[mpich-discuss] No requirement for smpd.exe in MPICH2-1.3.3
Robert Hunter Robert.M.Hunter at usace.army.mil
Tue Mar 15 09:17:00 CDT 2011
Jayesh,
I believe the problem may lie in the fact that the smpd needs to write to the registry in HKEY_LOCAL_MACHINE, which I don't have permission to write into. I tried the same steps outlined below on a machine that I do have permission to write into HKEY_LOCAL_MACHINE and I was able to run.
Do you know of anyway to override the default value of the registry key? In looking through the source I couldn't find any. Perhaps future versions could allow for registry entries to be written to HKEY_CURRENT_USER?
Bobby
On Mar 10, 2011, at 4:55 PM, Jayesh Krishna wrote:
> Hi,
>  Try copying the *.dlls to C:\mpich2\bin and let us know if it works.
> Regards,
> Jayesh
> From: "Robert Hunter" <Robert.M.Hunter at usace.army.mil>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Wednesday, March 9, 2011 4:33:11 PM
> Subject: Re: [mpich-discuss] No requirement for smpd.exe in MPICH2-1.3.3
> Jayesh,
> Thanks for the information regarding smpd.exe.
> I still have a question as to how I would run without installing smpd. I've tried the following:
> I copied smpd.exe, mpiexec.exe to a dir named C:\mpich2\bin, I then added this dir my to my PATH. I also copied mpich2mpi.dll, mpich2nemesis.dll, and cpi.exe to C:\mpich2 . I then unistalled mpich2-1.3.3rc1 and rebooted. Next I tried the following in the c:\mpich2 dir ".\bin\mpiexec.exe -localonly 2 cpi.exe" The following output is what I get:
> C:\mpich2>.\bin\mpiexec.exe -localonly 2 .\cpi.exe
> Unknown option: -d
> Error while connecting to host, No connection could be made because the
> target machine actively refused it. (10061)
> Connect on sock (host=bhunter-lt.erdc.hpc.mil, port=8676) failed,
> exhaused all end points
> Unable to connect to 'bhunter-lt.erdc.hpc.mil:8676',
> sock error: Error = -1
> ReadFile() failed, error 109
> unable to start the local smpd manager.
> C:\mpich2>
> Note: I don't have admin privileges on the machine.
> Thanks for any help.
> Bobby
> On Mar 3, 2011, at 11:18 AM, Jayesh Krishna wrote:
> Hi,
> MPICH2 1.3.3 did not remove the requirement for smpd.exe .
> When using the "-localonly' option with mpiexec you do not need to have SMPD installed on the system. MPICH2 1.3.3 removed firewall issues when starting MPI jobs with the "-localonly" option.
> So you still need SMPD to be available, but you don't need to install SMPD or worry about firewall issues when running all MPI processes on the local node.
> Regards,
> Jayesh
> From: "Robert Hunter" < Robert.M.Hunter at usace.army.mil >
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, March 3, 2011 7:33:21 AM
> Subject: [mpich-discuss] No requirement for smpd.exe in MPICH2-1.3.3
> I came across a note @ boinc.berkley.edu that stated mpich2-1.3.3 should remove the requirement for smpd.exe, as well as no firewall issues on Windows. I've downloaded and tried this method with the mpich-1.3.3r1-win-ia32 install and using the following command line "mpiexec -localonly -n 2 -channel nemesis:none cpi.exe" but it simply returns the following error "Uknown option -d". Will these functionality be included in the MPICH2-1.3.3 release?
> Thanks,
> Bobby
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110315/7498c09a/attachment.htm>
