[mpich-discuss] Fatal error in PMPI_Bcast:
    Fujun Liu
    liufujun07 at gmail.com
    Thu May 26 17:49:11 CDT 2011
Hi everyone,
When I try one example from http://beige.ucs.indiana.edu/I590/node62.html, I
got the following error message as below. In the MPI cluster, there are two
hosts. If I run the two processes on just one host, everything works fine.
But if I run two processes on the two-host cluster, the following error
happens. I think the two hosts just can't send/receive message to each
other, but I don't know how to resolve this.
Thanks in advance!
xxxx at query:~/MPI$ mpiexec -n 2 -f machinefile ./GreetMaster
Fatal error in PMPI_Bcast: Other MPI error, error stack:
PMPI_Bcast(1430).......................: MPI_Bcast(buf=0x7fff13114cb0,
count=8192, MPI_CHAR, root=0, MPI_COMM_WORLD) failed
MPIR_Bcast_impl(1273)..................:
MPIR_Bcast_intra(1107).................:
MPIR_Bcast_binomial(143)...............:
MPIC_Recv(110).........................:
MPIC_Wait(540).........................:
MPIDI_CH3I_Progress(353)...............:
MPID_nem_mpich2_blocking_recv(905).....:
MPID_nem_tcp_connpoll(1823)............:
state_commrdy_handler(1665)............:
MPID_nem_tcp_recv_handler(1559)........:
MPID_nem_handle_pkt(587)...............:
MPIDI_CH3_PktHandler_EagerSend(632)....: failure occurred while posting a
receive for message data (MPIDI_CH3_PKT_EAGER_SEND)
MPIDI_CH3U_Receive_data_unexpected(251): Out of memory (unable to allocate
-1216907051 bytes)
[mpiexec at query] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1)
Fujun Liu
Department of Computer Science, University of Kentucky, 2010.08-
fujun.liu at uky.edu, (859)229-3659
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110526/9dd0c44b/attachment.htm>
