[mpich-discuss] mpicexec segmentation fault
MICHAEL S DAVIS
msdavis at s383.jpl.nasa.gov
Thu Mar 31 17:34:31 CDT 2011
I recently downloaded mpich2-1.3.2p1 and compiled and installed the
software with no errors.
When I test run the test command
[root at host bin]# ./mpiexec -np 1 -machinefile machines /bin/hostname
Segmentation fault
[root at host bin]#
Here is the build information
[root at host bin]# ./mpiexec -info
HYDRA build details:
Version: 1.3.2p1
Release Date: Mon Feb 14 19:07:22 CST 2011
CC: gcc
CXX: c++
F77: f77
F90:
Configure options: '--prefix=/opt/mpich2'
'--disable-option-checking' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS= '
'LIBS=-lrt -lpthread ' 'CPPFLAGS=
-I/var/tmp/mpich2-1.3.2p1/src/mpl/include
-I/var/tmp/mpich2-1.3.2p1/src/openpa/src
-I/var/tmp/mpich2-1.3.2p1/src/mpid/ch3/include
-I/var/tmp/mpich2-1.3.2p1/src/mpid/common/datatype
-I/var/tmp/mpich2-1.3.2p1/src/mpid/common/locks
-I/var/tmp/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include
-I/var/tmp/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include
-I/var/tmp/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
-I/var/tmp/mpich2-1.3.2p1/src/util/wrappers
-I/var/tmp/mpich2-1.3.2p1/src/util/wrappers'
Process Manager: pmi
Launchers available: ssh rsh fork slurm ll lsf
sge persist
Binding libraries available: hwloc plpa
Resource management kernels available: none slurm ll lsf sge pbs
Checkpointing libraries available:
Demux engines available: poll select
[root at host bin]#
I also tried using the intel compilers and get the same result. The
software builds and installs, but I can not run mpiexec without getting
a segmentation fault. I have mpich1 running on this cluster and have no
problems with it.
I can ssh between nodes with no problems.
I am running Red Hat Enterprise Linux WS release 4 (Nahant Update 9) if
that makes any difference.
Can anybody tell me what might be the problem or how to fix this issue.
thanks
Mike
Michael S. Davis
Systems Engineer
Jet Propulsion Laboratory
Phone: (818) 393-7131
Cell: (818) 653-9564
DISCLAIMER: All opinions presented herein are my own and do not, in any way, represent the opinion or policy of JPL, Caltech or NASA.
(JPL now requires notice in all electronic communication)
