[mpich-discuss] how to connect linux and windows?
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Nov  1 10:07:17 CDT 2011
 So did it work for you ?
-Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Monday, October 31, 2011 9:27:54 PM
Subject: Re: [mpich-discuss] how to connect linux and windows?
I have done it.
use cpi.exe as the example. I have rename it as icpi.exe. and have make the icpi.c on the linux.
if exe on two windows ,it's OK. But, if exe on linux and windows,it show some error.
can't found the cmd header in the left context.
why?
2011/10/27 Jayesh Krishna < jayesh at mcs.anl.gov >
SMPD is the default (only available one right now) process manager on Windows. After configuring MPICH2 with SMPD on Unix/linux,
1. Make sure that you have the program (say foo.c ==compiled_to==> foo.exe ==renamed_to==> "foo" on Windows) compiled and working on Windows.
"mpiexec -n 2 foo" should work
2. Add the Windows and Linux hostnames to the "machinefile" (mpiexec -n 2 -machinefile mf.txt foo)
You can specify the path to the different executables using the "-path" option (mpiexec -n 2 -machinefile mf.txt -path "C:\temp;/home/user/temp" foo).
Jayesh
Sent: Monday, October 24, 2011 3:12:21 AM
Subject: [mpich-discuss] how to connect linux and windows?
now,I have use smpd complement the connection between ubuntu11.10 and other ubuntu11.10
and I have install mpich2-1.4.1p1 on windows7 , it's run well
how to connect linux and windows??
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
