[mpich-discuss] MPICH_PORT_RANGE
Nicolas Rosner
nrosner at gmail.com
Thu Mar 10 20:03:15 CST 2011
Q: I'm having a problem with mpd / mpdboot, can you fix it?
A: Short answer: No.
Longer answer: For all releases since MPICH2-1.2, we recommend using
the hydra process manager instead of mpd. The mpd process manager has
many problems, as well as an annoying mpdboot step that is fragile and
difficult to use correctly. The mpd process manager is deprecated at
this point, and most reported bugs in it will not be fixed.
http://wiki.mcs.anl.gov/mpich2/index.php/Frequently_Asked_Questions#Q:_I_don.27t_like_.3CWHATEVER.3E_about_mpd.2C_or_I.27m_having_a_problem_with_mpdboot.2C_can_you_fix_it.3F
2011/3/10 hatem Elshazly <strongwave83 at hotmail.com>:
> im using mpich2 with mpd as process manager.
