexpected output in bcastlength: Did not detect mismatched length (short) on
process 3
Unexpected output in bcastlength:  Found 2 errors
Program bcastlength exited without No Errors
Thank you
Abel
On 11/01/2011 10:49 AM, Anthony Chan wrote:
> Your configure command seems OK.  But the ifort on your path is 11.1
> which is older than the icc/icpc which are 12.1.  Could you try using the
> same version of icc/icpc/ifort to configure mpich2 ?
> A.Chan
>> Hi,
>> I have some problem while trying to install mpich2 on a linux machine
>> (64 bit,
>> theo.ne.anl.gov).
>> Althoug the make and make install steps appear to have no problem and
>> the cpi
>> test program is working too. When I try a make installcheck I receive
>> a bunch of
>> errors relateded to F77 and F90 bindings.
>> It is always the same kind of compiling error:
>> undefined reference to `__intel_sse2_strrchr'
>> undefined reference to `__intel_sse2_strcspn'
>> undefined reference to `__intel_sse2_strdup'
>> I do need mpif77 and mpif90 to work properly as the code I am working
>> on is
>> written in fortran 90.
>> Here is more detail about what I am trying to do and I join the files
>> m.txt,
>> mi.txt and mic.txt
>> I am using intel compiler icc, icpc and ifort
>> [b59103 at theo mpich2-1.4.1]$ icc --version
>> icc (ICC) 12.1.0 20110811
>> Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
>> [b59103 at theo mpich2-1.4.1]$ ifort --version
>> ifort (IFORT) 11.1 20100806
>> Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
>> [b59103 at theo mpich2-1.4.1]$ icpc --version
>> icpc (ICC) 12.1.0 20110811
>> Here is my compile/install script and I join the files m.txt, mi.txt
>> and
>> mtesting.txt
>> cd /software/src
>> tar xzf mpich2-1.4.1p1.tar.gz
>> mkdir /software/build/mpich2-1.4.1
>> cd /software/build/mpich2-1.4.1
>> /software/src/mpich2-1.4.1p1/configure
>> --prefix=/software/mpich2-install CC=icc
>> F77=ifort FC=ifort CXX=icpc \
>> MPICH2LIB_CFLAGS="-g -O2" MPICH2LIB_FFLAGS="-g -O2"
>> MPICH2LIB_FCFLAGS="-g
>> -O2" MPICH2LIB_CXXFLAGS="-g -O2" \
>> --with-pm=gforker --enable-g=meminit 2>&1 | tee c.txt
>> make 2>&1 | tee m.txt
>> make install 2>&1 | tee mi.txt
>> make installcheck 2>&1 | tee mic.txt
>> Thank you,
>> Abel
>> Abel Marin-Lafleche
>> Nuclear Engineering Associate
>> Nuclear Engineering Division
>> Argonne National Laboratory
>> 9700 S. Cass Avenue
>> Argonne, IL 60439 USA
>> Phone: 630-252-4622
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Abel Marin-Lafleche
9700 S. Cass Avenue
Phone: 630-252-4622
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111101/89f81c35/attachment-0001.bin>
