[mpich-discuss] mpich2mpi.dll not found
    Phelan Jr., Frederick R. Dr.
    frederick.phelan at nist.gov
    Wed Mar 16 18:40:35 CDT 2011
Jayesh,
Thanks very much. That indeed was the issue.
Appreciate it!
Fred Phelan
Frederick R. Phelan Jr., Ph.D.
Complex Fluids Group
Polymers Division
National Institute of Standards and Technology
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, March 16, 2011 5:41 PM
Cc: Phelan Jr., Frederick R. Dr.
Subject: Re: [mpich-discuss] mpich2mpi.dll not found
HI,
 This usually happens when you have a 64-bit version of MPICH2 installed and the application was compiled with a 32-bit version of MPICH2 (The dlls installed should be 64-bit for 64-bit apps and 32-bit for 32-bit apps). Let me know if it sounds familiar.
-Jayesh
----- Original Message -----
From: "Phelan Jr., Frederick R. Dr." <frederick.phelan at nist.gov>
Sent: Tuesday, March 15, 2011 4:49:51 PM
Subject: [mpich-discuss] mpich2mpi.dll not found
When I run the same thing with -localonly I get the error: mpich2mpi.dll not found ... the files are installed, so not sure what that means.
Fred
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Phelan Jr., Frederick R. Dr.
Sent: Tuesday, March 15, 2011 5:05 PM
Subject: Re: [mpich-discuss] Error 123
Forgot to add ... at the point that the out file ends, the program is just sitting there. Have to click break.
Fred
Sent: Tuesday, March 15, 2011 4:55 PM
I ran this with the WMPIEXEC program and the -verbose option. The lammps program never executes. Is the output file in anyway meaningful as to why?
Fred
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of SULLIVAN David (AREVA)
Sent: Tuesday, March 15, 2011 1:37 PM
Fred,
I use a program that takes command line arguments. For example a typical call would be:
mpiexec -n 12 -f nodefile mcnp5.mpi -i input -o output wwinp=wwfile
I have never run into the problems you have describe.
Dave
Sent: Tuesday, March 15, 2011 1:17 PM
To: Nicolas Rosner
Cc: mpich-discuss at mcs.anl.gov
There is now question that what is happening here is related the seeming inability of the mpiexec to run a program that requires command line arguments, which in some cases involves use of the < symbol. However, -i can also be used in place of < ... the results is the same.
At this point I have tried every conceivable variation:
a) C:\LAMMPS\example\micelle>"C:\Program Files\MPICH2\bin\mpiexec" -n 2 -dir c:\lammps\example\micelle\ c:\bin\lmp_win_mpi.exe < c:\lammps\example\micelle\in.micelle
Result: Does not recognize data redirection and lammps exits
b) C:\LAMMPS\example\micelle>"C:\Program Files\MPICH2\bin\mpiexec" -n 2 -dir c:\lammps\example\micelle\ "c:\bin\lmp_win_mpi.exe < c:\lammps\example\micelle\in.micelle"
Result: Error 123
c) C:\LAMMPS\example\micelle>"C:\Program Files\MPICH2\bin\mpiexec" -n 2 -dir c:\lammps\example\micelle\ c:\bin\lmp_win_mpi.exe -i c:\lammps\example\micelle\in.micelle
Result: Does not recognize command line arguments and lammps exits
d) C:\LAMMPS\example\micelle>"C:\Program Files\MPICH2\bin\mpiexec" -n 2 -dir c:\lammps\example\micelle\ "c:\bin\lmp_win_mpi.exe -i c:\lammps\example\micelle\in.micelle"
Result: Error 123
Does anyone have a working example of running using mpich that runs a program that makes use of command line arguments?
Fred
Sent: Tuesday, March 15, 2011 12:43 PM
To: Phelan Jr., Frederick R. Dr.
This part of your command line looks problematic:
> ... "c:\bin\lmp_win_mpi.exe < c:\lammps\example\micelle\in.micelle"
I'm neither a Windows nor a LAMMPS user, but at least on most Linux/Unix shells, quoting a redirection symbol prevents the shell from interpreting it as such, e.g.
  "program name" "foo bar" < "input file"
looks quite reasonable, while
  "program name" "foo bar < input file"
seems odd, since that would pass the whole 2nd string (incl. `<') as an argument to the program.
Hope this helps,
Nicolás
mpich-discuss mailing list
