[mpich-discuss] FAQ addition
    Torquil Macdonald Sørensen
    torquil at gmail.com
    Sun Jun 19 06:42:15 CDT 2011
Hi!
Perhaps it would be a good idea to add the following to the MPICH2 FAQ in the
section "2 Building MPICH2":
Q: How do I build a Subversion checkout of MPICH2 on Unix?
A: Make sure you have autoconf, automake and libtool installed. Then run the
script "maint/updatefiles" within the MPICH2 source directory. This will
generate the "./configure" script that can be subsequently used for the usual
"./configure; make; make install" procedure.
MPICH2 FAQ:
http://wiki.mcs.anl.gov/mpich2/index.php/Frequently_Asked_Questions
Best regards
Torquil Sørensen
