[mpich-discuss] I can not run parallel programs when I do not have internet connection
    Adolfo Vázquez-Quesada
    adolfo.vazquez at aer.mw.tum.de
    Fri May 20 03:52:27 CDT 2011
I have resolved the problem, so please, do not waste your time in this
question. If it could be useful for someone, the solution was to delete
a line in the /etc/hosts file that was added by the network manager program.
Thank you.
Adolfo.
> More information about this problem. When I run mpdcheck I obtain
> *** the fq hostname seems to be localhost
>  Your fully qualified and unqualified names do not resolve to
>  the same IP. This likely means that your DNS domain name is not
>  set correctly.  This might be fixed by adding a line similar
>  to the following to your /etc/hosts:
>         $ipaddr             $fqhn   $uqdn
> Best regards again.
> Adolfo
>> Maybe you could help me.
>> When I have internet connection I can run the programs in parallel with
>> mpirun without problem. But If I do not have internet connection, I
>> obtain
>> de next error from the mpd process:
>> meryado_mpdman_1: conn error in connect_lhs: Network is unreachable
>> meryado_mpdman_1 (connect_lhs 924): failed to connect to lhs at
>> 192.168.1.34 59126
>> meryado_mpdman_1 (run 197): lhs connect failed
>> If someone could help me I would be very grateful.
>> Best regards.
>> Adolfo.
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
