[mpich-discuss] Connect MPI application to a Web service
Hisham Adel
hosham2004 at yahoo.com
Thu Mar 17 09:33:22 CDT 2011
First thanks for your reply. I am searching for these APIs but I didn't find
anything till now.
For you points here is my reply:
OK, but does that assume eternal life in perfect health of both the.....
>I want to run mpiexec one time only because the program load some data in memory
>and I don't want to load the data for each client because it is the same.
So in this case your app doesn't spawn a process -- your seq C++
subsystem isn't a program, but a shared library.........
> Yes, my seq C++ subsystem is a shared library
Well, you can, but not without spawning a separate process: as a
command line tool, mpiexec provides its own entry point. If you don't
mind this, you don't need JNI in the first place, but you possibly do.
> how ? I tried but I failed I don't know how to run the program, because in this
>case I will run it with Java not with mpiexec...
Otherwise there's the client-server approach: your MPI C++ system runs
as a whole separate server process, and the Java service code queries
the subservice thru tcp socket, RPC, or even something WS-ish if you
embed a small HTTP server and in your C++ code.
> I was thinking about this solution but I wanted to know if there is any APIs or
>not....
(You'd have to see what to do about potentially overlapping requests,
but if the main Java WS allows them, that'd be something to consider
regardless of the approach.)
For a mere proof-of-concept hack, you could just execute mpiexec from
Java as a separate process using something like Runtime.exec().
> If I used Runtime.exec(), how will I pass the user requests to the library ?
It seems that there no solution except the client-server approach; connecting
HTTP and C++.
I think I will work with it.
If you you have any other ideas, please let me know.
Thanks and Regards,
Hisham
Cc: Hisham Adel <hosham2004 at yahoo.com>
Sent: Wed, March 16, 2011 11:49:14 PM
Subject: Re: [mpich-discuss] Connect MPI application to a Web service
There might be some sort of API for this, but I'll let someone else
answer that part, and throw in a few alternative ideas
instead/meanwhile:
> I don't want to run mpiexec for each client request. I want to run mpiexec only
>one time, then keep the program running waiting for other clients requests.
external process and your app's own interface to it? In a server
context I'd consider relaxing the "only one time" design to something
closer to "not too often". Enabling the system to be self-healing in
this aspect adds complexity, but depending on the case could be well
worth its cost in robustness.
> For the sequential version [..] JNI.
subsystem isn't a program, but a shared library. The Java code
triggers a call to a native C++ function directly; the main() entry
point is that of the `java' executable (possibly an app server or so).
Is that correct?
> for the parallel version [..] I don't know how to
> run the program in this case; I can't use mpiexec.
If your main priority is to avoid any new processes, and/or using JNI
is mandatory by requirement, I can't think of much except what I
mentioned at the top (some API I'm not familiar with).
Hope this helps,
Nicolás
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110317/3ef23ac9/attachment.htm>
