[mpich-discuss] how can I be sure that the program is running	via another computer
    h banki
    hd_banki at yahoo.com
    Thu Mar  3 09:43:16 CST 2011
Hi Rosner,
Thanks alot for your help.
--- On Thu, 3/3/11, Nicolas Rosner <nrosner at gmail.com> wrote:
Subject: Re: [mpich-discuss] how can I be sure that the program is running via another computer
Date: Thursday, March 3, 2011, 7:27 AM
Hi Banki,
> is there any way to show a message in the screen of *another computer* like "a part of program is running here"?
Yes, there is, but may I suggest that doing so might be overkill for
your purpose?
> actually I want to be sure that a part of program is running via another computer!!
Fair enough. But what if the other computer happened to be behind a
locked door, or across the ocean, or had no physical screen at all? In
distributed computing, you quickly realize how practical it is to have
remote results (or, in your case, proof of remote activity) delivered
right back to your local screen, rather than merely cause collateral
effects on the remote machines.
In fact, since this is so important, MPICH does a lot of work behind
the scenes to ensure each of your process' output (and errors, if any)
are collected, sent back, merged together and displayed as if they
were local output. (To avoid confusion, you can optionally ask mpiexec
to prepend the rank of each process to each locally printed line.)
Thus, all you need to do is have each process print something like
"This machine's hostname is %s", or anything similar that would
convince you it was running somewhere else. Try looking up
MPI_Get_processor_name, for instance.
Question: doesn't the cpi.c example do this already for you? It does
on Linux. No idea about Windows, though.
Hope this helps,
Nicolás
On Thu, Mar 3, 2011 at 7:29 AM, h banki <hd_banki at yahoo.com> wrote:
> Hello,
> I want to run a MPI program through two computers. so I have a machine file which has the IP of my computer and IP of another computer. and in both computers I have registered the same user with the same password.
> I use the below command, in the command prompt :
> C:\Program Files\MPICH2\examples>mpiexec -n 6 -machinefile machines.txt cpi.exe
> the program runs successfully and returns the correct result without any error.
> now I want to know that is there any way to show a message in the screen of another computer like "a part of program is running here"?
> Regards,
> Banki
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110303/ddd6b8d5/attachment-0001.htm>
