[mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
    Arun Murthy
    arun.murthy at fluidyn.com
    Tue Mar  8 01:28:45 CST 2011
Hi
I have noticed problems in running Fortran MPICH2 applications.
Basically, the prints to standard output from a Fortran module don't
seem to work properly. They appear after the program has exited. This
problem doesn't exist with C program.
I did a test with "fpi.f" example. I have used MPICH2-1.3.3rc1 and
mingw-w64-1.0-bin_i686-mingw_20101129 compiler. (I have tested it with
GCC 4.5.2 provided by www.equation.com and the results are same.) Below
are screen shots when I run fpi.exe using mpiexec and then directly:
C:\tmp\mpi>*"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 1 -localonly
fpi.exe*
9
12
0
  Process            0  of            1  is alive
Enter the number of intervals: (0 quits)
   pi is approximately: 3.1426214565576127  Error is: 0.0010288029678196
   pi is approximately: 3.1421713566497975  Error is: 0.0005787030600044
C:\tmp\mpi>*fpi.exe*
9
0
C:\tmp\mpi>
I did not find any options for mpiexec to overcome this. Thanks for your
help.
Best Regards
Arun
On 23-02-2011 10:14, Arun Murthy wrote:
> Hi Jayesh
> Thanks for your answer. For the moment, I will continue to work with
> GCC V4.5.x.
> But, this raises one doubt in my mind. Perhaps, this is not the right
> forum to raise this question. Nevertheless, I am counting on the
> experience and knowledge of people at ANL and on this forum. What
> happens when I migrate to a new GCC compiler, say V4.7 or V4.8 or even
> V5. Will there be a backward compatibility with the MPICH2 libraries
> or will I have to rebuild MPICH2 on the new compiler suite? I have
> encountered several such backward compatibility problems with GCC on
> Linux.
> Thanks for your answers
> Best Regards
> Arun
> On 22-02-2011 22:27, Jayesh Krishna wrote:
>> Hi,
>>   It is possible that mingw gcc version 4.4.3 is old (64-bit was in
>> the nascent stage) and does not support 64-bit libs generated from
>> Windows libraries. I test libmpi.a using mingw gcc version 4.6.0 .
>> Regards,
>> Jayesh
>> ----- Original Message -----
>> From: "Arun Murthy"<arun.murthy at fluidyn.com>
>> To: "Jayesh Krishna"<jayesh at mcs.anl.gov>
>> Cc: mpich-discuss at mcs.anl.gov
>> Sent: Tuesday, February 22, 2011 9:31:21 AM
>> Subject: Re: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64
>> compilers
>> Hi Jayesh
>> I am linking with libmpi.a. I am able to run the code after compiling it
>> with V4.5.3.
>> With Best Regards
>> Arun
>> On 22-02-2011 20:55, Jayesh Krishna wrote:
>>> Hi,
>>>    Are you linking using libmpi.a or mpi.lib ? Are you able to run
>>> your code after compiling it with V4.5.3 ?
>>> Regards,
>>> Jayesh
>>> To: mpich-discuss at mcs.anl.gov
>>> Sent: Tuesday, February 22, 2011 7:05:51 AM
>>> compilers
>>> Hi
>>> I downloaded the MPICH2-1.3.2p1 Windows EM64T/AMD64 (binary) onto my
>>> Windows-XP 64bit machine. I tried to use it with two GNU compilers:
>>> V4.4.3 and V.4.5.3. Basically, I tried to link the icpi.c example
>>> into an executable. With GCC V4.4.3, I get undefined symbols, while
>>> with V4.5.3, it works well. Does it mean that, if I want to use GCC
>>> V4.4.3, I need to rebuild MPICH2 from the source using the V4.4.3
>>> compiler?
>>> The output details of my trials are below.
>>> Thanks for your help.
>>> With Best Regards
>>> Arun
>>> D:\tmp>"C:\Program Files\mingw_443\64bit\bin\gcc.exe" --ver
>>> Built by Equation Solution<http://www.Equation.com>   .
>>> Using built-in specs.
>>> Target: x86_64-pc-mingw32
>>> Configured with: ../gcc-4.4.3-mingw/configure
>>> --host=x86_64-pc-mingw32 --build=x86_64-unknown-linux-gnu
>>> --target=x86_64-pc-mingw32
>>> --prefix=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/gcc/4.4.3
>>> --with-gmp=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/gmp
>>> --with-mpfr=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/mpfr --with-mpc=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/mpc
>>> --with-sysroot=/home/gfortran/gcc-home/binary/mingw32/cross/x86_64/gcc/4.4.3
>>> --with-gcc --with-gnu-ld --with-gnu-as --disable-shared
>>> --disable-nls --disable-tls --enable-libgomp
>>> --enable-languages=c,fortran,c++ --enable-threads=win32
>>> --disable-win32-registry
>>> Thread model: win32
>>> gcc version 4.4.3 (GCC)
>>> D:\tmp>"C:\Program Files\mingw_443\64bit\bin\gcc.exe" -I"C:\Program
>>> Files\MPICH2\include" icpi.c -L"C:\Program Files\MPICH2"\lib -lmpi
>>> -o icpi.exe
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x76):
>>> undefined reference to `MPI_Init'
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x87):
>>> undefined reference to `MPI_Comm_size'
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x98):
>>> undefined reference to `MPI_Comm_rank'
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0xab):
>>> undefined reference to `MPI_Get_processor_name'
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x142):
>>> undefined reference to `MPI_Wtime'
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x16c):
>>> undefined reference to `MPI_Bcast'
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x237):
>>> undefined reference to `MPI_Reduce'
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x2b4):
>>> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x31b):
>>> undefined reference to `MPI_Finalize'
>>> collect2: ld returned 1 exit status
>>> D:\tmp>"C:\Program Files\mingw-w64\bin\x86_64-w64-mingw32-gcc.exe"
>>> --ver
>>> COLLECT_GCC=C:\Program Files\mingw-w64\bin\x86_64-w64-mingw32-gcc.exe
>>> COLLECT_LTO_WRAPPER=c:/program
>>> files/mingw-w64/bin/../libexec/gcc/x86_64-w64-min
>>> gw32/4.5.3/lto-wrapper.exe
>>> Target: x86_64-w64-mingw32
>>> Configured with: ../../../build/gcc/src/configure
>>> --target=x86_64-w64-mingw32
>>> --prefix=/c/buildbot/mingw-w64/mingw32/mingw-x86-x86_64/build/build/root
>>> --with-sysroot=/c/buildbot/mingw-w64/mingw32/mingw-x86-x86_64/build/build/root
>>> --enable-languages=all,obj-c++ --enable-fully-dynamic-string
>>> --disable-multilib
>>> Thread model: win32
>>> gcc version 4.5.3 20110207 (prerelease) (GCC)
>>> -I"C:\Program Files\MPICH2\include" icpi.c -L"C:\Program
>>> Files\MPICH2"\lib -lmpi -lfmpich2g -
>>> o icpi.exe
>>> SUCCESS
>>> D:\tmp>
>>> On 11-01-2011 18:53, Arun Murthy wrote:
>>> Hi Jayesh
>>> Yes, I linked icpi.o with mpi.lib. Happy to hear that Mingw64
>>> support will be available this month. I can wait for a couple of
>>> weeks for the next release. In the meantime, if you want me to test
>>> the pre-release version, I would be happy to do that.
>>> Best regards
>>> Arun
>>> On 11-01-2011 17:10, Jayesh Krishna wrote:
>>> Hi,
>>> Are you trying to link your code with mpi.lib ? Mingw compilers may
>>> not be playing nice with the windows libraries. AFAICT we added
>>> support for mingw 64-bit compilers (*.a libraries compatible with
>>> mingw 64-bit compilers) after 1.3.1 was released. It should be
>>> available in the next release, 1.3.2, due this month.
>>> (PS: If you need it sooner than that let me know and I can get you a
>>> custom build for development purposes)
>>> Regards,
>>> Jayesh
>>> Sent: Tuesday, January 11, 2011 2:12:01 AM
>>> compilers
>>> Hi Jayesh
>>> I opened CMD with "Run as administrator" and did the following:
>>> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot
>>> c:\tmp\icpi.exe
>>> Job terminated with following error message:
>>> Error posting writev, A request to send or receive data was
>>> disallowed because the socket had already been shut down in that
>>> direction with a previous shutdown call.(10058)
>>> unable to post a write for the next command,
>>> sock error: Error = 10058
>>> unable to post a write of the closed_request command to the parent
>>> context.
>>> unable to close the stdin context.
>>> state machine failed.
>>> -exitcodes c:\tmp\icpi.exe
>>> rank: node: exit code
>>> 0: Arun-PC: -1073741819
>>> 1: Arun-PC: -1073741819
>>> C:\tmp>"C:\Program Files\MPICH2\bin"\smpd -status
>>> smpd running on Arun-PC
>>> Best Regards
>>> Arun
>>> On 10-01-2011 22:08, Jayesh Krishna wrote:
>>> Hi,
>>> Can you try running the job from an administrator command prompt
>>> (Note that opening a command prompt from an administrator account
>>> does not give you an admin command prompt. Right-click on the
>>> command prompt icon and select "Run as administrator" to get an
>>> admin command prompt) and see if it works ?
>>> Can you also check the status of the MPICH2 process manager (Type
>>> "smpd -status" at the command prompt)?
>>> Regards,
>>> Jayesh
>>> From: Arun Murthy<arun.murthy at fluidyn.com>   To: Jayesh
>>> Krishna<jayesh at mcs.anl.gov>   Cc: mpich-discuss at mcs.anl.gov Sent:
>>> Mon, 10 Jan 2011 01:33:41 -0600 (CST)
>>> compilers
>>> Hi Jayesh
>>> I tried that. It did not help. Here is the response:
>>> icpi.exe
>>> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\6308
>>> registry key, error 5, Access is denied.
>>> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\808
>>> registry k ey, error 5, Access is denied.
>>> When I killed the job by<CTRL>   C, the following messages appeared:
>>> mpiexec aborting job...
>>> received suspend command for a pmi context that doesn't exist:
>>> unmatched
>>> id = 1
>>> job aborted:
>>> rank: node: exit code[: error message]
>>> 0: Arun-PC: -1073741819: mpiexec aborting job
>>> Terminate batch job (Y/N)? y
>>> When I tried the same thing on the pre-built "cpi.exe", I get the same
>>> messages that I got with "icpi.exe", but it still works:
>>> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot cpi
>>> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\4544
>>> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7288
>>> Enter the number of intervals: (0 quits) 9
>>> pi is approximately 3.1426214565576127, Error is 0.0010288029678196
>>> wall clock time = 0.000077
>>> When I killed this job by<CTRL>   C, the following messages appeared:
>>> SuspendThread failed with error 5 for process
>>> 0:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
>>> unable to suspend process.
>>> unable to read the cmd header on the pmi context, Error = -1.
>>> Error posting readv, An existing connection was forcibly closed by the
>>> remote host.(10054)
>>> 1:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
>>> remote host.(10054)
>>> received kill command for a pmi context that doesn't exist:
>>> unmatched id = 0
>>> job aborted:
>>> 0: Arun-PC: 123: process 0 exited without calling finalize
>>> 1: Arun-PC: 123: process 1 exited without calling finalize
>>> Does it have anything to do with an incorrect node (-1073741819) on
>>> which mpiexec is trying to launch the processes? Thanks for your help.
>>> Best Regards
>>> Arun
>>> On 07-01-2011 22:11, Jayesh Krishna wrote:
>>> Hi,
>>> Can you try running your program with the "-localroot" option and
>>> let us know if it works for you (mpiexec -n 2 -localroot icpi.exe)?
>>> Regards,
>>> Jayesh
>>> From: "Arun Murthy"<arun.murthy at fluidyn.com>   To:
>>> mpich-discuss at mcs.anl.gov Sent: Friday, January 7, 2011 12:56:17 AM
>>> Subject: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64
>>> compilers
>>> Hi
>>> I am trying to use MPICH2 on Windows 7 64bit (installed from
>>> mpich2-1.3.1-win-x86-64.msi) along with Mingw-w64 compiler suite
>>> (mingw-w64-1.0-bin_i686-mingw_20101129).
>>> I tried to compile-link the example "icpi.c" using following command:
>>> C:\MinGW\mingw-w64-1.0-bin_i686-mingw_20101129\bin\x86_64-w64-mingw32-gcc.exe
>>> Files\MPICH2\lib" -lmpi -o icpi.exe
>>> I could get the executable, but it doesn't run with any number of
>>> processors. When run with mpiexec, it aborts without any message. I
>>> could run the pre-built "cpi.exe" with any number of CPU's. I don't
>>> have
>>> MS Visual Studio on my machine. Can anyone help?
>>> By the way, the 32-bit version of MPICH1 (1.2.5 SDK.gcc) works well
>>> with
>>> Mingw-w32 compiler suite.
>>> Thanks
>>> Arun
>>> _______________________________________________
>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110308/06c6ac01/attachment-0001.htm>
