[mpich-discuss] Fatal error in PMPI_Bcast:
    Dave Goodell
    goodell at mcs.anl.gov
    Fri May 27 08:42:06 CDT 2011
Does the "examples/cpi" program from the MPICH2 build directory work correctly for you when you run it on multiple nodes?
-Dave
On May 26, 2011, at 5:49 PM CDT, Fujun Liu wrote:
> Hi everyone,
> When I try one example from http://beige.ucs.indiana.edu/I590/node62.html, I got the following error message as below. In the MPI cluster, there are two hosts. If I run the two processes on just one host, everything works fine. But if I run two processes on the two-host cluster, the following error happens. I think the two hosts just can't send/receive message to each other, but I don't know how to resolve this.
> Thanks in advance!
> xxxx at query:~/MPI$ mpiexec -n 2 -f machinefile ./GreetMaster
> Fatal error in PMPI_Bcast: Other MPI error, error stack:
> PMPI_Bcast(1430).......................: MPI_Bcast(buf=0x7fff13114cb0, count=8192, MPI_CHAR, root=0, MPI_COMM_WORLD) failed
> MPIR_Bcast_impl(1273)..................:
> MPIR_Bcast_intra(1107).................:
> MPIR_Bcast_binomial(143)...............:
> MPIC_Recv(110).........................:
> MPIC_Wait(540).........................:
> MPIDI_CH3I_Progress(353)...............:
> MPID_nem_mpich2_blocking_recv(905).....:
> MPID_nem_tcp_connpoll(1823)............:
> state_commrdy_handler(1665)............:
> MPID_nem_tcp_recv_handler(1559)........:
> MPID_nem_handle_pkt(587)...............:
> MPIDI_CH3_PktHandler_EagerSend(632)....: failure occurred while posting a receive for message data (MPIDI_CH3_PKT_EAGER_SEND)
> MPIDI_CH3U_Receive_data_unexpected(251): Out of memory (unable to allocate -1216907051 bytes)
> [mpiexec at query] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
> APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1)
> Fujun Liu
> Department of Computer Science, University of Kentucky, 2010.08-
> fujun.liu at uky.edu, (859)229-3659
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
