[mpich-discuss] Hydra: prefer localhost instead of first in host file
Torquil Macdonald Sørensen torquil at gmail.com
Sun Mar 27 09:07:29 CDT 2011
Hi!
I'm in an environment with multiple computers sharing the same filesystem.
I'm using the latest Mpich2 with hydra and a host file that looks like
hostA:4
hostB:4
hostC:4
The host file is the same on all the computers, because it is on a shared
filesystem.
Sometimes I want to run with 12 processes and in that case this works fine.
However, sometime I want only 4 processes, and I would like them to run on the
computer I'm currently logged into (not always hostA). E.g. I want "mpiexec -n 4
prog.exe" to start 4 processes on hostB if I run this command from hostB.
That way, I can e.g. run three different simulations, each of 4 processes, each
on its own computer, just by executing "mpiexec -n 4 prog.exe" on each
individual computer.
With earlier versions of Mpich2 this seemed to work as I wished (not using Hydra).
Is there a way of making Mpich2 prefer to start the first 4 process on the local
machine instead of starting them on the computer listed first in the host file?
I'v been reading the Hydra documentation, obviously without finding out if this
can be accomplished.
Best regards
Torquil Sørensen
