[mpich-discuss] I can not run parallel programs when I do not have internet connection
    Adolfo Vázquez-Quesada
    adolfo.vazquez at aer.mw.tum.de
    Fri May 20 03:43:36 CDT 2011
More information about this problem. When I run mpdcheck I obtain
*** the fq hostname seems to be localhost
 Your fully qualified and unqualified names do not resolve to
 the same IP. This likely means that your DNS domain name is not
 set correctly.  This might be fixed by adding a line similar
 to the following to your /etc/hosts:
        $ipaddr             $fqhn   $uqdn
Best regards again.
Adolfo
> Maybe you could help me.
> When I have internet connection I can run the programs in parallel with
> mpirun without problem. But If I do not have internet connection, I obtain
> de next error from the mpd process:
> meryado_mpdman_1: conn error in connect_lhs: Network is unreachable
> meryado_mpdman_1 (connect_lhs 924): failed to connect to lhs at
> 192.168.1.34 59126
> meryado_mpdman_1 (run 197): lhs connect failed
> If someone could help me I would be very grateful.
> Best regards.
> Adolfo.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
