[mpich-discuss] installing and using MPI_PUBLISH_NAME and	MPI_LOOKUP_NAME with mpich2
    Pavan Balaji
    balaji at mcs.anl.gov
    Fri Jun 17 09:35:01 CDT 2011
Can you tell me the mpiexec command line you are using for the two
executables?
  -- Pavan
On 06/17/2011 01:53 AM, Bernard Secher - SFME/LGLS wrote:
> Hi Pavan,
> I can run my application on system with a shared file-system, but also
> on system without shared file-system.
> The usage is to perform coupling between parallel programs with more
> than 1 process.
> My test program uses the same executable, but it can be different
> executables.
> Bernard
> Pavan Balaji a écrit :
>> Hi Bernard,
>> You didn't answer my first question. Can you please let us know about
>> this:
>> >> Do you have a shared file-system? If yes, you don't need to modify
>> >> anything. It should just work. If no, then read below:
>> With respect to the test program, what's the exact usage? It looks
>> like it needs to be run with more than 1 process. You mentioned that
>> there are two applications? Are both using the same executable (with
>> different input arguments)?
>> -- Pavan
>> On 06/16/2011 04:12 AM, Bernard Secher - SFME/LGLS wrote:
>>> When I tried to use hydra_nameserver I get the followinf error message
>>> when I launch my application:
>>> [secher at is209011 essai]$ [mpiexec at is209011] HYDU_sock_read
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/utils/sock/sock.c:223):
>>> read errno (Input/output error)
>>> [mpiexec at is209011] control_cb
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:249):
>>> assert (!closed) failed
>>> [mpiexec at is209011] HYDT_dmxu_poll_wait_for_event
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/tools/demux/demux_poll.c:77):
>>> callback returned error status
>>> [mpiexec at is209011] HYD_pmci_wait_for_completion
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:206):
>>> error waiting for event
>>> [mpiexec at is209011] main
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/ui/mpich/mpiexec.c:404):
>>> process manager error waiting for completion
>>> What is wrong
>>> My application is just a little test program. I have attached it to this
>>> message.
>>> Bernard
>>>> [please keep mpich-discuss cc'ed]
>>>> On 06/16/2011 02:18 AM, Bernard Secher - SFME/LGLS wrote:
>>>>> How can I use the default publish mechanism? My Publish/lookup is
>>>>> hapenning between two different applications. Is there an option to
>>>>> give
>>>>> to mpiexec for that ?
>>>>> If I use the pmi option, the mpiexec -nameserver -help give the
>>>>> following message:
>>>>> -nameserver: Nameserver to use for publish/lookup (format is
>>>>> host:port)
>>>>> I don't understand what I have to do with this option.
>>>>> First I launch the hydra_nameserver . Do I give some options to
>>>>> hydra_nameserver ? Do I give some options then, to the two mpiexec to
>>>>> launch my two applications?
>>>> There are no options required for hydra_nameserver. The two mpiexec's
>>>> will need the -nameserver {hostname} option, where {hostname} is the
>>>> name of the host where the nameserver is running.
>>>> -- Pavan
>>> _\\|//_
>>> (' 0 0 ')
>>> ____ooO (_) Ooo______________________________________________________
>>> Bernard Sécher DEN/DM2S/SFME/LGLS mailto :bsecher at cea.fr
>>> CEA Saclay, Bât 454, Pièce 114 Phone : 33 (0)1 69 08 73 78
>>> 91191 Gif-sur-Yvette Cedex, France Fax : 33 (0)1 69 08 10 87
>>> ------------Oooo---------------------------------------------------
>>> oooO ( )
>>> \ ( (_/
>>> \_)
>>> Ce messageélectronique et tous les fichiers attachés qu'il contient
>>> sont confidentiels et destinés exclusivementà l'usage de la personne
>>> à laquelle ils sont adressés. Si vous avez reçu ce message par erreur,
>>> merci d'en avertir immédiatement sonémetteur et de ne pas en conserver
>>> de copie.
>>> This e-mail and any files transmitted with it are confidential and
>>> intended solely for the use of the individual to whom they are
>>> addressed.
>>> If you have received this e-mail in error please inform the sender
>>> immediately, without keeping any copy thereof.
>         _\\|//_
>        (' 0 0 ')
>         oooO (   )
>          \ ( (_/
>           \_)
> de copie.
> intended solely for the use of the individual to whom they are addressed.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
