[mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Mar 15 08:55:22 CDT 2011
Perhaps the non-portable FLUSH might solve your problem (add FLUSH after the WRITEs - there should also be some way to specify on stdout buffering for your program).
Jayesh
----- Original Message -----
Sent: Tuesday, March 8, 2011 1:28:45 AM
Subject: Re: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
Hi
I have noticed problems in running Fortran MPICH2 applications. Basically, the prints to standard output from a Fortran module don't seem to work properly. They appear after the program has exited. This problem doesn't exist with C program.
I did a test with "fpi.f" example. I have used MPICH2-1.3.3rc1 and mingw-w64-1.0-bin_i686-mingw_20101129 compiler. (I have tested it with GCC 4.5.2 provided by www.equation.com and the results are same.) Below are screen shots when I run fpi.exe using mpiexec and then directly:
C:\tmp\mpi> "C:\Program Files\MPICH2\bin"\mpiexec.exe -n 1 -localonly fpi.exe
9
12
0
Process 0 of 1 is alive
Enter the number of intervals: (0 quits)
pi is approximately: 3.1426214565576127 Error is: 0.0010288029678196
pi is approximately: 3.1421713566497975 Error is: 0.0005787030600044
C:\tmp\mpi> fpi.exe
9
0
C:\tmp\mpi>
I did not find any options for mpiexec to overcome this. Thanks for your help.
Best Regards
Arun
On 23-02-2011 10:14, Arun Murthy wrote:
Hi Jayesh
Thanks for your answer. For the moment, I will continue to work with GCC V4.5.x.
But, this raises one doubt in my mind. Perhaps, this is not the right forum to raise this question. Nevertheless, I am counting on the experience and knowledge of people at ANL and on this forum. What happens when I migrate to a new GCC compiler, say V4.7 or V4.8 or even V5. Will there be a backward compatibility with the MPICH2 libraries or will I have to rebuild MPICH2 on the new compiler suite? I have encountered several such backward compatibility problems with GCC on Linux.
Thanks for your answers
Best Regards
Arun
On 22-02-2011 22:27, Jayesh Krishna wrote:
It is possible that mingw gcc version 4.4.3 is old (64-bit was in the nascent stage) and does not support 64-bit libs generated from Windows libraries. I test libmpi.a using mingw gcc version 4.6.0 .
Jayesh
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Tuesday, February 22, 2011 9:31:21 AM
Hi Jayesh
I am linking with libmpi.a. I am able to run the code after compiling it
with V4.5.3.
With Best Regards
Arun
On 22-02-2011 20:55, Jayesh Krishna wrote:
Are you linking using libmpi.a or mpi.lib ? Are you able to run your code after compiling it with V4.5.3 ?
Jayesh
Sent: Tuesday, February 22, 2011 7:05:51 AM
Hi
I downloaded the MPICH2-1.3.2p1 Windows EM64T/AMD64 (binary) onto my Windows-XP 64bit machine. I tried to use it with two GNU compilers: V4.4.3 and V.4.5.3. Basically, I tried to link the icpi.c example into an executable. With GCC V4.4.3, I get undefined symbols, while with V4.5.3, it works well. Does it mean that, if I want to use GCC V4.4.3, I need to rebuild MPICH2 from the source using the V4.4.3 compiler?
The output details of my trials are below.
With Best Regards
Arun
D:\tmp>"C:\Program Files\mingw_443\64bit\bin\gcc.exe" --ver
Built by Equation Solution <http://www.Equation.com> .
Using built-in specs.
Target: x86_64-pc-mingw32
Configured with: ../gcc-4.4.3-mingw/configure --host=x86_64-pc-mingw32 --build=x86_64-unknown-linux-gnu --target=x86_64-pc-mingw32 --prefix=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/gcc/4.4.3 --with-gmp=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/gmp --with-mpfr=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/mpfr --with-mpc=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/mpc --with-sysroot=/home/gfortran/gcc-home/binary/mingw32/cross/x86_64/gcc/4.4.3 --with-gcc --with-gnu-ld --with-gnu-as --disable-shared --disable-nls --disable-tls --enable-libgomp --enable-languages=c,fortran,c++ --enable-threads=win32 --disable-win32-registry
Thread model: win32
gcc version 4.4.3 (GCC)
D:\tmp>"C:\Program Files\mingw_443\64bit\bin\gcc.exe" -I"C:\Program Files\MPICH2\include" icpi.c -L"C:\Program Files\MPICH2"\lib -lmpi -o icpi.exe
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x76): undefined reference to `MPI_Init'
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x87): undefined reference to `MPI_Comm_size'
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x98): undefined reference to `MPI_Comm_rank'
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0xab): undefined reference to `MPI_Get_processor_name'
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x142): undefined reference to `MPI_Wtime'
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x16c): undefined reference to `MPI_Bcast'
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x237): undefined reference to `MPI_Reduce'
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x2b4): undefined reference to `MPI_Wtime'
C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x31b): undefined reference to `MPI_Finalize'
collect2: ld returned 1 exit status
D:\tmp>"C:\Program Files\mingw-w64\bin\x86_64-w64-mingw32-gcc.exe" --ver
COLLECT_GCC=C:\Program Files\mingw-w64\bin\x86_64-w64-mingw32-gcc.exe
COLLECT_LTO_WRAPPER=c:/program files/mingw-w64/bin/../libexec/gcc/x86_64-w64-min
gw32/4.5.3/lto-wrapper.exe
Target: x86_64-w64-mingw32
Configured with: ../../../build/gcc/src/configure --target=x86_64-w64-mingw32 --prefix=/c/buildbot/mingw-w64/mingw32/mingw-x86-x86_64/build/build/root --with-sysroot=/c/buildbot/mingw-w64/mingw32/mingw-x86-x86_64/build/build/root --enable-languages=all,obj-c++ --enable-fully-dynamic-string --disable-multilib
Thread model: win32
gcc version 4.5.3 20110207 (prerelease) (GCC)
D:\tmp>"C:\Program Files\mingw-w64\bin\x86_64-w64-mingw32-gcc.exe" -I"C:\Program Files\MPICH2\include" icpi.c -L"C:\Program Files\MPICH2"\lib -lmpi -lfmpich2g -
o icpi.exe
SUCCESS
D:\tmp>
On 11-01-2011 18:53, Arun Murthy wrote:
Hi Jayesh
Yes, I linked icpi.o with mpi.lib. Happy to hear that Mingw64 support will be available this month. I can wait for a couple of weeks for the next release. In the meantime, if you want me to test the pre-release version, I would be happy to do that.
Best regards
Arun
On 11-01-2011 17:10, Jayesh Krishna wrote:
Are you trying to link your code with mpi.lib ? Mingw compilers may not be playing nice with the windows libraries. AFAICT we added support for mingw 64-bit compilers (*.a libraries compatible with mingw 64-bit compilers) after 1.3.1 was released. It should be available in the next release, 1.3.2, due this month.
(PS: If you need it sooner than that let me know and I can get you a custom build for development purposes)
Jayesh
Sent: Tuesday, January 11, 2011 2:12:01 AM
Hi Jayesh
I opened CMD with "Run as administrator" and did the following:
C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot c:\tmp\icpi.exe
Job terminated with following error message:
Error posting writev, A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call.(10058)
unable to post a write for the next command,
sock error: Error = 10058
unable to post a write of the closed_request command to the parent context.
unable to close the stdin context.
state machine failed.
C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot -exitcodes c:\tmp\icpi.exe
rank: node: exit code
0: Arun-PC: -1073741819
1: Arun-PC: -1073741819
C:\tmp>"C:\Program Files\MPICH2\bin"\smpd -status
smpd running on Arun-PC
Best Regards
Arun
On 10-01-2011 22:08, Jayesh Krishna wrote:
Can you try running the job from an administrator command prompt (Note that opening a command prompt from an administrator account does not give you an admin command prompt. Right-click on the command prompt icon and select "Run as administrator" to get an admin command prompt) and see if it works ?
Can you also check the status of the MPICH2 process manager (Type "smpd -status" at the command prompt)?
Jayesh
From: Arun Murthy <arun.murthy at fluidyn.com> To: Jayesh Krishna <jayesh at mcs.anl.gov> Cc: mpich-discuss at mcs.anl.gov Sent: Mon, 10 Jan 2011 01:33:41 -0600 (CST)
Hi Jayesh
I tried that. It did not help. Here is the response:
C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot icpi.exe
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\6308
registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\808
registry k ey, error 5, Access is denied.
When I killed the job by<CTRL> C, the following messages appeared:
mpiexec aborting job...
received suspend command for a pmi context that doesn't exist: unmatched
id = 1
job aborted:
rank: node: exit code[: error message]
0: Arun-PC: -1073741819: mpiexec aborting job
Terminate batch job (Y/N)? y
When I tried the same thing on the pre-built "cpi.exe", I get the same
messages that I got with "icpi.exe", but it still works:
C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot cpi
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\4544
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7288
Enter the number of intervals: (0 quits) 9
pi is approximately 3.1426214565576127, Error is 0.0010288029678196
wall clock time = 0.000077
When I killed this job by<CTRL> C, the following messages appeared:
SuspendThread failed with error 5 for process
0:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
unable to suspend process.
unable to read the cmd header on the pmi context, Error = -1.
Error posting readv, An existing connection was forcibly closed by the
remote host.(10054)
1:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
remote host.(10054)
received kill command for a pmi context that doesn't exist: unmatched id = 0
job aborted:
0: Arun-PC: 123: process 0 exited without calling finalize
1: Arun-PC: 123: process 1 exited without calling finalize
Does it have anything to do with an incorrect node (-1073741819) on
which mpiexec is trying to launch the processes? Thanks for your help.
Best Regards
Arun
On 07-01-2011 22:11, Jayesh Krishna wrote:
Can you try running your program with the "-localroot" option and let us know if it works for you (mpiexec -n 2 -localroot icpi.exe)?
Jayesh
From: "Arun Murthy" <arun.murthy at fluidyn.com> To: mpich-discuss at mcs.anl.gov Sent: Friday, January 7, 2011 12:56:17 AM
Subject: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
Hi
I am trying to use MPICH2 on Windows 7 64bit (installed from
mpich2-1.3.1-win-x86-64.msi) along with Mingw-w64 compiler suite
(mingw-w64-1.0-bin_i686-mingw_20101129).
I tried to compile-link the example "icpi.c" using following command:
C:\MinGW\mingw-w64-1.0-bin_i686-mingw_20101129\bin\x86_64-w64-mingw32-gcc.exe
Files\MPICH2\lib" -lmpi -o icpi.exe
I could get the executable, but it doesn't run with any number of
processors. When run with mpiexec, it aborts without any message. I
could run the pre-built "cpi.exe" with any number of CPU's. I don't have
MS Visual Studio on my machine. Can anyone help?
By the way, the 32-bit version of MPICH1 (1.2.5 SDK.gcc) works well with
Mingw-w32 compiler suite.
Thanks
Arun
mpich-discuss mailing list mpich-discuss at mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
