[mpich-discuss] issues when writing a simple makefile to build MPI programs
    clara
    clarazhang at gmail.com
    Sat Jun 25 10:05:57 CDT 2011
See attached please.
On Sat, Jun 25, 2011 at 11:03 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> Can you please send all the log files requested in the README? It's very
> hard to help you otherwise.
> On 06/25/2011 10:01 AM, clara wrote:
>> Please see attached, thanks.
>> Btw, can you tell me which options need be set (the process manager is
>> selected gforker) if I don't want the generated mpicc to use "-lopa
>> -lmpl -lrt"?
>> About the above libraries, opa means "OpenPA",  which is to provide
>> atomics library. mpl means what? Is it "message passing library"? If so,
>> why can I only see C files about env, string and mem operations in
>> src/mpl/src?
>> - Clara
>> On Sat, Jun 25, 2011 at 10:44 AM, Pavan Balaji <balaji at mcs.anl.gov
>> <mailto:balaji at mcs.anl.gov>> wrote:
>>    I don't see the error in the log you sent. Please send us the log
>>    files as described in the README.
>>      -- Pavan
>>    On 06/25/2011 09:40 AM, clara wrote:
>>        Attached please find the output info when I ran configure with -m32
>>        option. Because I am building 64-bit libraries, the log files
>>        cannot be
>>        obtained now.
>>        - Clara
>>        On Sat, Jun 25, 2011 at 10:28 AM, Pavan Balaji
>>        <balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>
>>        <mailto:balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>> wrote:
>>            Can you send us the log files are described in the README?
>>        Please
>>            compress them as they can be huge.
>>              -- Pavan
>>            On 06/25/2011 09:12 AM, clara wrote:
>>                Thanks, but now I get the below error:
>>                configure: error: Could not determine a way to link a
>>        Fortran
>>                test program!
>>                On Sat, Jun 25, 2011 at 9:59 AM, Pavan Balaji
>>        <mailto:balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>>> wrote:
>>                    It's "CFLAGS", not "CFLAG".
>>                      -- Pavan
>>                    On 06/25/2011 08:42 AM, clara wrote:
>>                        I executed the following command:
>>                        ./configure
>>        --prefix=/mnt/lux/git/pios/xc/**______mpich2-32
>>                        --with-pm=gforker
>>                        --disable-faster CFLAG=-m32 CXXFLAGS=-m32
>>        FFLAGS=-m32
>>                FCFLAGS=-m32
>>                        and got the below errors:
>>                        configure: error: ****  Incompatible Fortran and C
>>                Object File
>>                        Types!  ****
>>                        F77 Object File Type produced by "gfortran -m32
>>        " is : : ELF
>>                        32-bit LSB
>>                        relocatable, Intel 80386, version 1 (SYSV), not
>>        stripped.
>>                          C  Object File Type produced by "gcc    -O2"
>>        is : :
>>                ELF 64-bit LSB
>>                        relocatable, x86-64, version 1 (SYSV), not
>> stripped.
>>                        Is there any simple way setting -m32 in order to
>>        build
>>                32-bit
>>                        libraries
>>                        on 64-bit system?
>>                        - Clara
>>                        On Fri, Jun 24, 2011 at 11:53 AM, Anthony Chan
>>        <chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>
>>        <mailto:chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>>
>>        <mailto:chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>>>
>>        <mailto:chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>>>>> wrote:
>>                            You need to rebuild mpich2 for 32bit.  Set
>>                            CFLAGS/CXXFLAGS/FFLAGS/FCFLAGS
>>                            to -m32 (assume your system has the 32bit
>>        support).
>>                            BTW, your install of 1.2.1p1 mpich2 is old,
>>        please
>>                upgrade
>>                        if possible
>>                            (the latest stable release is 1.4)
>>                            A.Chan
>>                            ----- Original Message -----
>>         > I think the default installed mpich2 in 64-bit ubuntu is in
>>                        x86_64
>>         > mode.
>>         > When I try to compile/link an MPI program in 32-bit mode,
>>                        there is an
>>         > error
>>         > below:
>>         > /usr/lib/libmpich.so: file not recognized: File format not
>>                        recognized
>>         > How can I configure the compile/link flags? Do I need to rebuild
>>         > mpich2 to
>>         > get a 32-bit libraries? Or is there any 32-bit libraries
>>                        coexisted
>>         > with
>>         > 64-bit libraries? Thanks.
>>         > Below is the output version information of the default installed
>>         > MPICH2:
>>         > MPICH2 Version: 1.2.1p1
>>         > MPICH2 Release date: Unknown, built on Tue Apr 27 15:06:31
>>                        UTC 2010
>>         > MPICH2 Device: ch3:nemesis
>>         > MPICH2 configure: --build=x86_64-linux-gnu --prefix=/usr
>>         > --includedir=${prefix}/include --mandir=${prefix}/share/man
>>         > --infodir=${prefix}/share/info --sysconfdir=/etc
>>                        --localstatedir=/var
>>         > --libexecdir=${prefix}/lib/___**___mpich2
>> --disable-maintainer-mode
>>         > --disable-dependency-tracking --disable-silent-rules --srcdir=.
>>         > --enable-sharedlibs=gcc --prefix=/usr --enable-f90
>>         > --sysconfdir=/etc/mpich2
>>         > --includedir=/usr/include/____**__mpich2
>>                --docdir=/usr/share/doc/mpich2
>>         > MPICH2 CC: gcc -g -O2 -g -Wall -O2 -O2
>>         > MPICH2 CXX: c++ -g -O2 -g -Wall -O2 -O2
>>         > MPICH2 F77: gfortran -g -O2 -O2
>>         > MPICH2 F90: f95 -O2
>>         > - Clara
>>         > On Fri, Jun 24, 2011 at 12:08 AM, Pavan Balaji
>>        <mailto:balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>>>**>
>>         > wrote:
>>         > > Clara,
>>         > > On 06/23/2011 10:53 PM, clara wrote:
>>         > >> If I only use shared memory communication among processes on
>> a
>>         > >> single
>>         > >> node, how can I configure the mpich2.1.4 (except
>>                            --with-pm=gforker)
>>         > >> in
>>         > >> order to link libraries as little as possible?
>>         > > Shared memory communication support comes by default in
>>                        MPICH2. You
>>         > > don't
>>         > > need to pass any special configure options; not even
>>         > > --with-pm=gforker.
>>         > > Unfortunately, all libraries are still required to be
>>                        linked with
>>         > > even when
>>         > > only shared memory support is needed.
>>         > >  -- Pavan
>>         > > Pavan Balaji
>>         > > http://www.mcs.anl.gov/~balaji
>>         > ______________________________**_______________________
>>         > mpich-discuss mailing list
>>         > mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.**gov<mpich-discuss at mcs.anl.gov>
>>        <mailto:mpich-discuss at mcs.anl.**__gov
>>        <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>>
>>        <mailto:mpich-discuss at mcs.anl.**>____gov
>>        <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>>>
>>        <mailto:mpich-discuss at mcs.anl <mailto:mpich-discuss at mcs.anl>**.
>>        <mailto:mpich-discuss at mcs.anl>**.__>____gov
>>        https://lists.mcs.anl.gov/____**__mailman/listinfo/mpich-**discuss<https://lists.mcs.anl.gov/______mailman/listinfo/mpich-discuss>
>>        <https://lists.mcs.anl.gov/___**_mailman/listinfo/mpich-**discuss<https://lists.mcs.anl.gov/____mailman/listinfo/mpich-discuss>
>>        <https://lists.mcs.anl.gov/__**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss>
>> **>__>
>>        <https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
>> **>__>__>
>> **>__>
>> **>__>__>
>> **>__>
>> **>__>__>
>>                    Pavan Balaji
>>            Pavan Balaji
>>    Pavan Balaji
> Pavan Balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110625/c368f9f5/attachment-0001.htm>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110625/c368f9f5/attachment-0001.bin>
