[mpich-discuss] how to make the hosts files
    hyunduk kim
    fororigin at gmail.com
    Wed May 11 03:22:03 CDT 2011
Dear Pavan Balaji
As your comment, I modified my command, however I received unexpected
massage as below
[root at francium examples]# mpiexec -n 10 -machinefile
/usr/local/mpich2/machine/hosts ./cpi
ssh: connect to host host1 port 22: Connection timed out
ssh: connect to host host2 port 22: Connection timed out
I don't know what is wrong?
I just used mpich2 under multi-core environment.
2011/5/11 Pavan Balaji <balaji at mcs.anl.gov>
> On 05/11/2011 12:30 AM, hyunduk kim wrote:
>> I was trying to install mpich2. mpich2 was running with cpi file after
>> the setup.
>> before running the mpiexec, I made the machine file 'hosts" under the
>> install directory as like /usr/local/mpich2/machine.
>> (in my case, I use the multi-core 2 cpu and one cpu has 6 core)
>> host1 slots=6
>> host2 slots=6
> The format is:
> host1:6
> host2:6
>  and I started the test.
>> #> mpiexec -n 12 -machinefile hosts ./cpi
>> After run, I was received a error messages as following
> If you use the -machinefile or -f option for the host file, the
> HYDRA_HOST_FILE environment variable is ignored. Do you have the "hosts"
> file in the current directory? Otherwise, you should use:
> mpiexec -n 12 -machinefile /usr/local/mpich2/machine/hosts ./cpi
>  [root at francium examples]# mpiexec -f machinefile -n 12 ./cpi
>> [mpiexec at francium.kaist.ac.kr <mailto:mpiexec at francium.kaist.ac.kr>]
>> HYDU_parse_hostfile (./utils/args/args.c:316): unable to open host file:
>> machinefile
> Do you have a file called "machinefile" in your current directory?
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110511/9be8ccef/attachment-0001.htm>
