[mpich-discuss] mpich2-1.3.2p1 compile error
    Wei Huang
    huangwei at ucar.edu
    Wed May  4 11:52:12 CDT 2011
Anthony,
Probably line:
PATH: /neem2/huangwei/apps/mpich2-1.4rc2/bin
caused the confusion, but it is the log file for 1.3.2p1.
(As I tried  1.4rc2 before and put that line into my path.)
Attached are two files of the configure and make output
(saved to files).
Wei Huang
VETS/CISL
National Center for Atmospheric Research
P.O. Box 3000 (1850 Table Mesa Dr.)
Boulder, CO 80307-3000 USA
(303) 497-8924
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110504/a93b87f6/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110504/a93b87f6/attachment-0003.obj>
On May 4, 2011, at 10:43 AM, Anthony Chan wrote:
> The config.log you sent is from mpich2-1.4rc2 not mpich2-1.3.2p1
> that you originally reported to have problem.  Also pgcc does not seem
> to have option -fvisibility=hidden which AFAIK is a gcc option...
> Need your configure and make outputs to find out what's wrong.
>> config.log which is generated automatically by configure isn't what
>> I need yet. We need the configure and make outputs as shown
>> on your screen, see MPICH2's top-level README file for more details.
>>> Attached is the config.log.
>>> Thanks,
>>> Wei Huang
>>> VETS/CISL
>>> (303) 497-8924
>>> On May 4, 2011, at 9:40 AM, Anthony Chan wrote:
>>>> Can you send us the configure and make outputs as stated in the
>>>> README ?
>>>> A.Chan
>>>>> Hi, there,
>>>>> I tried to compile mpich2-1.3.2p1, and configure with:
>>>>> setenv CC pgcc
>>>>> setenv FC pgf90
>>>>> ./configure \
>>>>> --prefix=/neem2/huangwei/apps/mpich2-1.3.2p1
>>>>> When I compile, I go the error message below.
>>>>> How do I solve this issue?
>>>>> Thanks,
>>>>> Wei
>>>>> VETS/CISL
>>>>> (303) 497-8924
>>>>> Making all in src
>>>>> make[5]: Entering directory
>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc/src'
>>>>> CC topology.lo
>>>>> pgcc-Warning-Unknown switch: -fvisibility=hidden
>>>>> PGC-S-0170-Designated initializers are not supported (topology.c:
>>>>> 497)
>>>>> 509)
>>>>> PGC/x86-64 Linux/x86-64 6.2-5: compilation completed with severe
>>>>> errors
>>>>> make[5]: *** [topology.lo] Error 1
>>>>> make[5]: Leaving directory
>>>>> make[4]: *** [all-recursive] Error 1
>>>>> make[4]: Leaving directory
>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc'
>>>>> make[3]: *** [all-recursive] Error 1
>>>>> make[3]: Leaving directory
>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra'
>>>>> make[2]: *** [all-redirect] Error 1
>>>>> make[2]: Leaving directory
>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm'
>>>>> make[1]: *** [all-redirect] Error 2
>>>>> make[1]: Leaving directory
>>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src'
>>>>> make: *** [all-redirect] Error 2
>>>>> compiler info:
>>>>> neem>pgcc -V
>>>>> pgcc 6.2-5 64-bit target on x86-64 Linux
>>>>> Copyright 1989-2000, The Portland Group, Inc. All Rights
>>>>> Reserved.
>>>>> Copyright 2000-2006, STMicroelectronics, Inc. All Rights
>>>>> Reserved.
>>>>> neem>pgf90 -V
>>>>> pgf90 6.2-5 64-bit target on x86-64 Linux
>>>>> Reserved.
>>>>> Reserved.
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list
>>>>> mpich-discuss at mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
