[mpich-discuss] Connect MPI application to a Web service
Hisham Adel hosham2004 at yahoo.com
Wed Mar 16 14:44:51 CDT 2011
I have a problem. It is little bit complicated.
Here it is:
I have a parallel application written with C++ and MPI. I want to connect it to
a web service.
I don't want to run mpiexec for each client request. I want to run mpiexec only
one time, then keep the program running waiting for other clients requests.
The web service is written in Java. So, I want to make the connection between
the Parallel C++ code and JAVA.
For the sequential version of this application, the connection between the web
services and the C++ application done with Java Native Interface (JNI).
I tried to do the same for the parallel version, but it doesn't work. Because I
don't know how to run the program in this case; I can't use mpiexec.
So, do you have a solution to this problem ?
Thanks for your time.
Hisham
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110316/967b2328/attachment.htm>
