[mpich-discuss] installing and using MPI_PUBLISH_NAME and MPI_LOOKUP_NAME with mpich2
Bernard Secher - SFME/LGLS bernard.secher at cea.fr
Mon Jun 20 03:38:18 CDT 2011
The problem occures after I launch only the first executable:
mpiexec -np 2 -nameserver is209011 testMPI2
Bernard
Pavan Balaji a écrit :
> Can you tell me the mpiexec command line you are using for the two
> executables?
>  -- Pavan
> On 06/17/2011 01:53 AM, Bernard Secher - SFME/LGLS wrote:
>> Hi Pavan,
>> I can run my application on system with a shared file-system, but also
>> on system without shared file-system.
>> The usage is to perform coupling between parallel programs with more
>> than 1 process.
>> My test program uses the same executable, but it can be different
>> executables.
>> Bernard
>>> Hi Bernard,
>>> You didn't answer my first question. Can you please let us know about
>>> this:
>>> >> Do you have a shared file-system? If yes, you don't need to modify
>>> >> anything. It should just work. If no, then read below:
>>> With respect to the test program, what's the exact usage? It looks
>>> like it needs to be run with more than 1 process. You mentioned that
>>> there are two applications? Are both using the same executable (with
>>> different input arguments)?
>>> -- Pavan
>>> On 06/16/2011 04:12 AM, Bernard Secher - SFME/LGLS wrote:
>>>> When I tried to use hydra_nameserver I get the followinf error message
>>>> when I launch my application:
>>>> [secher at is209011 essai]$ [mpiexec at is209011] HYDU_sock_read
>>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/utils/sock/sock.c:223):
>>>> read errno (Input/output error)
>>>> [mpiexec at is209011] control_cb
>>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:249):
>>>> assert (!closed) failed
>>>> [mpiexec at is209011] HYDT_dmxu_poll_wait_for_event
>>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/tools/demux/demux_poll.c:77):
>>>> callback returned error status
>>>> [mpiexec at is209011] HYD_pmci_wait_for_completion
>>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:206):
>>>> error waiting for event
>>>> [mpiexec at is209011] main
>>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/ui/mpich/mpiexec.c:404):
>>>> process manager error waiting for completion
>>>> What is wrong
>>>> My application is just a little test program. I have attached it to
>>>> this
>>>> message.
>>>> Bernard
>>>>> [please keep mpich-discuss cc'ed]
>>>>> On 06/16/2011 02:18 AM, Bernard Secher - SFME/LGLS wrote:
>>>>>> How can I use the default publish mechanism? My Publish/lookup is
>>>>>> hapenning between two different applications. Is there an option to
>>>>>> give
>>>>>> to mpiexec for that ?
>>>>>> If I use the pmi option, the mpiexec -nameserver -help give the
>>>>>> following message:
>>>>>> -nameserver: Nameserver to use for publish/lookup (format is
>>>>>> host:port)
>>>>>> I don't understand what I have to do with this option.
>>>>>> First I launch the hydra_nameserver . Do I give some options to
>>>>>> hydra_nameserver ? Do I give some options then, to the two
>>>>>> mpiexec to
>>>>>> launch my two applications?
>>>>> There are no options required for hydra_nameserver. The two mpiexec's
>>>>> will need the -nameserver {hostname} option, where {hostname} is the
>>>>> name of the host where the nameserver is running.
>>>>> -- Pavan
>>>> _\\|//_
>>>> (' 0 0 ')
>>>> ____ooO (_) Ooo______________________________________________________
>>>> Bernard Sécher DEN/DM2S/SFME/LGLS mailto :bsecher at cea.fr
>>>> CEA Saclay, Bât 454, Pièce 114 Phone : 33 (0)1 69 08 73 78
>>>> 91191 Gif-sur-Yvette Cedex, France Fax : 33 (0)1 69 08 10 87
>>>> ------------Oooo---------------------------------------------------
>>>> oooO ( )
>>>> \ ( (_/
>>>> \_)
>>>> Ce messageélectronique et tous les fichiers attachés qu'il contient
>>>> sont confidentiels et destinés exclusivementà l'usage de la personne
>>>> à laquelle ils sont adressés. Si vous avez reçu ce message par erreur,
>>>> merci d'en avertir immédiatement sonémetteur et de ne pas en conserver
>>>> de copie.
>>>> This e-mail and any files transmitted with it are confidential and
>>>> intended solely for the use of the individual to whom they are
>>>> addressed.
>>>> If you have received this e-mail in error please inform the sender
>>>> immediately, without keeping any copy thereof.
>>         _\\|//_
>>        (' 0 0 ')
>>         oooO (   )
>>          \ ( (_/
>>           \_)
>> de copie.
>> addressed.
       _\\|//_
      (' 0 0 ')
 Bernard Sécher  DEN/DM2S/SFME/LGLS    mailto : bsecher at cea.fr
       oooO (   )
        \ ( (_/
         \_)
Ce message électronique et tous les fichiers attachés qu'il contient
sont confidentiels et destinés exclusivement à l'usage de la personne
merci d'en avertir immédiatement son émetteur et de ne pas en conserver
de copie.
intended solely for the use of the individual to whom they are addressed.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110620/98a42093/attachment.htm>
