[mpich-discuss] mpe error
    Anthony Chan
    chan at mcs.anl.gov
    Sun May 15 13:36:04 CDT 2011
Backtrace shows that merging failed. Would you be able to run
the same program without MPE ?
A.Chan
----- Original Message -----
> Hi,
> I'm a newbie to mpi, and i've managed to compile, link and run my
> program under mpich2-1.3.2p1
> without any problems. However, when i do the same, but using the
> "-mpe=mpilog" option, the following
> error is produced:
> Writing logfile....
> Enabling the Default clock synchronization...
> clog_commset.c:CLOG_CommSet_sync_IDs() -
> The parent CLOG_CommSet_t does not contain 0-th GID
> 1188451318-1305386600.768476-degas.como.group in the
> child_table[]/nclog_commset.c:CLOG_CommSet_merge() -
> CLOG_CommSet_sync_IDs() fails!
> Backtrace of the callstack at rank 2:
> At [0]:
> LINUXlib/mpsimpleprog_vienna(CLOG_Util_abort+0x73)[0x6e2377]
> At [1]:
> LINUXlib/mpsimpleprog_vienna(CLOG_CommSet_merge+0x2d2)[0x6dec1f]
> At [2]:
> LINUXlib/mpsimpleprog_vienna(CLOG_Merger_sort+0x1d)[0x6e9c44]
> At [3]:
> LINUXlib/mpsimpleprog_vienna(CLOG_Converge_sort+0x20)[0x6e631e]
> At [4]:
> LINUXlib/mpsimpleprog_vienna(MPE_Finish_log+0x114)[0x6e2144]
> At [5]: LINUXlib/mpsimpleprog_vienna(MPI_Finalize+0x58c)[0x6b228a]
> At [6]:
> LINUXlib/mpsimpleprog_vienna(_ZN5boost3mpi11environmentD1Ev+0x63)[0x69dc53]
> At [7]: LINUXlib/mpsimpleprog_vienna(main+0x56e)[0x5909d6]
> At [8]: /lib64/libc.so.6(__libc_start_main+0xe6)[0x3e4c21e576]
> At [9]: LINUXlib/mpsimpleprog_vienna[0x58fca9]
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 2
> [mpiexec at degas.como.group] ONE OF THE PROCESSES TERMINATED BADLY:
> CLEANING UP
> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
> Please help!
> Thanks,
> Peter
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
