[mpich-discuss] Windows XP LAN
Jayesh Krishna
jayesh at mcs.anl.gov
Wed May 25 10:00:13 CDT 2011
Which version of MPICH2 are you using ?
I have added a ticket to track the work to disable netmods in Nemesis (re-enable the feature) on Windows (https://trac.mcs.anl.gov/projects/mpich2/ticket/1496).
Jayesh
----- Original Message -----
From: "Igor Marković" <igor.markovic2 at gmail.com>
Sent: Wednesday, May 25, 2011 9:31:02 AM
Subject: Re: [mpich-discuss] Windows XP LAN
On 24.5.2011 11:52, Igor Marković wrote:
> I have a problem using MPICH2 on Windows XP. If I run any MPI program
> using mpiexec, I have to wait for about 2 minutes before I see any
> prints on the command prompt. If I simply disconnect LAN cable from my
> computer, I have to wait only for 2-3 seconds.
> Can I change a setting in order to prevent mpiexec from accessing the
> LAN, and make it use only the local machine?
Does anyone have a clue? Are there some settings that can be changed, so
that MPICH2 functions properly? My laptop is usually on home network and
is a member of a workgroup.
mpich-discuss mailing list
