[mpich-discuss] MPI_Comm_Spawn and MPI_Open_port/MPI_Comm_accept/MPI_Comm_connect without using mpiexec and smpd
Jayesh Krishna jayesh at mcs.anl.gov
Tue Jun 28 14:05:17 CDT 2011
 Does your custom process manager (Windows Service) support the PMI wire protocol (protocol used by the PMI library to interact with the process manager)? PMI2 (The newer version of PMI) defines/standardizes the wire protocol and is implemented in the new process manager Hydra. Unfortunately I don't have enough resources to port Hydra to Windows (SMPD only supports PMI-1 and has its own custom wire protocol that you will have to figure out by looking into the code and the debug logs).
Jayesh
----- Original Message -----
Sent: Thursday, June 23, 2011 10:19:26 AM
Subject: [mpich-discuss] MPI_Comm_Spawn and MPI_Open_port/MPI_Comm_accept/MPI_Comm_connect without using mpiexec and smpd
I just started to investigate the possibility of using MPI in our application on the Windows platform.
Here is what I am trying to accomplish:
I am trying to use both of the following techniques:
1. MPI_Comm_Spawn
2. Client/server model using MPI_Open_port/MPI_Comm_accept/MPI_Comm_connect
I followed the example code here:
http://www.mcs.anl.gov/research/projects/mpi/mpi-standard/mpi-report-2.0/node98.htm#Node98
http://www.mcs.anl.gov/research/projects/mpi/mpi-standard/mpi-report-2.0/node106.htm
and was able to get them working if I use mpiexec / smpd. However, I want to start the executable without using mpiexec / smpd since we already have our own windows service application to deal with compute node resource allocation.
I already read through a lot of documentations, but couldn't find my answers to some of the basic problems that I am trying to solve:
1. Base on the MPI 2.2 document section 8.8 here:
http://www.mpi-forum.org/docs/mpi-2.2/mpi22-report.pdf
It's not a requirement to use mpiexec / mpirun to start an MPI program.
Is there any example available for starting the MPI program without using mpiexec / mpirun?
2. I found an example that allows debugging without the use of a process manager by setting environment variable in section 9.8 of this doc:
http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.3.2-windevguide.pdf
It noted that this cannot support MPI_Comm_Spawn. Is that a technical limitation or there is a workaround?
Thanks in advance for your help!
Eric _______________________________________________
mpich-discuss mailing list
