[mpich-discuss] about installation
    Jain, Rohit
    Rohit_Jain at mentor.com
    Mon Jun 27 17:03:08 CDT 2011
Hi Dave,
I am configuring new installation, and looking at my current config options, and need some clarification.
--enable-shared: If I just want to run machine installed valgrind on my application, and trying to find issues back in MPICH code, do I need to use this option?
--enable-totalview: If I just want to run totalview with my application and debug application's code, not inside MPICH code, Do I need to use this option?
Rohit
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
Sent: Thursday, April 21, 2011 7:43 AM
Subject: Re: [mpich-discuss] about installation
[I also answered this on the valgrind-users list, posting here for the MPICH2 community's benefit]
If you are trying to trace application calls to the MPI library, then rebuild your MPICH2 installation with the "--enable-shared" configure flag.  MPICH2 does not build shared libraries by default, but the Valgrind MPI wrappers expect a shared library in order to build.
If you are trying to trace calls *within* MPICH2, you can probably just reconfigure Valgrind with "--without-mpicc".
-Dave
On Apr 21, 2011, at 2:49 AM CDT, Kaveri Zanje wrote:
> I have install mpich2-1.3.2p1  with file system luster , testfs, ufs.
> I want to install valgrind for tracing MPI-IO call, but i am not able to install it .
> it is giving me following error
> Making all in mpi
> make[2]: Entering directory `/home1/stu2/valgrind-3.6.0/mpi'
> mpicc -g -O -fno-omit-frame-pointer -Wall -fpic -m64  -fpic -shared  -o libmpiwrap-amd64-linux.so libmpiwrap_amd64_linux_so-libmpiwrap.o
> /usr/bin/ld: /home/stu2/home1/mpich2-install/lib/libmpich.a(comm_rank.o): relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC
> /home/stu2/home1/mpich2-install/lib/libmpich.a: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> make[2]: *** [libmpiwrap-amd64-linux.so] Error 1
> make[2]: Leaving directory `/home1/stu2/valgrind-3.6.0/mpi'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home1/stu2/valgrind-3.6.0'
> make: *** [all] Error 2
> mpich-discuss mailing list
