[mpich-discuss] issues when writing a simple makefile to build MPI programs
    Pavan Balaji
    balaji at mcs.anl.gov
    Sat Jun 25 10:03:29 CDT 2011
Can you please send all the log files requested in the README? It's very
hard to help you otherwise.
On 06/25/2011 10:01 AM, clara wrote:
> Please see attached, thanks.
> Btw, can you tell me which options need be set (the process manager is
> selected gforker) if I don't want the generated mpicc to use "-lopa
> -lmpl -lrt"?
> About the above libraries, opa means "OpenPA",  which is to provide
> atomics library. mpl means what? Is it "message passing library"? If so,
> why can I only see C files about env, string and mem operations in
> src/mpl/src?
> - Clara
> On Sat, Jun 25, 2011 at 10:44 AM, Pavan Balaji <balaji at mcs.anl.gov
> <mailto:balaji at mcs.anl.gov>> wrote:
>     I don't see the error in the log you sent. Please send us the log
>     files as described in the README.
>       -- Pavan
>     On 06/25/2011 09:40 AM, clara wrote:
>         Attached please find the output info when I ran configure with -m32
>         option. Because I am building 64-bit libraries, the log files
>         cannot be
>         obtained now.
>         - Clara
>         On Sat, Jun 25, 2011 at 10:28 AM, Pavan Balaji
>         <balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>
>         <mailto:balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>> wrote:
>             Can you send us the log files are described in the README?
>         Please
>             compress them as they can be huge.
>               -- Pavan
>             On 06/25/2011 09:12 AM, clara wrote:
>                 Thanks, but now I get the below error:
>                 configure: error: Could not determine a way to link a
>         Fortran
>                 test program!
>                 On Sat, Jun 25, 2011 at 9:59 AM, Pavan Balaji
>         <mailto:balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>>> wrote:
>                     It's "CFLAGS", not "CFLAG".
>                       -- Pavan
>                     On 06/25/2011 08:42 AM, clara wrote:
>                         I executed the following command:
>                         ./configure
>         --prefix=/mnt/lux/git/pios/xc/______mpich2-32
>                         --with-pm=gforker
>                         --disable-faster CFLAG=-m32 CXXFLAGS=-m32
>         FFLAGS=-m32
>                 FCFLAGS=-m32
>                         and got the below errors:
>                         configure: error: ****  Incompatible Fortran and C
>                 Object File
>                         Types!  ****
>                         F77 Object File Type produced by "gfortran -m32
>         " is : : ELF
>                         32-bit LSB
>                         relocatable, Intel 80386, version 1 (SYSV), not
>         stripped.
>                           C  Object File Type produced by "gcc    -O2"
>         is : :
>                 ELF 64-bit LSB
>                         relocatable, x86-64, version 1 (SYSV), not stripped.
>                         Is there any simple way setting -m32 in order to
>         build
>                 32-bit
>                         libraries
>                         on 64-bit system?
>                         - Clara
>                         On Fri, Jun 24, 2011 at 11:53 AM, Anthony Chan
>         <chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>
>         <mailto:chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>>
>         <mailto:chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>>>
>         <mailto:chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>>>>> wrote:
>                             You need to rebuild mpich2 for 32bit.  Set
>                             CFLAGS/CXXFLAGS/FFLAGS/FCFLAGS
>                             to -m32 (assume your system has the 32bit
>         support).
>                             BTW, your install of 1.2.1p1 mpich2 is old,
>         please
>                 upgrade
>                         if possible
>                             (the latest stable release is 1.4)
>                             A.Chan
>                             ----- Original Message -----
>          > I think the default installed mpich2 in 64-bit ubuntu is in
>                         x86_64
>          > mode.
>          > When I try to compile/link an MPI program in 32-bit mode,
>                         there is an
>          > error
>          > below:
>          > /usr/lib/libmpich.so: file not recognized: File format not
>                         recognized
>          > How can I configure the compile/link flags? Do I need to rebuild
>          > mpich2 to
>          > get a 32-bit libraries? Or is there any 32-bit libraries
>                         coexisted
>          > with
>          > 64-bit libraries? Thanks.
>          > Below is the output version information of the default installed
>          > MPICH2:
>          > MPICH2 Version: 1.2.1p1
>          > MPICH2 Release date: Unknown, built on Tue Apr 27 15:06:31
>                         UTC 2010
>          > MPICH2 Device: ch3:nemesis
>          > MPICH2 configure: --build=x86_64-linux-gnu --prefix=/usr
>          > --includedir=${prefix}/include --mandir=${prefix}/share/man
>          > --infodir=${prefix}/share/info --sysconfdir=/etc
>                         --localstatedir=/var
>          > --libexecdir=${prefix}/lib/______mpich2 --disable-maintainer-mode
>          > --disable-dependency-tracking --disable-silent-rules --srcdir=.
>          > --enable-sharedlibs=gcc --prefix=/usr --enable-f90
>          > --sysconfdir=/etc/mpich2
>          > --includedir=/usr/include/______mpich2
>                 --docdir=/usr/share/doc/mpich2
>          > MPICH2 CC: gcc -g -O2 -g -Wall -O2 -O2
>          > MPICH2 CXX: c++ -g -O2 -g -Wall -O2 -O2
>          > MPICH2 F77: gfortran -g -O2 -O2
>          > MPICH2 F90: f95 -O2
>          > - Clara
>          > On Fri, Jun 24, 2011 at 12:08 AM, Pavan Balaji
>         <mailto:balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>>>>
>          > wrote:
>          > > Clara,
>          > > On 06/23/2011 10:53 PM, clara wrote:
>          > >> If I only use shared memory communication among processes on a
>          > >> single
>          > >> node, how can I configure the mpich2.1.4 (except
>                             --with-pm=gforker)
>          > >> in
>          > >> order to link libraries as little as possible?
>          > > Shared memory communication support comes by default in
>                         MPICH2. You
>          > > don't
>          > > need to pass any special configure options; not even
>          > > --with-pm=gforker.
>          > > Unfortunately, all libraries are still required to be
>                         linked with
>          > > even when
>          > > only shared memory support is needed.
>          > >  -- Pavan
>          > > Pavan Balaji
>          > > http://www.mcs.anl.gov/~balaji
>          > _____________________________________________________
>          > mpich-discuss mailing list
>          > mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>         <mailto:mpich-discuss at mcs.anl.__gov
>         <mailto:mpich-discuss at mcs.anl.gov>>
>         <mailto:mpich-discuss at mcs.anl.>____gov
>         <mailto:mpich-discuss at mcs.anl.gov>>>
>         <mailto:mpich-discuss at mcs.anl <mailto:mpich-discuss at mcs.anl>.
>         <mailto:mpich-discuss at mcs.anl>.__>____gov
>         <mailto:mpich-discuss at mcs.anl.gov>>>>
>         https://lists.mcs.anl.gov/______mailman/listinfo/mpich-discuss
>         <https://lists.mcs.anl.gov/____mailman/listinfo/mpich-discuss>
>         <https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss>__>
>         <https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>__>__>
>                     Pavan Balaji
>             Pavan Balaji
>     Pavan Balaji
Pavan Balaji
