[mpich-discuss] mpich2-1.3.2p1 compile error
    Anthony Chan
    chan at mcs.anl.gov
    Wed May  4 11:43:47 CDT 2011
The config.log you sent is from mpich2-1.4rc2 not mpich2-1.3.2p1
that you originally reported to have problem.  Also pgcc does not seem
to have option -fvisibility=hidden which AFAIK is a gcc option...
Need your configure and make outputs to find out what's wrong.
----- Original Message -----
> config.log which is generated automatically by configure isn't what
> I need yet. We need the configure and make outputs as shown
> on your screen, see MPICH2's top-level README file for more details.
> > Attached is the config.log.
> > Thanks,
> > Wei Huang
> > huangwei at ucar.edu
> > VETS/CISL
> > National Center for Atmospheric Research
> > P.O. Box 3000 (1850 Table Mesa Dr.)
> > Boulder, CO 80307-3000 USA
> > (303) 497-8924
> > On May 4, 2011, at 9:40 AM, Anthony Chan wrote:
> > > Can you send us the configure and make outputs as stated in the
> > > README ?
> > > A.Chan
> > >> Hi, there,
> > >> I tried to compile mpich2-1.3.2p1, and configure with:
> > >> setenv CC pgcc
> > >> setenv FC pgf90
> > >> ./configure \
> > >> --prefix=/neem2/huangwei/apps/mpich2-1.3.2p1
> > >> When I compile, I go the error message below.
> > >> How do I solve this issue?
> > >> Thanks,
> > >> Wei
> > >> VETS/CISL
> > >> (303) 497-8924
> > >> Making all in src
> > >> make[5]: Entering directory
> > >> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc/src'
> > >> CC topology.lo
> > >> pgcc-Warning-Unknown switch: -fvisibility=hidden
> > >> PGC-S-0170-Designated initializers are not supported (topology.c:
> > >> 497)
> > >> 509)
> > >> PGC/x86-64 Linux/x86-64 6.2-5: compilation completed with severe
> > >> errors
> > >> make[5]: *** [topology.lo] Error 1
> > >> make[5]: Leaving directory
> > >> make[4]: *** [all-recursive] Error 1
> > >> make[4]: Leaving directory
> > >> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc'
> > >> make[3]: *** [all-recursive] Error 1
> > >> make[3]: Leaving directory
> > >> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra'
> > >> make[2]: *** [all-redirect] Error 1
> > >> make[2]: Leaving directory
> > >> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm'
> > >> make[1]: *** [all-redirect] Error 2
> > >> make[1]: Leaving directory
> > >> `/neem2/huangwei/src/mpich2-1.3.2p1/src'
> > >> make: *** [all-redirect] Error 2
> > >> compiler info:
> > >> neem>pgcc -V
> > >> pgcc 6.2-5 64-bit target on x86-64 Linux
> > >> Copyright 1989-2000, The Portland Group, Inc. All Rights
> > >> Reserved.
> > >> Copyright 2000-2006, STMicroelectronics, Inc. All Rights
> > >> Reserved.
> > >> neem>pgf90 -V
> > >> pgf90 6.2-5 64-bit target on x86-64 Linux
> > >> Reserved.
> > >> Reserved.
> > >> _______________________________________________
> > >> mpich-discuss mailing list
> > >> mpich-discuss at mcs.anl.gov
> > >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
