[mpich-discuss] Trouble running mpiexec with gdb
    Vikram Ramanathan
    vramana2 at iit.edu
    Tue May 24 10:29:15 CDT 2011
Hi
  I'm using petsc-dev on a Linux (Ubuntu 10.10 64-bit) machine with 2
processors. I was hoping to debug some code when running it on two
processors.
  The problem is that gdb needs root permissions to run. I can use/run
mpiexec fine by itself, but when I do something like sudo mpiexec -n 2
[program name] [parameters] -start_in_debugger, I get the following error:
/usr/bin/mpdroot: open failed for root's mpd conf
filempiexec_vikram-Aspire-4820TG (__init__ 1214): forked process failed;
status=255
  What does this exactly mean? Is there a way to work around this?
Thank you,
Vikram Ramanathan
Graduate Student, ECE Dept,
Illinois Institute of Technology
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110524/f8b317d1/attachment.htm>
